Python Plugin: Chromecast Topic is solved
Ewaldharmsen
Re: Python Plugin: Chromecast
Your lso just create the user variable yourself, just create a variable named "Badkamer"
Sollbohakan
Have this error in Domoticz log:
2018-12-21 14:48:05.682 Error: (Chromecasts) Error on line 314 Error is 'NoneType' object has no attribute 'display_name'
2018-12-21 15:17:49.925 Error: (Chromecasts) http://127.0.0.1:8192/json.htm?type=com ... iable&idx= did not return any results. ([1, Chromecast('192.168.0.101', port=8009, device=DeviceStatus(friendly_name='Vardagsrum', model_name='Chromecast Audio', manufacturer='Google Inc.', uuid=UUID('ec8b31a6-f59e-524e-34c8-49fd10cf3331'), cast_type='audio')), '', 'CONNECTED', 0])
2018-12-21 15:17:49.954 Error: (Chromecasts) http://127.0.0.1:8192/json.htm?type=com ... iable&idx= did not return any results. ([0, Chromecast('192.168.0.235', port=8009, device=DeviceStatus(friendly_name='Mini1', model_name='Google Home Mini', manufacturer='Google Inc.', uuid=UUID('7e9a0c3e-fb27-1b72-7008-d51a93bb0f11'), cast_type='cast')), '', 'CONNECTED', 0])
I have only 1 Google home mini and 1 Chromecast Audio.
jeroenkl
Ok, still same issue.Ewaldharmsen wrote: Friday 21 December 2018 12:00 Your lso just create the user variable yourself, just create a variable named "Badkamer"
dextm80
- Domoticz version: 4.10159
ok i understand my error. Wrong error path installing dipendencies
sudo pip3 install pychromecast -t /home/HEREPUTMYUSER/domoticz/plugins/ChromecastPlugin
fyi now works all ok thanks
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
jeroenkl
For me it is working again. Removed the script and removed manually the Chromecast dir.Sollbohakan wrote: Friday 21 December 2018 15:12 Have this error in Domoticz log:
Uservariables not removed
Re-install
thxs for the support
My Chromecast connected to the TV works fine, but my other devices (Google Home and Google Home mini) give an error.
Where is that attribute to be set?
2018-12-23 17:04:20.899 Error: (Cast) Error on line 314 Error is 'NoneType' object has no attribute 'display_name'-
Amsterdam020
- Domoticz version: 3.5629
I tried to install the "Chromecast status and control plugin"
but i get this error in the log:
I have created two instances so i have two rows..
When I try to delete the hardware in the hardware domoticz crashes and no webpage respond any longer.
How can i delete the hardware or somebody have another idea to solve this?
MODIFY: solved by beginning on a second pi
2018-12-23 17:50:36.878 Error: chromecast hardware (21) thread seems to have ended unexpectedly
2018-12-23 17:50:36.879 Error: chromecast hardware (22) thread seems to have ended unexpectedly
Last edited by Amsterdam020 on Monday 24 December 2018 1:25, edited 1 time in total.
Rp3, youlesss, rfxcom, philips hue, dsb1820
When ever I want to set audio level of one of the Google Home devices, I get the error:
Anyone any idea how to solve that?
Error: (Cast) Error on line 409 Error is Trying to use the controller without it being registered with a Cast object.-
mark.sellwood
Domoticz V4.10303
Python version '3.5.3
ChromeCast version 3.1.0
This plugin appears to be working fine with my Home Hub but isn't working with my Home Mini's
If I try to make one of the Mini's say something I get the following in the log:-
If I try to set the volume i get:-
I also note that if I ask one of the Mini's to play a radit channel it works fine but nothing is updated in the Plugin.
I also see the following errors in the log:-
Not sure how to get all the devices working.
