Lights on when LUX <=500 else off
EdwinK
Post by EdwinK »
I know I've seen such a script here somewhere, but searching for it doesn't find any.
What I need to do is when the LUX is below a set level (500 for example) it needs to turn on the outside lights. When the level is above the set level then turn it off again.
(The 500 is arbitrary, it could well be another level that I need, think twilight or dusk).
Re: Lights on when LUX <=500 else off
EdwinK wrote: Sunday 30 December 2018 15:32 I know I've seen such a script here somewhere, but searching for it doesn't find any.
In its most simple form
-- outside lights
            on      =   {   timer                       =   { "every 15 minutes"  } },
    execute = function(dz)
        lowerLux        = 400
        upperLux        = 500
        currentLux      = dz.devices("lux device name").lux
        outsideLight    = dz.devices("outside light name")
        if currentLux < lowerLux then
            outsideLight.switchOn().checkFirst()
        elseif currentLux > upperLux then
            outsideLight.switchOff().checkFirst()
EdwinK
Post by EdwinK »
Thanks. I like the most simple form's :). Just I have several switches. One called 'Lamp - Berging' and the others 'Buiten - 1' and 'Buiten - 2' Should have said that before ;)
EdwinK wrote: Sunday 30 December 2018 16:07 Thanks. I like the most simple form's :). Just I have several switches. One called 'Lamp - Berging' and the others 'Buiten - 1' and 'Buiten - 2' Should have said that before ;)
If you always want to switch them together then probably easier to put them in a group. Please send me a PM if you want to discuss further
EdwinK
Post by EdwinK »
Let's see if I can get that to work
havnegata
Domoticz version: V4.10162
Post by havnegata »
Please, @waaren, continue to share your knowledge here in the forum and not by PM's. That way lots of people can learn, and I for sure have learned a lot from you!
havnegata wrote: Sunday 30 December 2018 17:32 Please, @waaren, continue to share your knowledge here in the forum and not by PM's. That way lots of people can learn, and I for sure have learned a lot from you!
I will but sometimes the process of getting to a result require a lot of communication that is not very interesting for many.
I always ask to share the end-result when it can be of any use to others.
and.. thx for the compliment.
EdwinK
Post by EdwinK »
O.. I will put the end result ;)
-- outside lights
        lowerLux        = 400
        upperLux        = 500
        currentLux      = dz.devices("LUX").lux
        outsideLights   = dz.groups("Buitenlampen")   --This should be a group, not a scene!!
            outsideLights.switchOn().checkFirst()
            outsideLights.switchOff().checkFirst()
Now it looks real simple.
havnegata
Post by havnegata »
