I have a problem with RFLink
When I use Domoticz dzVents script the LED lights aren't switch on and off, but when I use the Domotiz GUI, they do.
I turned on Debug in RFLink but from a loggin POV it seems to work fine. But in real live it doesn't. the LED leds are only switched on when I use the Domoticz GUI.
I have a thread below where the whole dzVents script is reviewed and it seems that its not dzVends
viewtopic.php?f=59&t=25899&p=199254#p199038
Is there a way to have a even more detailed log, or can you look at the thread above. I'm realy stuck and don't know what to do.
Edwin
RFLink does not work in combo with dzVents script
egrootoonk
- Domoticz version: V4.10233
egrootoonk
Re: RFLink does not work in combo with dzVents script
I think is a bug.
I had to add a .afterSEc(1) to the switchOn() in order to make it work.
It seems to a bug to me. Apperently the PIR sends multiple time the ON signal when it's triggered and the RFLink gateway can't handle it.
on = { devices = { "PIR" }},
execute = function(domoticz, switch)
if switch.active then
domoticz.devices(73).switchOn().checkFirst().afterSec(1)
domoticz.devices(73).switchOff().checkFirst().afterSec(10)
