Today I got 4 switches (Quigg GT-FSI-08) and a broken remote control (GT-1000). I'm under the impression that this combination should work with RFXcom. My idea is when I have the right setings for the RFXcom I can self-learn the switches. Is there somebody who can help me with correct settings (RFXcom modes needed) and switch type/sub type/code/etc.?
Best regards,
Jan
Quigg GT-1000 properties needed i.c.w. RFXcom
- Target OS: -
Re: Quigg GT-1000 properties needed i.c.w. RFXcom
This device is not in the supported device list, chapter 2.2.2 of the RFXtrx User Guide.
Unknown if this module is supported by the RFXtrx.
Check with RFXmngr is you can control the module using Lighting5 - Kangtai or Lighting5 - IT or Lighting4
If this does not operate contact support rfxcom.com
RFXtrx433, RFXtrx433E, RFXtrx433XL, RFX433XL, RFX868XL
Lighting 5 - Kangtai works! Thx for the hint.
But which RFXcom settings within domoticz belong to that?
- Target OS: -
Transmit should operate without enabling a protocol. Enable Lighting4+AC to receive Kangtai.
OK clear. But what I mean is that I do not have a working transmitter to "Learn Light/Switch" within Switches (https://<mydomoticzurl>/#/LightSwitches) section. So I need it to add manual via "Manual Light/Switch". There I need to configure a few things. Some I know, and some I don't:
Hardware: RFXcom
Device name: n.a.
Switch Type: On/Off
Type: ??? (what should this be, because Kangtai is not available in this combo box)
Depending on the Type fields get added or removed.
Hardware: RFXcom
Device name: n.a.
Switch Type: On/Off
Downloaded the source of Domoticz and found the following fragment within RFXNames.cpp:
{ pTypeLighting5, sTypeLightwaveRF, "LightwaveRF" },
{ pTypeLighting5, sTypeEMW100, "EMW100" },
{ pTypeLighting5, sTypeBBSB, "BBSB new" },
{ pTypeLighting5, sTypeMDREMOTE, "MDRemote" },
{ pTypeLighting5, sTypeRSL, "Conrad RSL" },
{ pTypeLighting5, sTypeLivolo, "Livolo" },
{ pTypeLighting5, sTypeTRC02, "TRC02 (RGB)" },
{ pTypeLighting5, sTypeTRC02_2, "TRC02_2 (RGB)" },
{ pTypeLighting5, sTypeAoke, "Aoke" },
{ pTypeLighting5, sTypeEurodomest, "Eurodomest" },
{ pTypeLighting5, sTypeLivoloAppliance, "Livolo" },
{ pTypeLighting5, sTypeRGB432W, "RGB432W" },
{ pTypeLighting5, sTypeMDREMOTE107, "MDRemote 107" },
{ pTypeLighting5, sTypeLegrandCAD, "Legrand CAD" },
{ pTypeLighting5, sTypeAvantek, "Avantek" },
{ pTypeLighting5, sTypeIT, "Intertek,FA500,PROmax" },
{ pTypeLighting5, sTypeMDREMOTE108, "MDRemote 108" },
{ pTypeLighting5, sTypeKangtai, "Kangtai / Cotech" },
Looks like this is (part of) the list that is being used to populate the combobox. Some of these names I can find in the UI of domoticz when adding a new switch manually (i.e. MDRemote 107/108), but some I can not find (i.e. Kangtai). I restored domoticz just now with the latest stable, but still not able to see Kangtai. What am I missing here?
