Dear all,
I just receive my new FGR-223 and after mount them I had 2 issues:
Issue 1) My EVERSPRING SA413 - Contrôleur USB Z-Wave Plus discovers the device, ok nice. But with label like "FIBARO System Unknown: type=0303, id=1000" but not with all paramters only these (I try to re-add device and also reset it completly):
150. Parameter #150:
156. Parameter #156:
157. Parameter #157:
3001. Protection:
Why only these parameters?
Issue 2) I mount device with 2 toggle switch Up on S1 and Down on S2 but device only work like "gate motor".... I don't want that I want Switch Up => Up and Switch Down => Down... how to force to standard mounting ?
Please, could you help me?
Best regards,
LC
Fibaro fgr 223 parameters issue
funmsa
- Domoticz version: 2023.2
Re: Fibaro fgr 223 parameters issue
Dear Loic,
Did you have exactly same problem than mine ? Or you just cut&paste my question on Domoticz forum ?
https://forum.fibaro.com/topic/32682-fg ... ent-164414
Best regards.
Best regards.
loicc21
Hello, I have exactly the same issue.
My English is not good, so I used your message.
Hope we will find good answers
Merry Christmas
Merry Christmas
funmsa
Happy to see I'm not alone with the issue !
I find some information about OpenZwave definition but I don't already all understand to fix problem, but more or less :
Here you can find all device already described (unfortunately FGR-223 don't exist again) : https://github.com/OpenZWave/open-zwav ... ter/config
Here your local driver where must put new device description : domoticz/Config/[BRAND]/[device.xml]
I receive info than Bety Version Fibaro Box have included the new device : last homecenter beta Version 4.521 Beta
My problem It's :
To find a xml describing the device like fgr223.xml (1er challenge)
And after (second challenge) to understand the correct procedure to add a new description device on my Domoticz (without wainting new version)
I find this but don't work for me (but I didn't delete the file I'm scarry to lose all others ZWave device setup... to much work) https://github.com/OpenZWave/open-zwave ... ng-Devices
Other possibility (perhaps) it's to use Zensys Tools (never use it but Aeotec send my reference) to direct setup my device (and solve directly the problem short terme until a new version of Domoticz include full description)
If you have also other idea please send me some help too.
Best regards.
My problem It's :
Best regards.
funmsa
Dear All,
Just solve it ! I share with you how...
Add file : https://github.com/OpenZWave/open-zwave ... fgr223.xml => Special thank to Nechry !
Modify manufacturer file to link to fgr223.xml : https://github.com/OpenZWave/open-zwave ... ecific.xml
After just remove your device and add again and ... miracle all parameters are available !
Beautifull
Beautifull
I installed the latest version of Domoticz on Debian.
I have the same problem when i try to include FGR-223 : "FIBARO System Unknown: type=0303, id=1000".
However, I had already the line "<Product type="0303" id="1000" name="FGR223 Roller Shutter Controller 3" config="fibaro/fgr223.xml"/>" in Config/manufacturer_specific.xml and the xml file in Config/fibaro.
I tried to install beta version of Domoticz but i have the same problem.
Have you got an idea ?
Thank'a a lot.
Thank'a a lot.
Jordindc
- Domoticz version: 2020.2
Same here,
I added fgr223.xml in Config/fibaro directory and added the corresponding line in manufacturer_specific.xml file. Restarted several times domoticz server, when I add the module in the system, although now os well recognized as a Fibaro Roller Shutter 3+ device, I only get parameter 3001 Protection, and it works as a Garage gate (only S1 works alternating blind direction, no other function available).
Any suggestion about this issue?
Thanks in advance
Thanks in advance
