I did not find json query in Wiki about how to obtain history (both in graph and number form) of custom sensor. I collect from this sensor infos from distant dust sensor (PPM of dust in air) and nodeMCU (based on EasyESP) rapports every 5 min results of measurements.
It is possible to obtain such rapport from WEB GUI of Domoticz but is it possible from command line/script or so on?
Obtain history of custom sensor
mackowiakp
- waaren
Re: Obtain history of custom sensor
From a script or command line:mackowiakp wrote: Monday 31 December 2018 8:28 I did not find json query in Wiki about how to obtain history (both in graph and number form) of custom sensor. I collect from this sensor infos from distant dust sensor (PPM of dust in air) and nodeMCU (based on EasyESP) rapports every 5 min results of measurements.
http://domoticIP:domoticzPort/json.htm?range=year&sensor=Percentage&type=graph&idx=Your device ID
http://domoticIP:domoticzPort/json.htm?range=month&sensor=Percentage&type=graph&idx=Your device ID
http://domoticIP:domoticzPort/json.htm?range=day&sensor=Percentage&type=graph&idx=Your device IDcannot attach a screenshot because or error: "Sorry, the board attachment quota has been reached."
Until fixed please use this external link to view the screenshot
mackowiakp
OK. THX for answer and PM. it works. But be so king to tell me is any way to specify the range of time the rapport should be generated?