2018-12-27 21:33:06.220 Status: (ChromeCast) Will pronounce "Hello" on chromecast Office speaker
2018-12-27 21:33:06.221 Error: (ChromeCast) Error on line 335 Error is 'NoneType' object has no attribute 'display_name'Code: Select all
2018-12-27 21:34:56.178 Status: User: Admin initiated a switch command (2/Office speaker/Set Level)
2018-12-27 21:34:56.215 Error: (ChromeCast) Error on line 417 Error is 'Chromecast' object has no attribute 'Name'I also see the following errors in the log:-
2018-12-28 03:42:43.338 Error: (ChromeCast) Error on line 221 Error is Can't convert 'NoneType' object to str implicitly
2018-12-28 03:43:21.171 Error: (ChromeCast) Error on line 154 Error is Can't convert 'ConnectionStatus' object to str implicitly
2018-12-29 04:23:14.563 Error: (ChromeCast) Error on line 104 Error is 'Idle'3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
Ewaldharmsen
Can you check version 3.1.2?mark.sellwood wrote: Thursday 27 December 2018 22:40 Domoticz V4.10303
If I try to make one of the Mini's say something I get the following in the log:-If I try to set the volume i get:-Code: Select all
2018-12-27 21:33:06.220 Status: (ChromeCast) Will pronounce "Hello" on chromecast Office speaker 2018-12-27 21:33:06.221 Error: (ChromeCast) Error on line 335 Error is 'NoneType' object has no attribute 'display_name'I also note that if I ask one of the Mini's to play a radit channel it works fine but nothing is updated in the Plugin.Code: Select all
2018-12-27 21:34:56.178 Status: User: Admin initiated a switch command (2/Office speaker/Set Level) 2018-12-27 21:34:56.215 Error: (ChromeCast) Error on line 417 Error is 'Chromecast' object has no attribute 'Name'
I also see the following errors in the log:-Not sure how to get all the devices working.Code: Select all
2018-12-28 03:42:43.338 Error: (ChromeCast) Error on line 221 Error is Can't convert 'NoneType' object to str implicitly 2018-12-28 03:43:21.171 Error: (ChromeCast) Error on line 154 Error is Can't convert 'ConnectionStatus' object to str implicitly 2018-12-29 04:23:14.563 Error: (ChromeCast) Error on line 104 Error is 'Idle'
I hope that solves the problem
Ewaldharmsen
should be solved in version 3.1.2EddyG wrote: Sunday 23 December 2018 20:10 When ever I want to set audio level of one of the Google Home devices, I get the error:Anyone any idea how to solve that?Code: Select all
mark.sellwood
Just done a git pull & now its reported that I'm on 3.1.2
Level control of my Home Hub is working fine but if I try to set the volume of a Home Mini i get:-
2018-12-30 12:23:44.160 Status: User: Admin initiated a switch command (2/Office speaker/Set Level)
2018-12-30 12:23:44.180 Error: (ChromeCast) Error on line 409 Error is Trying to use the controller without it being registered with a Cast object.3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
Ewaldharmsen
Can you try a full reboot?
mark.sellwood
Tried a full reboot, that didn't help so I removed the plugin, rebooted, deleted the ChromcastPlugin directory, rebooted, added the plugin back along with pychromecast, rebooted, added the plugin back & I still have the error.
Log below.
Log below.
2018-12-30 14:04:56.470 Status: Domoticz V4.10304 (c)2012-2018 GizMoCuz
2018-12-30 14:04:56.483 Status: Build Hash: 30480b21, Date: 2018-12-30 08:37:02
2018-12-30 14:04:56.488 Status: Startup Path: /home/pi/domoticz/
2018-12-30 14:04:56.800 Status: EventSystem: reset all events...
2018-12-30 14:04:57.918 Active notification Subsystems: (0/13)
2018-12-30 14:04:57.869 Status: PluginSystem: Started, Python version '3.5.3'.
2018-12-30 14:04:57.963 Status: WebServer(HTTP) started on address: :: with port 8080
2018-12-30 14:04:58.063 Starting shared server on: :::6144
2018-12-30 14:04:58.046 Status: WebServer(SSL) started on address: :: with port 443
2018-12-30 14:04:58.054 Status: Proxymanager started.
2018-12-30 14:04:58.064 Status: TCPServer: shared server started...
2018-12-30 14:04:58.069 Status: RxQueue: queue worker started...
2018-12-30 14:05:00.072 Status: EventSystem: reset all events...
2018-12-30 14:05:00.074 Status: EventSystem: reset all device statuses...
2018-12-30 14:05:00.340 Status: PluginSystem: Entering work loop.
2018-12-30 14:05:00.701 Status: Python EventSystem: Initalizing event module.
2018-12-30 14:05:00.704 Status: EventSystem: Queue thread started...
