Hello
I am a newbie with domoticz installation
My new raspberry pi 3 B+ is running on Raspbian Stretch Lite .
Via Putty , I have contact with my pi and it is running fine .
[email protected]'s password:
Linux raspberrypi 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Dec 21 17:34:48 2018 from 192.168.0.213
SSH is enabled and the default password for the 'pi' user has not been changed.
This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
When I try the command to install domoticz" the easy way" I get the following response :
pi@raspberrypi:~ $ curl -L install.domoticz.com | sudo bash
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0bash: line 1: syntax error near unexpected token `newline'
bash: line 1: `<!DOCTYPE html>'
100 11546 100 11546 0 0 88637 0 --:--:-- --:--:-- --:--:-- 89503
pi@raspberrypi:~ $
Can someone help me
Many thanks
Starting with domoticz
FreddyAdam
cogliostrio
Re: Starting with domoticz
can your Pi reach the internet?
Try pinging fx domotcz.com.
You should get a reply like this
ping -c 3 domoticz.comCode: Select all
64 bytes from srv20398.flexwebhosting.nl (185.27.142.198): icmp_seq=1 ttl=49 time=24.9 ms-
FreddyAdam
The ping command gave this :
pi@raspberrypi:~ $ ping -c 3 domoticz.com
PING domoticz.com (185.27.142.198) 56(84) bytes of data.
64 bytes from srv20398.flexwebhosting.nl (185.27.142.198): icmp_seq=1 ttl=55 time=23.0 ms
64 bytes from srv20398.flexwebhosting.nl (185.27.142.198): icmp_seq=2 ttl=55 time=21.8 ms
64 bytes from srv20398.flexwebhosting.nl (185.27.142.198): icmp_seq=3 ttl=55 time=20.3 ms
--- domoticz.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 20.369/21.758/23.012/1.083 ms
Beschuitbus
The same here, I can reach domoticz site (ping works)
It looks like there is a bug in the installation file?
altery
Same here. install.domoticz.com seems to return the Domoticz Website instead of the installer. Is the installation scribt available somewhere else? Couldnt find it on github.
altery
Ok, it works when using HTTPS. So instead of the command given in Domoticz Wiki, do this (as root or using sudo):
curl -L https://install.domoticz.com |bash-
FreddyAdam
It works !!!!!!
Many thanks .
Many thanks .
