DomoticaRob
Posts: 80 Joined: Sunday 29 November 2015 14:03
Domoticz version: V4.9700
Post
by DomoticaRob » Saturday 15 December 2018 20:54
I want to make a textfile with all the attributes of a device.
I can print a .dump to the log with:
devices = {
103
execute = function(domoticz, Rob1)
if (Rob1.dump() ~= nil) then
print('Dump: '..Rob1.dump())
I want to iterate through Rob1 and write every item to a textfile.
I know that it must be possible with
forEach
and
file = io.open()
and so on. But, I don't get it working.
I have struggled through a lot of topics and wiki's. I still don't get it.
Please help,
Rob
Posts: 6028 Joined: Tuesday 03 January 2017 14:18
Post
by waaren » Saturday 15 December 2018 21:04
DomoticaRob wrote: I want to make a textfile with all the attributes of a device.
devices = {
103
forEach
and
file = io.open()
Please help,
Rob
If you configure domoticz to log to a file you can copy that file and keep the relevant lines.
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
dzVents wiki
DomoticaRob
Post
by DomoticaRob » Saturday 15 December 2018 22:15
Hey Waaren,
Thanks for your reply.
That is a way. But I want to do it with 'iteratie' and 'file.write' and so on. It is not only for this purpose, but also as learning moment for other situations.
Post
by waaren » Sunday 16 December 2018 12:22
DomoticaRob wrote: Saturday 15 December 2018 22:15
Hey Waaren,
In that case you can use the code below. The dumpTable function used here is almost equal to what dzVents uses internally for the dump command. This and other Lua code snippets can be found in the dzVents/runtime directory
on = { devices = { 103 }},
execute = function(dz, item )
local fileName = "dump" .. item.name .. ".out_" .. os.date("%H%M%S" )
local file = io.open(fileName, "a")
local function dumpTable(t, level)
for attr, value in pairs(t) do
if (type(value) ~= 'function') then
if (type(value) == 'table') then
io.write(level .. attr .. ':\n')
print(level .. attr )
dumpTable(value, level .. ' ')
io.write(level .. attr .. ': ' .. tostring(value) .. "\n")
print(level .. attr .. ': ' .. tostring(value) )
io.write(level .. attr .. '()\n')
print(level .. attr .. '()')
io.output(file)
io.write("-- Start of attributes dump " .. item.name .. "\n")
dumpTable(item,"> ")
io.write("-- End of attributes dump " .. item.name .. " \n")
io.close(file)
dzVents wiki
DomoticaRob
Post
by DomoticaRob » Sunday 16 December 2018 13:36
Super, super, super!
Thank you very much.
I do understand the code.
There is one last issue:
In FileZilla I can't copy the files to my Local site (Nas).
I have tried to change the file attributes. Still no downloading.
I wanted to place the screendumps from FileZilla in this reply, but in the tab Attachments I don't get 'upload file' anymore. Has that to do with the planned relocatoin of the Domoticz forum server?
Post
by waaren » Sunday 16 December 2018 13:47
DomoticaRob wrote: Sunday 16 December 2018 13:36
Sorry no experience with fileZilla. Better to open a new topic for that problem?
For filecopy between RPI's and synology I use rsync and between RPI's and desktop WinSCP
I still see the button Add files but also the error "Sorry, the board attachment quota has been reached." on the yellow triangle with the exclamation mark
dzVents wiki
DomoticaRob
Post
by DomoticaRob » Sunday 16 December 2018 13:49
I see that for these files the owner is: 'root root'.
Other files have as owner: 'pi pi'. These files I can download.
How/where can I change that?
Post
by waaren » Sunday 16 December 2018 14:00
On my system the owner of these files is the user executing the domoticz binary.
To change this give the command
on the OS level
dzVents wiki
DomoticaRob
Post
by DomoticaRob » Wednesday 19 December 2018 20:10
Hey Waaren,
It seems that the code below here has a strange sorting result. If I run the script a few times for the same devide I get every time the same result, but every time in a different sorting order, probably no order at all?
Is there a way in the script that I can sort it?
io.output(file)
io.close(file)
Post
by waaren » Wednesday 19 December 2018 21:26
DomoticaRob wrote: Wednesday 19 December 2018 20:10
It seems that the code below here has a strange sorting result. If I run the script a few times for the same device I get every time the same result, but every time in a different sorting order, probably no order at all?
Lua tables / arrays are unsorted. There is always a way to sort but for the attributes of a device ( effectively a multilevel table ) it is too complicated for my Lua skills.
If you only want to alphabetically sort the file you could use the sort function on the os level. A call to os.execute("sort -b " .. file .. " > " .. file .. "_sorted" ) would do the trick and produce something like below.
