local variable not updating until after script\working with json data
Arsenius
Post by Arsenius »
I am trying to get the RGB value of a dummy_color_switch.
The json value looks like this:
Color "{\"b\":255,\"cw\":0,\"g\":247,\"m\":3,\"r\":199,\"t\":0,\"ww\":0}"
in my dzvent script i would like to have 3 variables for Red\Green\Blue.
So from the wiki i get that i need to use domoticz.utils.fromJSON() and that i can then assign these 3 values so i made this script:
		devices = {
			'color_switch'
	    myColor = domoticz.utils.fromJSON(device.color) -- also tried this with 'local myColor'
	    print(myColor.r)
	    print(myColor.g)
	    print(myColor.b)
When i change the color on the switch, i dont see the new values but i see the old values from the previous change.
Is this the right way to get specific values from a json value?
How do i make this so these values are from the made change.
Re: local variable not updating until after script\working with json data
Arsenius wrote: Sunday 23 December 2018 18:53 I am trying to get the RGB value of a dummy_color_switch.
It is the right way to get values from a JSON but here the problem is that domoticz does not update the color values on the first pass. (don't know enough of the domoticz internals to explain why)
You can get the RGB values but you will have to use an explicit API call and therefor you need to use the workaround as in the script below.
local callBack    = "getColorFromDevice"
local colorSwitch = 839
    on =    {
                devices         = { colorSwitch },
                httpResponses   = { callBack    },
	execute = function(dz, item)
        local function getDeviceStatus(idx)
            local url         = dz.settings['Domoticz url'] .. "/json.htm?type=devices&rid=" .. idx
            dz.openURL  ({ url = url, method = "GET", callback = callBack })
        if item.isDevice then
            getDeviceStatus(item.id)
            myColor = item.json
            myColor = dz.utils.fromJSON((myColor.result[1].Color))
            dz.log("Red   value: " .. myColor["r"],dz.LOG_FORCE)
            dz.log("Green value: " .. myColor["g"],dz.LOG_FORCE)
            dz.log("Blue  value: " .. myColor["b"],dz.LOG_FORCE)
Arsenius
Post by Arsenius »
Thank you, it works.
Users browsing this forum: gvhoofst and 1 guest
