Hmm, that's the same I got and it is working for me now. Did you restart domoticz `sudo service domoticz.sh restart`? And which URL did you set in the plugin settings? Do you run the latest version of the plugin?
Python Plugin: Chromecast Topic is solved
Re: Python Plugin: Chromecast
- Domoticz version: 4.10159
wow, i've reinstalled plugin and now it's ok! no errors!
Edit
I've other chromecast, i try to add anorther chromecast and this is the log error:
EDIT
okk, i can add 1 plugin and i put the names into Chromecast name(s), but GOOGLE HOME MINI status is not update
Issues: into group (1 group with 1 chromecast and google mini)volume are not updated, google mini status not updated (no log errors)
Edit
2018-11-25 11:20:04.952 Error: (Chromecast) failed to load 'plugin.py', Python Path used was '/home/x/domoticz/plugins/ChromecastPlugin/:/usr/lib/python36.zip:/usr/lib/python3.6:/usr/lib/python3.6:/usr/lib/python3.6/lib-dynload'.
2018-11-25 11:20:04.952 Error: (Chromecast 2) Module Import failed, exception: 'TypeError'
2018-11-25 11:20:04.952 Error: (Chromecast 2) Error Line details not available.
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
That's negative..
5 google minis are updated just fine at my place.
Spoken text work's fine too..
Regards, Hans
Regards, Hans
- EdwinK
- Domoticz version: BETA
Two Chromecast's and two mini's working (at least, devices are created).
yes, try it into a group and tell me
1x Fibaro Wall Plug
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
Good evening... I like the plugin very much but ran into a few things.
Voice on a group works, but they dont start at the same time... the first Mini starts.. the second follows a few seconds later, but somewhere in the middle of the text...
and... I ran into the max size of the variable ... my goodmorning script can generate a pretty long variable, with weather, Traffic, Birthdays, News, Garbage, etc ..its not played...
regards, Hans
regards, Hans
I have just release version 2.0.0.
It now auto resumes youtube when that what was playing before a message was played.
- EdwinK
Getting this in the error log.
2018-11-27 09:48:54.291 Error: (PyCast) Error on line 264 Error is 'result'
2018-11-27 09:48:54.313 Error: (PyCast) Error on line 264 Error is 'result'
2018-11-27 09:48:54.325 Error: (PyCast) Error on line 264 Error is 'result'
2018-11-27 09:48:54.337 Error: (PyCast) Error on line 264 Error is 'result'
I've upgraded to the latest version and it works fine now with my 15 devices or so. I copied the logging where it said "(Chromecast) Found these chromecasts: Living Room display, Attic, etc." to the hardware settings.
Personally I wouldn't mind the plugin to just create devices for all devices found. You don't have to show the devices if you don't want to anyway.
Thanks for the great work!
Currently I'm investigating how to notify to the cast devices. For instance I would like to cast if the garage door is left open. Any suggestions what the best approach would be?
Thanks for the plugin! Seems to work (I'm not using the notification, at least so far) but the only thing I wonder is why I get this in my log:
Variable is created so not sure what is missing...
.../json.htm?type=command¶m=getuservariable&idx= did not return any results.
Very nice plugin, but I ran into the max.size of the variable.
Is there something to do about this?
Regards, Hans
2018-12-02 16:56:11.922 Error: EventSystem: Error updating variable Living Room speaker: String exceeds maximum size
Regards, Hans
I just have released version 3.0.1.
You can now update the hardware without the need to restart domoticz.
Devices which are no longer needed are automatically deleted
After re-installing the plugin I get this error:
2018-12-11 07:03:36.189 Error: (Chromecast) 'onCommand' failed 'NameError'.
2018-12-11 07:03:36.189 Error: (Chromecast) ----> Line 570 in '/home/pi/domoticz/plugins/ChromecastPlugin/plugin.py', function onCommand
2018-12-11 07:03:36.189 Error: (Chromecast) ----> Line 415 in '/home/pi/domoticz/plugins/ChromecastPlugin/plugin.py', function onCommand
Any idea how to solve this?
Thanks for the help!
Kind regards, Rob
Kind regards, Rob
Any ideas about this:Ewaldharmsen wrote: ↑Monday 10 December 2018 14:23 I just have released version 3.0.1.
Still seeing it also with the new version.Nautilus wrote: ↑Sunday 02 December 2018 9:59 Thanks for the plugin! Seems to work (I'm not using the notification, at least so far) but the only thing I wonder is why I get this in my log:Variable is created so not sure what is missing...Code: Select all
Last edited by Nautilus on Tuesday 11 December 2018 23:03, edited 2 times in total.
- EdwinK
2018-12-11 09:28:57.518 Error: (PyCast) http://192.168.0.11:8080/json.htm?type=command¶m=getuservariable&idx= did not return any results.
2018-12-11 09:28:57.540 Error: (PyCast) http://192.168.0.11:8080/json.htm?type=command¶m=getuservariable&idx= did not return any results.
2018-12-11 09:28:57.561 Error: (PyCast) http://192.168.0.11:8080/json.htm?type=command¶m=getuservariable&idx= did not return any results.
2018-12-11 09:28:57.585 Error: (PyCast) http://192.168.0.11:8080/json.htm?type=command¶m=getuservariable&idx= did not return any results.
