I doesn't found where set the PIN Code for the security panel.
I see in the forum it is in the Parameters but i doesn't see .
Anyone can take a Print Screen or a few explanation for set this PIN Code please ?
Domoticz version: 3.5877
Build Hash: 15b013c
Compile Date: 2016-11-10 16:44:33
THANKS
Where to setup PIN Code for the Security Panel ? Topic is solved
- bbqkees
- Domoticz version: 4.1x
Re: Where to setup PIN Code for the Security Panel ?
setup->system->security panel.
It is right there on the first tab on the right side.
OK thank you
In this i see "Password" then i thought it was for something else because i doesn't see PIN
THANKS
THANKS
- Domoticz version: 4.97
I am a begginer and I am sure the solution is straightforward. I tried setting a PIN code in the manner described above. When I press apply settings, it closes the setting tab and opens the dashboard tab. However, there is no security panel in my devices section and when I go back to the settings tab, the security panel password is re-set to the defualt xxxxxxxetc.
What am I doing wrong?
Users browsing this forum: Amazon [Bot], Bing [Bot] and 1 guest
