I wrote a small script to set my fan.
in DzVents I can switch the "slider" on and off by :
domoticz.devices('Ventilator').switchOn()
But setting the slider to a percentage :
domoticz.devices('Ventilator').dimTo(35)
Doesn't work. I doesn't give an error, but no updates to the slider.
Any clue ?
dimTo doesn't work ? (Bug ?)
- Domoticz version: V4.1174
Raspberry PI 3 - Opentherm Gateway + ESP8826 - EvoHome - ESPEasy CO2 + Fancontrol - RF-Link - zigbee2mqqt -
- waaren
Re: dimTo doesn't work ? (Bug ?)
Can you enter this in your script and show us the loglines ? That might help to understand what happens.
domoticz.devices('Ventilator').dump()
Please see below :
Seems the value sticks to 100%...?
018-12-02 22:28:00.177 Status: dzVents: > idx: 208
2018-12-02 22:28:00.177 Status: dzVents: > kodiSwitchOff()
2018-12-02 22:28:00.177 Status: dzVents: > kodiPause()
2018-12-02 22:28:00.177 Status: dzVents: > updateWeight()
2018-12-02 22:28:00.177 Status: dzVents: > updateAirQuality()
2018-12-02 22:28:00.177 Status: dzVents: > isVariable: false
2018-12-02 22:28:00.177 Status: dzVents: > isTimer: false
2018-12-02 22:28:00.177 Status: dzVents: > updateUV()
2018-12-02 22:28:00.177 Status: dzVents: > kodiExecuteAddOn()
2018-12-02 22:28:00.177 Status: dzVents: > icon: dimmer
2018-12-02 22:28:00.177 Status: dzVents: > updateVisibility()
2018-12-02 22:28:00.177 Status: dzVents: > kodiPlay()
2018-12-02 22:28:00.177 Status: dzVents: > updateTempHum()
2018-12-02 22:28:00.177 Status: dzVents: > pause()
2018-12-02 22:28:00.177 Status: dzVents: > updateTempBaro()
2018-12-02 22:28:00.177 Status: dzVents: > updateSoundLevel()
2018-12-02 22:28:00.177 Status: dzVents: > updateDistance()
2018-12-02 22:28:00.177 Status: dzVents: > updateSoilMoisture()
2018-12-02 22:28:00.177 Status: dzVents: > updateGas()
2018-12-02 22:28:00.177 Status: dzVents: > _data:
2018-12-02 22:28:00.177 Status: dzVents: > switchTypeValue: 7
2018-12-02 22:28:00.177 Status: dzVents: > description:
2018-12-02 22:28:00.177 Status: dzVents: > switchType: Dimmer
2018-12-02 22:28:00.177 Status: dzVents: > deviceType: Light/Switch
2018-12-02 22:28:00.178 Status: dzVents: > batteryLevel: 255
2018-12-02 22:28:00.178 Status: dzVents: > signalLevel: 12
2018-12-02 22:28:00.178 Status: dzVents: > lastLevel: 100
2018-12-02 22:28:00.178 Status: dzVents: > lastUpdate: 2018-12-02 22:27:00
2018-12-02 22:28:00.178 Status: dzVents: > changed: false
2018-12-02 22:28:00.178 Status: dzVents: > rawData:
2018-12-02 22:28:00.178 Status: dzVents: > 1: 100
2018-12-02 22:28:00.178 Status: dzVents: > subType: Switch
2018-12-02 22:28:00.178 Status: dzVents: > deviceID: 00014120
2018-12-02 22:28:00.178 Status: dzVents: > name: Ventilator
2018-12-02 22:28:00.178 Status: dzVents: > timedOut: false
2018-12-02 22:28:00.178 Status: dzVents: > baseType: device
2018-12-02 22:28:00.178 Status: dzVents: > data:
2018-12-02 22:28:00.178 Status: dzVents: > _state: On
2018-12-02 22:28:00.178 Status: dzVents: > usedByCamera: false
2018-12-02 22:28:00.178 Status: dzVents: > protected: false
2018-12-02 22:28:00.178 Status: dzVents: > icon: dimmer
2018-12-02 22:28:00.178 Status: dzVents: > unit: 1
2018-12-02 22:28:00.178 Status: dzVents: > levelVal: 100
2018-12-02 22:28:00.178 Status: dzVents: > _nValue: 1
2018-12-02 22:28:00.178 Status: dzVents: > hardwareType: Dummy (Does nothing, use for virtual switches only)
2018-12-02 22:28:00.178 Status: dzVents: > hardwareTypeValue: 15
2018-12-02 22:28:00.178 Status: dzVents: > hardwareName: Dummy_var
2018-12-02 22:28:00.178 Status: dzVents: > maxDimLevel: 100
2018-12-02 22:28:00.178 Status: dzVents: > hardwareID: 10
2018-12-02 22:28:00.178 Status: dzVents: > id: 208
2018-12-02 22:28:00.178 Status: dzVents: > cancelQueuedCommands()
