m.versteegh wrote: Tuesday 01 January 2019 14:39
I've initialised logging and rebooted the system, so it's a fresh log. It starts with the items as provided below. The log does contain a error, but that is related to InfluxDB. Based on the log, I would say that it has fired up the server running at 8443.
From the lines in the logfile it looks like domoticz started on ports 8080 and 8443 but I do not see the expected domoticz process in the result of the ps command.
Can you tell from the last lines in the logfile (use tail -f "your logfile" if domoticz is still running ?
can you also try
waaren wrote: Tuesday 01 January 2019 16:51
can you also try
Hello.
I have similar symptoms. Everything worked until you added the Xiaomi gate. After adding Xiaomi - no gui
After restoring the copy of the domoticza directory everything works (of course, a copy without Xiaomi).
-rw-r--r-- 1 pi pi 77 Feb 26 22:18 appversion.default
-rw-r--r-- 1 pi pi 79 Feb 26 22:20 appversion.h
-rw-r--r-- 1 pi pi 79 Feb 26 22:20 appversion.h.txt
-rw-r--r-- 1 pi pi 1400 Feb 26 22:18 appveyor.yml
drwxr-xr-x 6 pi pi 4096 Feb 26 22:18 cereal
-rw-r--r-- 1 pi pi 22210 Feb 26 22:19 CMakeCache.txt
drwxr-xr-x 8 pi pi 4096 Feb 27 00:31 CMakeFiles
-rw-r--r-- 1 pi pi 8275 Feb 26 22:19 cmake_install.cmake
-rw-r--r-- 1 pi pi 28573 Feb 26 22:18 CMakeLists.txt
drwxr-xr-x 84 pi pi 4096 Jun 23 2018 Config
-rw-r--r-- 1 pi pi 3521 Feb 26 22:19 CPackConfig.cmake
-rw-r--r-- 1 pi pi 3893 Feb 26 22:19 CPackSourceConfig.cmake
-rwxr-xr-x 1 pi pi 14614432 Jun 23 2018 domoticz
-rw------- 1 root root 14213 Feb 27 19:47 domoticz_crash.log
-rw-r----- 1 root root 409600 Feb 27 19:57 domoticz.db
-rw-r--r-- 1 pi pi 4427 Jun 23 2018 domoticz.sh
drwxr-xr-x 4 pi pi 4096 Jun 23 2018 dzVents
-rw-r--r-- 1 pi pi 3085 Feb 26 22:18 getgit.cmake
drwxr-xr-x 12 pi pi 12288 Feb 26 22:18 hardware
-rw-r--r-- 1 pi pi 87589 Jun 23 2018 History.txt
drwxr-xr-x 2 pi pi 4096 Feb 26 22:18 httpclient
-rw-r--r-- 1 pi pi 5930 Feb 26 22:18 INSTALL.md
drwxr-xr-x 2 pi pi 4096 Feb 26 22:18 json
-rw-r--r-- 1 pi pi 35147 Jun 23 2018 License.txt
drwxr-xr-x 5 pi pi 4096 Feb 26 22:19 lua
drwxr-xr-x 2 pi pi 4096 Feb 26 22:18 main
-rw-r--r-- 1 pi pi 2488 Feb 26 22:18 makebeta
-rw-r--r-- 1 pi pi 240814 Feb 26 22:19 Makefile
-rw-r--r-- 1 pi pi 2346 Feb 26 22:18 makerelease
drwxr-xr-x 2 pi pi 4096 Feb 26 22:18 Manual
drwxr-xr-x 3 pi pi 4096 Feb 26 22:20 MQTT
drwxr-xr-x 4 pi pi 4096 Feb 26 22:18 msbuild
drwxr-xr-x 2 pi pi 4096 Feb 26 22:18 notifications
drwxr-xr-x 2 pi pi 4096 Feb 26 22:18 patches
drwxr-xr-x 4 pi pi 4096 Jun 23 2018 plugins
drwxr-xr-x 2 pi pi 4096 Feb 26 22:18 push
-rw-r--r-- 1 pi pi 2864 Feb 26 22:18 README.md
drwxr-xr-x 8 pi pi 4096 Jun 23 2018 scripts
-rw-r--r-- 1 pi pi 3414 Jun 23 2018 server_cert.pem
drwxr-xr-x 2 pi pi 4096 Feb 26 22:18 smtpclient
drwxr-xr-x 3 pi pi 4096 Feb 26 22:23 sqlite
drwxr-xr-x 2 pi pi 4096 Feb 26 22:23 stdafx.h.gch
drwxr-xr-x 2 pi pi 4096 Feb 26 22:18 tcpserver
drwxr-xr-x 2 pi pi 4096 Feb 26 22:18 tinyxpath
drwxr-xr-x 3 pi pi 4096 Feb 26 22:18 tools
-rwxr-xr-x 1 pi pi 607 Jun 23 2018 updatebeta
-rwxr-xr-x 1 pi pi 490 Feb 26 22:18 updatedomo
-rwxr-xr-x 1 pi pi 624 Jun 23 2018 updaterelease
drwxr-xr-x 2 pi pi 4096 Feb 26 22:18 webserver
drwxr-xr-x 13 pi pi 4096 Jun 23 2018 www
drwxr-xr-x 3 pi pi 4096 Feb 26 22:20 zip
drwxr-xr-x 3 pi pi 4096 Feb 26 22:18 zlib
pi@raspberrypi:~ $ sudo curl -L install.domoticz.com | sudo bash
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 11643 100 11643 0 0 293k 0 --:--:-- --:--:-- --:--:-- 299k
bash: line 1: syntax error near unexpected token `newline'
bash: line 1: `<!DOCTYPE html>'
Last edited by marmachine on Thursday 28 February 2019 22:48, edited 1 time in total.
Similar issue, was running latest beta version.
Since today I when I tried to add additional IP Camera (it showed up in preview gave error when hitting ADD button)
Error I got was:
"Problem adding camera!"
It failes a couple of times, so I believed a reboot of my system would be good.
System reboot, no more Domoticz.
after a reboot and update of installed packeges it still did not work.
Checked Domoticz and saw that service was not started.
started domoticz and could view my page again.
Now need to sort out why the Domoticz service was not started automatically.