2018-12-30 14:05:00.705 Status: EventSystem: Started
2018-12-30 14:07:46.879 Status: (Chromecast) Started.
2018-12-30 14:07:58.972 Status: (Chromecast) Initialized version 3.1.2, author 'Tsjippy'
2018-12-30 14:07:58.975 Status: (Chromecast) Entering work loop.
2018-12-30 14:07:58.986 Status: (Chromecast) Checking if images are loaded
2018-12-30 14:07:58.988 Status: (Chromecast) Starting up
2018-12-30 14:07:59.170 (Chromecast) Checking devices for Office speaker
2018-12-30 14:07:59.256 (Chromecast) Created uservariable for 'Office speaker'
2018-12-30 14:07:59.256 (Chromecast) Created 'Status' device for chromecast 'Office speaker'
2018-12-30 14:07:59.270 (Chromecast) Device Image update: 'Chromecast', Currently 0, should be 101
2018-12-30 14:07:59.309 (Chromecast) Created 'Volume' device for chromecast 'Office speaker'
2018-12-30 14:07:59.315 (Chromecast) Device Image update: 'Chromecast', Currently 0, should be 101
2018-12-30 14:07:59.340 (Chromecast) Created 'Title' device for chromecast 'Office speaker'
2018-12-30 14:07:59.346 (Chromecast) Device Image update: 'Chromecast', Currently 0, should be 101
2018-12-30 14:07:59.367 (Chromecast) Created 'App' device for chromecast 'Office speaker'
2018-12-30 14:07:59.375 (Chromecast) Device Image update: 'Chromecast', Currently 0, should be 101
2018-12-30 14:07:59.402 (Chromecast) Checking devices for Lounge display
2018-12-30 14:07:59.483 (Chromecast) Created uservariable for 'Lounge display'
2018-12-30 14:07:59.484 (Chromecast) Created 'Status' device for chromecast 'Lounge display'
2018-12-30 14:07:59.492 (Chromecast) Device Image update: 'Chromecast', Currently 0, should be 101
2018-12-30 14:07:59.518 (Chromecast) Created 'Volume' device for chromecast 'Lounge display'
2018-12-30 14:07:59.525 (Chromecast) Device Image update: 'Chromecast', Currently 0, should be 101
2018-12-30 14:07:59.557 (Chromecast) Created 'Title' device for chromecast 'Lounge display'
2018-12-30 14:07:59.563 (Chromecast) Device Image update: 'Chromecast', Currently 0, should be 101
2018-12-30 14:07:59.584 (Chromecast) Created 'App' device for chromecast 'Lounge display'
2018-12-30 14:07:59.592 (Chromecast) Device Image update: 'Chromecast', Currently 0, should be 101
2018-12-30 14:07:59.619 (Chromecast) Checking devices for Front bedroom speaker
2018-12-30 14:07:59.700 (Chromecast) Created uservariable for 'Front bedroom speaker'
2018-12-30 14:07:59.700 (Chromecast) Created 'Status' device for chromecast 'Front bedroom speaker'
2018-12-30 14:07:59.708 (Chromecast) Device Image update: 'Chromecast', Currently 0, should be 101
2018-12-30 14:07:59.735 (Chromecast) Created 'Volume' device for chromecast 'Front bedroom speaker'
2018-12-30 14:07:59.741 (Chromecast) Device Image update: 'Chromecast', Currently 0, should be 101
2018-12-30 14:07:59.766 (Chromecast) Created 'Title' device for chromecast 'Front bedroom speaker'
2018-12-30 14:07:59.772 (Chromecast) Device Image update: 'Chromecast', Currently 0, should be 101
2018-12-30 14:07:59.793 (Chromecast) Created 'App' device for chromecast 'Front bedroom speaker'
2018-12-30 14:07:59.802 (Chromecast) Device Image update: 'Chromecast', Currently 0, should be 101
2018-12-30 14:07:59.828 (Chromecast) Devices check done
2018-12-30 14:07:59.909 (Chromecast) Found uservariable for Office speaker
2018-12-30 14:07:59.910 (Chromecast) Found uservariable for Lounge display
2018-12-30 14:07:59.910 (Chromecast) Found uservariable for Front bedroom speaker
2018-12-30 14:07:59.910 (Chromecast) Local ip address is 192.168.1.20
2018-12-30 14:07:59.911 (Chromecast) Starting file server on port 8000
2018-12-30 14:07:59.954 (Chromecast) Files in the '/tmp/' directory are now available on port 8000
2018-12-30 14:07:59.119 Status: Incoming connection from: 192.168.1.20
