maxHours and maxMinutes don't work correctly (for me)
papoo
Domoticz version: 4.10
Post by papoo »
hello
i want to log 36 hours of data temperature in history.
i try
    data = {
        temperatures    = { history = true, maxHours = 36 },
and
    data = {
        temperatures    = { history = true, maxMinutes = 2160 },
but only 100 items are in the data file
i try also
    data = {
        temperatures    = { history = true, maxHours = 36, maxMinutes = 2 },
for test, same result.
maybe i don't use this function correctly?
domoticz v4.10267
edit : sorry i don't use the bugs subforum. you can move this post.
Re: maxHours and maxMinutes don't work correctly (for me)
papoo wrote: Friday 28 December 2018 9:22 I want to log 36 hours of data temperature in history but only 100 items are in the data file.
The limit of 100 is hardcoded. Probably because of potential response / performance issues. You can easily lift this limit by modifying the file
domoticz/dzVents/runtime/HistoricalStorage.lua
and change in line 2
local MAXLIMIT = 100
to a number that you require.
Please note
1. Depending on your system / systemload this might lead to noticeable delays but I have not seen any significant dropdown on my RPI-3 (Debian stretch and using berryboot for rerouting filestorage IO over network to NAS) during my tests.
2. The file domoticz/dzVents/runtime/HistoricalStorage.lua will be overwritten with every domoticz update.
papoo
Post by papoo »
Thank's waaren
if i define maxItems = 13000
the data exceed 100
i try
temperatures    = { history = true, maxItems = 13000, maxHours = 36 },
to see if dzvents limit the 36 lasts hours
