Store variable in script
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
I have a script that now work with user variables. But its only needed for the script.
Can i store variable into script so it will update when needed and not update all the time into dB?
I have VarKodiStop and VarKodiPlay
When there is a action it update this variable otherwise it will go into a loop.
Want move those 2 into the script.
local Version = '18.12.03'
    active = true,
	    devices = {[KodiStatus] = { 'at nighttime' }},
	-- logging = {marker = 'KODI Control ' ..Version..'...........'},
-- KODI PAUZE
    if (domoticz.devices(SceneMovie).active and domoticz.devices(LogitechKodi).active) then
        if (domoticz.devices(KodiStatus).state == 'Paused') then
            domoticz.variables(VarKodiStop).set(0)
            domoticz.variables(VarKodiPlay).set(0)
            -- HALLOWEEN
            if (domoticz.time.matchesRule 'on 23/10-04/11') then
                domoticz.devices(BulbLivingroomAll).dimTo(100)
            -- X-MAS
            elseif (domoticz.time.matchesRule 'on 01/12-31/12') then
            -- NORMAL
            -- SENSOR DINING ROOM ON
            if (domoticz.devices(SensorDiningRoomDoor).active) then
                domoticz.helpers.Off(domoticz,BulbDressoirAll,nil,nil,nil)
            -- SENSOR DINING ROOM OFF
            elseif (not domoticz.devices(SensorDiningRoomDoor).active) then
                -- HALLOWEEN
                    domoticz.devices(BulbDressoirAll).dimTo(100)
                -- X-MAS
                elseif (domoticz.time.matchesRule 'on 20/12-31/12') then
                -- NORMAL
            domoticz.devices(BulbBalcony1).dimTo(100)
            domoticz.devices(BulbToiletAll).dimTo(100)
            domoticz.devices(BulbKitchenSinkAll).dimTo(100)
            domoticz.devices(BulbKitchenAll).dimTo(100)
            os.execute('/home/pi/domoticz/scripts/Peter/Nanoleaf/nano.sh -b 50 &')
            -- domoticz.log('------------------------==<[ KODI STAAT OP PAUZE ]>==-----------------------', domoticz.LOG_FORCE)
-- KODI VIDEO
        elseif (domoticz.devices(KodiStatus).state  == 'Video' and domoticz.variables(VarKodiPlay).value == 0) then
            domoticz.variables(VarKodiPlay).set(1)
            -- HALLOWEEN
                domoticz.devices(BulbLivingroomWall).dimTo(70)
                domoticz.devices(BulbLivingroomWindow).dimTo(20)
            -- X-MAS
            -- NORMAL
                -- HALLOWEEN
                    domoticz.devices(BulbDressoirAll).dimTo(25)
                -- X-MAS
                -- NORMAL
            domoticz.helpers.Off(domoticz,BulbKitchenSinkAll,nil,nil)
            domoticz.helpers.Off(domoticz,BulbKitchenAll,nil,nil)
            domoticz.helpers.Off(domoticz,BulbToiletAll,nil,nil)
            domoticz.helpers.RGB(domoticz,BulbBalcony1,25,'Blue',nil)
            os.execute('/home/pi/domoticz/scripts/Peter/Nanoleaf/nano.sh -b 10 &')
            -- domoticz.log('------------------------==<[ KODI IS FILM AAN AFSPELEN ]>==-----------------', domoticz.LOG_FORCE)
-- KODI TV SHOW
        elseif (domoticz.devices(KodiStatus).state  == 'TV Shows' and domoticz.variables(VarKodiPlay).value == 0)
        then
            -- HALLOWEEN
                domoticz.devices(BulbLivingroomWindow).dimTo(50)
            -- X-MAS
            -- NORMAL
                -- HALLOWEEN
                -- X-MAS
                -- NORMAL
            -- domoticz.log('------------------------==<[ KODI IS SERIE AAN AFSPELEN ]>==----------------', domoticz.LOG_FORCE)
-- KODI SPEELT NIKS
        elseif (domoticz.devices(KodiStatus).state  == 'On')
        then
            domoticz.variables(VarKodiStop).set(1)
            -- HALLOWEEN
            -- X-MAS
            -- NORMAL
                -- HALLOWEEN
                -- X-MAS
                -- NORMAL
            domoticz.helpers.RGB(domoticz,BulbBalcony1,75,'Blue',nil)
            -- domoticz.log('------------------------==<[ KODI SPEELT NIKS AF ]>==-----------------------', domoticz.LOG_FORCE)
emme
Domoticz version: latest
Re: Store variable in script
Post by emme »
you can use data section into your script
have a look at the wiki:
https://www.domoticz.com/wiki/DzVents:_ ... ptional.29
"We always done this way"
poudenes wrote: Monday 03 December 2018 16:51 I have a script that now work with user variables. But its only needed for the script.
It can be done like the example below but be aware that when you change the state or dimlevel of a device then this wil also be send to the database.
    active = true,
      data        =   {     KodiStop        =   { initial = 0     },
                            KodiPlay        =   { initial = 0     },
        local function setStopPlay(stop,play)
            domoticz.data.KodiStop) = stop
            domoticz.data.KodiPlay) = play
            -- KODI PAUZE
            setStopPlay(0,0)
            -- HALLOWEEN
            -- X-MAS
            -- NORMAL
                -- HALLOWEEN
                -- X-MAS
                -- NORMAL
-- KODI VIDEO
        elseif (domoticz.devices(KodiStatus).state  == 'Video' and domoticz.data.KodiPlay == 0) then
            setStopPlay(0,1)
            -- HALLOWEEN
            -- X-MAS
            -- NORMAL
                -- HALLOWEEN
                -- X-MAS
                -- NORMAL
-- KODI TV SHOW
        elseif (domoticz.devices(KodiStatus).state  == 'TV Shows' and domoticz.data.KodiPlay == 0)
        then
            setStopPlay(0,1)
            -- HALLOWEEN
            -- X-MAS
            -- NORMAL
                -- HALLOWEEN
                -- X-MAS
                -- NORMAL
-- KODI SPEELT NIKS
        then
            setStopPlay(1,0)
            -- HALLOWEEN
            -- X-MAS
            -- NORMAL
                -- HALLOWEEN
                -- X-MAS
                -- NORMAL
poudenes
Post by poudenes »
Thanks Waaren. I will look into the script to understand the way of work :D
waaren wrote: Monday 03 December 2018 18:47
    active = true,
            -- KODI PAUZE
            setStopPlay(0,0)
            -- HALLOWEEN
            -- X-MAS
            -- NORMAL
                -- HALLOWEEN
                -- X-MAS
                -- NORMAL
-- KODI VIDEO
            setStopPlay(0,1)
            -- HALLOWEEN
            -- X-MAS
            -- NORMAL
                -- HALLOWEEN
                -- X-MAS
                -- NORMAL
-- KODI TV SHOW
        then
            setStopPlay(0,1)
            -- HALLOWEEN
            -- X-MAS
            -- NORMAL
                -- HALLOWEEN
                -- X-MAS
                -- NORMAL
-- KODI SPEELT NIKS
        then
            setStopPlay(1,0)
            -- HALLOWEEN
            -- X-MAS
            -- NORMAL
                -- HALLOWEEN
                -- X-MAS
                -- NORMAL
poudenes
Post by poudenes »
Hi All,
Can I also change these variables from other scripts?