Thats a bug, can you update to version 3.0.2?schulpr wrote: ↑Tuesday 11 December 2018 7:06 Hi,
Kind regards, Rob
Should be solved.
Can you remove the hardware, and all user variables, restart domoticz and re-add it?EdwinK wrote: ↑Tuesday 11 December 2018 9:29Code: Select all
2018-12-11 09:28:57.518 Error: (PyCast) http://192.168.0.11:8080/json.htm?type=command¶m=getuservariable&idx= did not return any results. 2018-12-11 09:28:57.540 Error: (PyCast) http://192.168.0.11:8080/json.htm?type=command¶m=getuservariable&idx= did not return any results. 2018-12-11 09:28:57.561 Error: (PyCast) http://192.168.0.11:8080/json.htm?type=command¶m=getuservariable&idx= did not return any results. 2018-12-11 09:28:57.585 Error: (PyCast) http://192.168.0.11:8080/json.htm?type=command¶m=getuservariable&idx= did not return any results.
After update to 3.02 a new error occured:
2018-12-12 10:03:50.208 Error: (Chromecast) failed to load 'plugin.py', Python Path used was ':/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-12-12 10:03:50.208 Error: (Chromecast) Module Import failed, exception: 'SyntaxError'
2018-12-12 10:03:50.208 Error: (Chromecast) Import detail: File: /home/pi/domoticz/plugin.py, Line: 7, offset: 1
2018-12-12 10:03:50.208 Error: (Chromecast) Error Line '<!DOCTYPE html>
2018-12-12 10:03:50.208 '
Is it also possible to update with 'git pull ChromecastPlugin' or something like this?
Kind regards, Rob
Kind regards, Rob
Thanks, tried this but now I'm not getting any devices created. Allow new hardware devices was on when I re-added it:Ewaldharmsen wrote: ↑Wednesday 12 December 2018 9:19Can you remove the hardware, and all user variables, restart domoticz and re-add it?EdwinK wrote: ↑Tuesday 11 December 2018 9:29Code: Select all
2018-12-12 23:46:48.500 Status: (Chromecasts) Started.
2018-12-12 23:46:50.220 Status: (Chromecasts) Entering work loop.
2018-12-12 23:46:50.220 Status: (Chromecasts) Initialized version 3.0.2, author 'Tsjippy'
2018-12-12 23:46:50.223 Status: (Chromecasts) Checking if images are loaded
2018-12-12 23:46:50.223 Status: (Chromecasts) Starting up
2018-12-12 23:46:50.242 Error: (Chromecasts) 'onStart' failed 'ConnectionError'.
2018-12-12 23:46:50.242 Error: (Chromecasts) ----> Line 560 in '/home/pi/domoticz/plugins/ChromecastPlugin/plugin.py', function onStart
2018-12-12 23:46:50.242 Error: (Chromecasts) ----> Line 272 in '/home/pi/domoticz/plugins/ChromecastPlugin/plugin.py', function onStart
2018-12-12 23:46:50.242 Error: (Chromecasts) ----> Line 502 in '/home/pi/domoticz/plugins/ChromecastPlugin/plugin.py', function updateDevices
2018-12-12 23:46:50.242 Error: (Chromecasts) ----> Line 75 in '/home/pi/domoticz/plugins/ChromecastPlugin/requests/api.py', function get
2018-12-12 23:46:50.242 Error: (Chromecasts) ----> Line 60 in '/home/pi/domoticz/plugins/ChromecastPlugin/requests/api.py', function request
2018-12-12 23:46:50.242 Error: (Chromecasts) ----> Line 533 in '/home/pi/domoticz/plugins/ChromecastPlugin/requests/sessions.py', function request
2018-12-12 23:46:50.242 Error: (Chromecasts) ----> Line 646 in '/home/pi/domoticz/plugins/ChromecastPlugin/requests/sessions.py', function send
2018-12-12 23:46:50.242 Error: (Chromecasts) ----> Line 516 in '/home/pi/domoticz/plugins/ChromecastPlugin/requests/adapters.py', function send
2018-12-12 23:47:02.580 Error: (Chromecasts) http://127.0.0.1:8080/json.htm?type=command¶m=getuservariable&idx= did not return any results.
2018-12-12 23:47:12.805 (Chromecasts) Connecting to available chromecasts
2018-12-12 23:47:12.805 Status: (Chromecasts) Checking for available chromecasts
2018-12-12 23:47:21.791 (Chromecasts) Found these chromecasts: Musiikkihuone TV
2018-12-12 23:47:21.792 (Chromecasts) Registering listeners for Musiikkihuone TV
2018-12-12 23:47:21.792 (Chromecasts) Done registering listeners for Musiikkihuone TV
2018-12-12 23:47:21.836 (Chromecasts) The app of 'Musiikkihuone TV' has changed to Backdrop
2018-12-12 23:47:21.836 (Chromecasts) Will set the domoticz devices to off.
2018-12-12 23:47:21.836 (Chromecasts) Updated volume to 50
2018-12-12 23:47:21.792 Status: (Chromecasts) Connected to Musiikkihuone TV
2018-12-12 23:47:31.337 Error: (Chromecasts) http://127.0.0.1:8080/json.htm?type=command¶m=getuservariable&idx= did not return any results.
2018-12-12 23:47:41.323 Error: (Chromecasts) http://127.0.0.1:8080/json.htm?type=command¶m=getuservariable&idx= did not return any results.