2018-12-02 22:28:00.178 Status: dzVents: > setDiscoMode()
2018-12-02 22:28:00.178 Status: dzVents: > isHTTPResponse: false
2018-12-02 22:28:00.178 Status: dzVents: > nValue: 1
2018-12-02 22:28:00.178 Status: dzVents: > setKelvin()
2018-12-02 22:28:00.178 Status: dzVents: > updatePressure()
2018-12-02 22:28:00.178 Status: dzVents: > decreaseBrightness()
2018-12-02 22:28:00.178 Status: dzVents: > armAway()
2018-12-02 22:28:00.178 Status: dzVents: > updateBarometer()
2018-12-02 22:28:00.179 Status: dzVents: > hardwareID: 10
2018-12-02 22:28:00.179 Status: dzVents: > disarm()
2018-12-02 22:28:00.179 Status: dzVents: > updatePercentage()
2018-12-02 22:28:00.179 Status: dzVents: > updateRain()
2018-12-02 22:28:00.179 Status: dzVents: > setNightMode()
2018-12-02 22:28:00.179 Status: dzVents: > increaseBrightness()
2018-12-02 22:28:00.179 Status: dzVents: > updateSetPoint()
2018-12-02 22:28:00.179 Status: dzVents: > updateP1()
2018-12-02 22:28:00.179 Status: dzVents: > isSecurity: false
2018-12-02 22:28:00.179 Status: dzVents: > update()
2018-12-02 22:28:00.179 Status: dzVents: > hardwareId: 10
2018-12-02 22:28:00.179 Status: dzVents: > hardwareTypeValue: 15
2018-12-02 22:28:00.179 Status: dzVents: > startPlaylist()
2018-12-02 22:28:00.179 Status: dzVents: > armHome()
2018-12-02 22:28:00.179 Status: dzVents: > updateWind()
2018-12-02 22:28:00.179 Status: dzVents: > active: true
2018-12-02 22:28:00.179 Status: dzVents: > changed: false
2018-12-02 22:28:00.179 Status: dzVents: > playFavorites()
2018-12-02 22:28:00.179 Status: dzVents: > setVolume()
2018-12-02 22:28:00.179 Status: dzVents: > hardwareName: Dummy_var
2018-12-02 22:28:00.179 Status: dzVents: > rawData:
2018-12-02 22:28:00.179 Status: dzVents: > 1: 100
2018-12-02 22:28:00.179 Status: dzVents: > switchOff()
2018-12-02 22:28:00.179 Status: dzVents: > isGroup: false
2018-12-02 22:28:00.179 Status: dzVents: > updateWetness()
2018-12-02 22:28:00.179 Status: dzVents: > levelVal: 100
2018-12-02 22:28:00.179 Status: dzVents: > updateRadiation()
2018-12-02 22:28:00.179 Status: dzVents: > setRGB()
2018-12-02 22:28:00.179 Status: dzVents: > updateCounter()
2018-12-02 22:28:00.179 Status: dzVents: > id: 208
2018-12-02 22:28:00.179 Status: dzVents: > description:
2018-12-02 22:28:00.179 Status: dzVents: > stop()
- waaren
I don't see all the values I expected in the dump. Some lines seem to be missing.
As alternative can you merge this into your script and change the 250 to the device IDX of your dimmer
logging = { level = domoticz.LOG_DEBUG,
marker = 'Dumper'
local dimmer = domoticz.devices(250)
domoticz.log("dimmer.deviceType : " .. tostring(dimmer.deviceType) ,domoticz.log_DEBUG)
domoticz.log("dimmer.switchType : " .. tostring(dimmer.switchType) ,domoticz.log_DEBUG)
domoticz.log("dimmer.maxDimLevel : " .. tostring(dimmer.maxDimLevel) ,domoticz.log_DEBUG)
domoticz.log("dimmer.lastLevel : " .. tostring(dimmer.lastLevel) ,domoticz.log_DEBUG)
domoticz.log("dimmer._adapters[1] : " .. tostring(dimmer._adapters[1]) ,domoticz.log_DEBUG)
domoticz.log("dimmer._adapters[2] : " .. tostring(dimmer._adapters[2]) ,domoticz.log_DEBUG)
domoticz.log("dimmer.hardwareTypeValue: " .. tostring(dimmer.hardwareTypeValue),domoticz.log_DEBUG)
domoticz.log("dimmer.switchTypeValue : " .. tostring(dimmer.switchTypeValue) ,domoticz.log_DEBUG)
Can you show us your complete script and the loglines of it ?
Best is to see the log from the command-line as the web version of the log (in the GUI) seems to miss entries every now and then.
Figured it out.. silly one.. i guess..
execute = function(domoticz,Ventilator) didn't add Ventilator here...
After adding all works likes expected....
But still wondering why domoticz.devices('Ventilator').switchOn() works..
and domoticz.devices('Ventilator').dimTo(35) not ?
