I use blocky to send me a notification through pushover each morning with the actual temperature and humidity outside....
But I would send me also a notification with the lowest and highest temperature and humidity of the last 24 hours...
Could you help me?
Calculation of the Lowest and the Highest Sensor values
- waaren
Re: Calculation of the Lowest and the Highest Sensor values
I don't think you can use Blockly to do this. It will require a call to the domoticz API like
http://<domoticzIP>:<domoticzPort/json.htm?idx=<IDX of your device>&range=day&sensor=temp&type=graph
And process the results. It can be done in Lua, dzVents or Python.
thanks...
some example in lua , dzevent or python ?
- waaren
in dzVents it would look like
-- getMaxTempHum
local httpResponses = "getMaxTempHum"
timer = { "at 19:35" }, -- Your preferred time
httpResponses = { httpResponses }
logging = {
level = domoticz.LOG_ERROR,
marker = httpResponse
execute = function(dz, item)
-- ****************************** Your settings below this line ***************************************************
temphumDevice = dz.devices(766) -- Replace with ID of Device you want to be notified on
-- ****************************** No changes required below this line *********************************************
local extremes = {}
local function logWrite(str,level)
dz.log(tostring(str),level or dz.LOG_DEBUG)
local function triggerJSON()
local URLString = dz.settings['Domoticz url'] .. "/json.htm?type=graph&sensor=temp&range=day&idx=" .. temphumDevice.id
dz.openURL({ url = URLString,
method = "GET",
callback = httpResponses })
local function convertTime(timeString) -- based on incoming format yyyy-mm-dd hh:mm
local year, month, day, hour, minute
_,_, year, month, day, hour, minute = string.find(timeString, "(%d+)-(%d+)-(%d+) (%d+):(%d+)")
fmtString = os.date("%A, %d %B %Y (%H:%M)",os.time({year=year, month=month, day=day, hour=hour, minute=minute })):gsub(" 0"," ")
logWrite(fmtString)
return fmtString -- outgoing format: ddd d mmmm yyyy (hh:mm)
local function showResult(str)
textDevice.updateText(str)
logWrite(str,dz.LOG_FORCE)
local function getTimeWindow(hours)
local to = os.time(os.date("*t"))
local from = os.date("%A, %d %B %Y (%H:%M)",to - hours * 3600)
local to = os.date("%A, %d %B %Y (%H:%M)",to)
return to, from
local function notify(from,now)
local notificationString = "\nhigh Temperature: " .. extremes.high.temperature .. " Celsius at " .. convertTime(extremes.high.tTime) .. "\n"
notificationString = notificationString .. "low temperature: " .. extremes.low.temperature .. " Celsius at " .. convertTime(extremes.low.tTime) .. "\n"
notificationString = notificationString .. "high humidity: " .. extremes.high.humidity .. "% at " .. convertTime(extremes.high.hTime) .. "\n"
notificationString = notificationString .. "low humidity: " .. extremes.low.humidity .. "% at " .. convertTime(extremes.low.hTime)
logWrite("\nExtremes between " .. from .. " and " .. now .. "\n" .. notificationString,dz.LOG_FORCE)
dz.notify("Extremes between " .. from .. " and " .. now, notificationString, dz.PRIORITY_NORMAL, nil,nil, dz.NSS_PUSHOVER )
local function getExtremes(rt)
extremes.low = {}
extremes.high = {}
extremes.low.temperature = 10000
extremes.low.humidity = 100
extremes.high.humidity = 0
extremes.high.temperature = -256
for key in ipairs(rt) do
if tonumber(rt[key].hu) > extremes.high.humidity then
logWrite("New max humidity found on " .. convertTime(rt[key].d) .. " ==>> " .. rt[key].hu )
extremes.high.humidity = tonumber(rt[key].hu)
extremes.high.hTime = rt[key].d
if tonumber(rt[key].hu) < extremes.low.humidity then
logWrite("New min humidity found on " .. convertTime(rt[key].d) .. " ==>> " .. rt[key].hu )
extremes.low.humidity = tonumber(rt[key].hu)
extremes.low.hTime = rt[key].d
if tonumber(rt[key].te) > extremes.high.temperature then
logWrite("New max temperature found on " .. convertTime(rt[key].d) .. " ==>> " .. rt[key].te )
extremes.high.temperature = tonumber(rt[key].te)
extremes.high.tTime = rt[key].d
if tonumber(rt[key].te) < extremes.low.temperature then
logWrite("New min temperature found on " .. convertTime(rt[key].d) .. " ==>> " .. rt[key].te )
extremes.low.temperature = tonumber(rt[key].te)
extremes.low.tTime = rt[key].d
return extremes
-- Main
if not item.isHTTPResponse then
triggerJSON()
elseif item.ok then -- statusCode == 2xx
extremes = getExtremes(item.json.result)
notify(getTimeWindow(24))
logWrite("Could not get (good) data from domoticz. Error (" .. (item.statusCode or 999) .. ")" ,dz.LOG_ERROR)
logWrite(item.data)
hi
thanks for your help...
Under Domoticz --> event --> DZvent i have pasted (and modified with my idx and timer)
I have saved and Enabled the script but at 11:20 I haven't seen any info about MAxtemp... the log only show
EventSystem: reset all events...
EventSystem: Write file: /home/ubuntu/domoticz/scripts/dzVents/generated_scripts/GETMAXTEMP.lua
-- getMaxTempHum
timer = { "at 11:20" }, -- Your preferred time
logging = {
temphumDevice = dz.devices(315) -- Replace with ID of Device you want to be notified on
local extremes = {}
method = "GET",
logWrite(fmtString)
return to, from
extremes.low = {}
extremes.high = {}
return extremes
-- Main
triggerJSON()
logWrite(item.data)
I found this script excellent. Thanks waaren!
@ayamy I had the trigger type as HTTP request, then it worked fine.
- Egregius
- Domoticz version: v2024.7
You forgot PHP
I always find it amazing how much code is needed in lua to achive something this simple
In php only 1/10 of code is needed:
$since=strftime("%F", time()-86400);
$sql="SELECT device, min(status) as min, max(status) as max FROM log WHERE (device = 'buiten_temp' OR device = 'humidity') AND timestamp > '$since' GROUP BY device;";
if (!$result=$db->query($sql)) {
die('There was an error running the query ['.$sql.' - '.$db->error.']');
while ($row = $result->fetch(PDO::FETCH_ASSOC)) {
$data[$row['device']]['min']=$row['min'];
$data[$row['device']]['max']=$row['max'];
telegram('Temperature last 24 hours: min='.$data['buiten_temp']['min'].', max='.$data['buiten_temp']['max'].'. Humidity: min='.$data['humidity']['min'].', max='.$data['humidity']['min'].'.');
- waaren
Sorry, I am just not smart enough to understand PHP. Please forgive me my ignorance.