Spoiler: show Code: Select all
> 1: 0
> 1: 0
> 1: Switch device adapter
> active: true
> _adapters:
> armAway()
> armHome()
> baseType: device
> baseType: device
> batteryLevel: 255
> bState: true
> cancelQueuedCommands()
> changed: true
> changed: true
> close()
> compare()
> current:
> data:
> _data:
> day: 19
> day: 19
> dayAbbrOfWeek: wed
> daysAgo: 0
> dDate: 1545247583
> decreaseBrightness()
> description: MaxOnTime:60
> deviceId: 011FE0EE
> deviceID: 011FE0EE
> deviceSubType: AC
> deviceType: Light/Switch
> dimTo()
> disarm()
> dump()
> fileExists()
> fromJSON()
> getISO()
> hardwareId: 5
> hardwareID: 5
> hardwareID: 5
> hardwareName: RFLink
> hardwareType: RFLink Gateway USB
> hardwareTypeValue: 46
> hour: 20
> hour: 20
> hoursAgo: 0
> icon: lightbulb
> icon: lightbulb
> idx: 535
> increaseBrightness()
> isDevice: true
> isdst: false
> isdst: false
> isGroup: false
> isHTTPResponse: false
> isScene: false
> isSecurity: false
> isTimer: false
> isToday: true
> isUTC: false
> isVariable: false
> kodiExecuteAddOn()
> kodiPause()
> kodiPlay()
> kodiPlayFavorites()
> kodiPlayPlaylist()
> kodiSetVolume()
> kodiStop()
> kodiSwitchOff()
> lastLevel: 0
> lastLevel: 0
> lastUpdate:
> lastUpdate: 2018-12-19 20:26:23
> level: 0
> levelVal: 0
> levelVal: 0
> log()
> LOG_DEBUG: 4
> LOG_ERROR: 1
> LOG_FORCE: 0.5
> LOG_INFO: 3
> LOG_MODULE_EXEC_INFO: 2
> matchesRule()
> maxDimLevel: 100
> maxDimLevel: 100
> milliseconds: 0
> milliSeconds: 0
> millisecondsAgo: 2053
> min: 26
> min: 26
> minutes: 26
> minutesAgo: 0
> month: 12
> month: 12
> msAgo: 2053
> _nValue: 1
> _nValue: 1
> nValue: 1
> onkyoEISCPCommand()
> open()
> osExecute()
> pause()
> play()
> playFavorites()
> print()
> protected: false
> protected: false
> raw: 2018-12-19 20:26:23
> rawData:
> rawData:
> rawDate: 2018-12-19
> rawTime: 20:26:23
> rgbToHSB()
> ruleIsAfterCivilTwilightEnd()
> ruleIsAfterCivilTwilightStart()
> ruleIsAfterSunrise()
> ruleIsAfterSunset()
> ruleIsAtCivilDayTime()
> ruleIsAtCivilNight()
> ruleIsAtCivilTwilightEnd()
> ruleIsAtCivilTwilightStart()
> ruleIsAtDayTime()
> ruleIsAtNight()
> ruleIsAtSunrise()
> ruleIsAtSunset()
> ruleIsBeforeCivilTwilightEnd()
> ruleIsBeforeCivilTwilightStart()
> ruleIsBeforeSunrise()
> ruleIsBeforeSunset()
> ruleIsInWeek()
> ruleIsOnDate()
> ruleIsOnDay()
> ruleMatchesBetweenRange()
> ruleMatchesHourSpecification()
> ruleMatchesMinuteSpecification()
> ruleMatchesTime()
> ruleMatchesTimeRange()
> sec: 23
> sec: 25
> seconds: 23
> secondsAgo: 2
> secondsSinceMidnight: 73583
> setDiscoMode()
> setHotWater()
> setKelvin()
> setNightMode()
> setRGB()
> setState()
> setVolume()
> setWhiteMode()
> signalLevel: 12
> signalLevel: 12
> startPlaylist()
> _state: On
> _state: On
> state: On
> stop()
> subType: AC
> switchOff()
> switchOn()
> switchSelector()
> switchType: On/Off
> switchType: On/Off
> switchTypeValue: 0
> switchTypeValue: 0
> timedOut: false
> timedOut: false
> toggleSwitch()
> toJSON()
> unit: 12
> unit: 12
> update()
> updateAirQuality()
> updateAlertSensor()
> updateBarometer()
> updateCounter()
> updateCustomSensor()
> updateDistance()
> updateElectricity()
> updateGas()
> updateHumidity()
> updateLux()
> updateMode()
> updateP1()
> updatePercentage()
> updatePressure()
> updateRadiation()
> updateRain()
> updateSetPoint()
> updateSoilMoisture()
> updateSoundLevel()
> updateTempBaro()
> updateTemperature()
> updateTempHum()
> updateTempHumBaro()
> updateText()
> updateUV()
> updateVisibility()
> updateVoltage()
> updateWaterflow()
> updateWeight()
> updateWetness()
> updateWind()
> updateYouless()
> urlEncode()
> usedByCamera: false
> usedByCamera: false
> utils:
> wday: 4
> wday: 4
> week: 51
> yday: 353
> yday: 353
> year: 2018
> year: 2018
dzVents wiki
DomoticaRob
Post
by DomoticaRob » Wednesday 19 December 2018 22:23
Can I just place:
os.execute("sort -b " .. fileName .. " > " .. fileName.. "_sorted")
at the end of my script, or must it be something like:
local result = os.execute("sort -b " .. fileName .. " > " .. fileName.. "_sorted")
Post
by waaren » Wednesday 19 December 2018 22:56
DomoticaRob wrote: Wednesday 19 December 2018 22:23
Can I just place:
Both will work. If you don't want to do something with the result then it makes not much sense to store the result in this var.
dzVents wiki
DomoticaRob
Post
by DomoticaRob » Thursday 20 December 2018 19:58
Thanks Waaren,
It works. The only problem is that the attributes and the tables will be mixed up.
I'm gonna make a macro in Excel to do this job for me.
Finally I want to have a Excel file with all my devices with all the attributes.