2018-12-30 14:07:59.969 Status: (Chromecast) Checking for available chromecasts
2018-12-30 14:08:09.536 (Chromecast) Found these chromecasts: Lounge display, Office speaker, Onkyo TX-L50 EB57F4, Front bedroom speaker
2018-12-30 14:08:09.537 (Chromecast) Registering listeners for Lounge display
2018-12-30 14:08:09.564 (Chromecast) Update Chromecast - App name-Lounge display: 0 - '0'
2018-12-30 14:08:09.599 (Chromecast) Update Chromecast - Volume-Lounge display: 2 - '50'
2018-12-30 14:08:09.600 (Chromecast) Done registering listeners for Lounge display
2018-12-30 14:08:09.601 (Chromecast) Registering listeners for Office speaker
2018-12-30 14:08:09.536 Status: (Chromecast) Connected to Lounge display
2018-12-30 14:08:09.601 Status: (Chromecast) Connected to Office speaker
2018-12-30 14:08:14.409 (Chromecast) Registering listeners for Front bedroom speaker
2018-12-30 14:08:14.408 Status: (Chromecast) Connected to Front bedroom speaker
2018-12-30 14:08:46.861 Status: User: Admin initiated a switch command (17/Chromecast - Volume-Office speaker/Set Level)
2018-12-30 14:08:46.885 Error: (Chromecast) Error on line 409 Error is Trying to use the controller without it being registered with a Cast object.3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
Ewaldharmsen
I have no idea, here it just works.
Can you try version 3.1.3? That should print the cast object.
mark.sellwood
Thanks, this is what I get with 3.1.3
I hope this helps
2018-12-30 16:34:34.382 Status: User: Admin initiated a switch command (17/Chromecast - Volume-Office speaker/Set Level)
2018-12-30 16:34:34.404 Error: (Chromecast) Somehow I cannot set the volume. The current chromecast used is this one: Chromecast('192.168.1.71', port=8009, device=DeviceStatus(friendly_name='Office speaker', model_name='Google Home Mini', manufacturer='Google Inc.', uuid=UUID('42ad2484-b19e-ce23-bad4-4f01b7c8ab8a'), cast_type='cast'))3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
Ewaldharmsen
Found the error, fixed in version 1.3.4: you cannot set the volume on a chrome cast audio device when no app is connected.mark.sellwood wrote: Sunday 30 December 2018 17:39 Thanks, this is what I get with 3.1.3I hope this helpsCode: Select all
2018-12-30 16:34:34.382 Status: User: Admin initiated a switch command (17/Chromecast - Volume-Office speaker/Set Level) 2018-12-30 16:34:34.404 Error: (Chromecast) Somehow I cannot set the volume. The current chromecast used is this one: Chromecast('192.168.1.71', port=8009, device=DeviceStatus(friendly_name='Office speaker', model_name='Google Home Mini', manufacturer='Google Inc.', uuid=UUID('42ad2484-b19e-ce23-bad4-4f01b7c8ab8a'), cast_type='cast'))
mark.sellwood
Thanks, I'll give 3.1.4 a try tomorrow and let you know how it goes.
mark.sellwood
Hi, so with 3.1.4 I still can't control the volume.
In my Office I asked my Google Home Mini to play "Magic Radio" this happen s fine.
I previous versions of the plugin (sorry I don't remember what one) it would display "Magic Radio" in the Text display in the Utility tab, this doesn't happen now.
With the Google Home Mini playing the radio I cant control the Volume, I get the error
I also note that you cant make the Home Mini say anything, I entered Hello on the Variable, in the log i see
I hope this helps.
2018-12-31 07:52:15.786 Status: (Chromecast) Cannot issue a command to 'Office speaker' when no app is connected.Code: Select all
2018-12-31 07:52:49.311 Status: (Chromecast) Will pronounce "Hello" on chromecast Office speaker
2018-12-31 07:52:49.312 Error: (Chromecast) Error on line 312 Error is 'NoneType' object has no attribute 'display_name'3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
Same here on plugin version 3.1.4. and Domoticz 4.10302
