"Connection" issue between Dashticz and Domoticz
Hi All
Just playing with Dashticz and have a NOOB question.
var config = {}
config['domoticz_ip'] = 'http://192.168.0.134:8080';
config['app_title'] = 'Sprøjtehusstræde';
This is my config ,and there is no communication between dashticz and domoticz.
Dashtica is asking me to check connection.
And i can see that no Domoticz info is in Dashticz,so i must have an connection error.
I am pretty sure ip and port is correct.
What have i forgot ?
and btw i can not acces setting on ipad either . "Wheel button" is "dead".is that normal ?
var config = {}
- EdwinK
- Domoticz version: BETA
Re: "Connection" issue between Dashticz and Domoticz
Do you have a username/password set?
I have now set a Login and password.
I realise that i have not set which Domoticz IDX needs to be shown.
And cannot seem to find the correct syntax for intering Domoticz IDX.
- mAiden88
- Domoticz version: 3.7286
Several questions for you, to make it clear to myself.
1): What url do you call, when you try go to dashticz?
I do not see any crazy things in your config. Can also be located elsewhere in the config.. Post your complete config is without passwords.
Anyone can build a fast processor. The trick is to build a fast system.
Hi guys
thx you for trying to help out a NOOB.
http://192.168.0.134:8080/dashticz_v2/
Just to expand info as much as possible ,to make my babling make some sence.
I can acces dashticz ,and it "works" showing local weather and stuf ,but do not get any info from Domoticz.
i was wondering how it knows what to "import. Maybe answer is it just everything ,but i have 170 ative ,swithes ,scenes to imports, Can it handle that without specifying more pages or anything.
I have played with dashticz earlier where i got it to import.at that point i needed to specify more specifically w9hat to import to get it in.I cant do so now ,beacuse the websettings button on my tablet isnt working.(last time i did it on a laptop.)
My "complete" config
var config = {}
config['language'] = 'en_US';
config['user_name'] = 'xxxxxxx';
config['pass_word'] = 'xxxxxxx';
config['wu_api'] = '23bd54af184b932c';
config['wu_city'] = 'Albertslund';
config['wu_country'] = 'DK';
not sure if any of this makes sence. But any help is highly appriciated.
regards
Bozidar
var config = {}
regards
Bozidar
- HansieNL
Can you try if the following settings solve your problem:
config['auto_positioning'] = 1;
config['use_favorites'] = 1;
Blah blah blah
thx for your suggestion.
I entered it ,but didn't change anything
var config = {}
config['user_name'] = 'xxxxxxxx';
config['pass_word'] = 'xxxxxx';
Is states that i need to double check path to domoticz.
var config = {}
Hi did you fix it ?
I have the same issue .
My Dashticz works fine for the longest time, I can access the Domoticz buttons all the time. However, I also quite regularly have the same error message in a red font in the lower right corner "double check path to domoticz"
So, a nice working system with a small disturbing text in alarming red font, that's all. I ignore it, but only wonder wat triggers this text.
- DewGew
- Domoticz version: V4.10618
Re:
Its when dashticz is getting the devices in background and sometimes it gets an error when retriving devices. There is an update in the latests beta handling the refresh and retrive devices in background maybe it's fixed now.jake wrote: ↑Friday 15 June 2018 23:07 My Dashticz works fine for the longest time, I can access the Domoticz buttons all the time. However, I also quite regularly have the same error message in a red font in the lower right corner "double check path to domoticz"
In the latest version I'm still having this problem! And the path is set correctly with http://
I get this error message when I want to switch a light from Off to On or visa versa.
What is the solution to this problem? I also think is slows down response when I change the status of the light.
var config = {}
config['language'] = 'nl_NL';
config['domoticz_ip'] = 'http://192.168.0.165:8080';
config['app_title'] = 'Home Automation';
config['domoticz_refresh'] = '3';
config['dashticz_refresh'] = '30';
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['hide_topbar'] = 0;
Sadly me too
rgroothuis wrote: ↑Saturday 17 November 2018 23:26 In the latest version I'm still having this problem! And the path is set correctly with http://
Screen Shot 2018-11-17 at 23.21.25.pngCode: Select all
var config = {} config['language'] = 'nl_NL'; config['domoticz_ip'] = 'http://192.168.0.165:8080'; config['app_title'] = 'Home Automation'; config['domoticz_refresh'] = '3'; config['dashticz_refresh'] = '30'; config['default_news_url'] = 'http://www.nu.nl/rss/algemeen'; config['news_scroll_after'] = '7'; config['hide_topbar'] = 0;
Anybody a solution for this problem? Or how to debug what the actual problem is?
Any way to debug?
My config simimular issues, on refresh loading menu i also get message 'there is something wrong with your config'
Everything is working fine and displaying fine, only at some moments lots of lag and i get this connection domoticz issue
I'm not code specialist so if someone has any hints, thanks in advance
var config = {}
config['domoticz_ip'] = 'http://192.168.1.13:2449';
config['auto_positioning'] = 0;
config['use_favorites'] = 0;
config['hide_topbar'] = 1;
config['last_update'] = 0;
config['wu_api'] = 'secrettt';
config['wu_city'] = 'pws:INOORDHO146';
config['wu_name'] = 'Haarlem';
config['no_rgb'] = 1;
config['spot_clientid'] = 'secrett';
config['longfonds_zipcode'] = 'secrett;
config['longfonds_housenumber'] = 'secrett';
var _HOST_DOMOTICZ = 'http://192.168.1.13:2449';
var buttons = {}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}
var coins = {}
coins.bitcoin = { key:'bitcoin', currency: 'EUR', layout:'vertical',width:4 }
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg_morning.jpg';
blocks[4] = {single_block: true};
blocks[3] = {single_block: true};
blocks[1046] = {single_block: true};
blocks[460] = {single_block: true};
blocks['longfonds'] = {};
blocks['longfonds']['width'] = 4;
columns[1] = {}
columns[1]['blocks'] = [418,909,446,870,137,1108,'8_1','8_2','8_3',9,832,'961_1',792,794,793,'spotify']
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = [6,4,3,1046,460,103,102,coins.bitcoin,'longfonds',159,163,173,12,16,1065,'graph_8']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise','weather',buttons.buienradar,'traffic']
columns[3]['width'] = 3;
If you press F12 in Chrome then developer mode starts. If you click on the tab 'console' you should be able to see the errors that have been reported.
One of the errors is 'Please, double check the path to Domoticz in settings'. What is the error just before this Domoticz error?
I assume you are already running the latest beta version of Dashticz...
- Minglarn
- Domoticz version: v3.8153
I've got this...
- Skärmklipp5.PNG (11.87 KiB) Viewed 4219 times
“When you eliminate the impossible, whatever remains, however improbable, must be the truth.” -Spock in Star Trek VI
Same problem on my side.
Several steps to debug.
Step 0: Use the beta version of Dashticz
I can't help with the master version.
Step 1: Starting Dashtics
Expected outcome: Dashtics starts. You see the dashboard.
Possible errors:
If you see an error message like 'time out. Check CONFIG.js'. then there is indeed an error in your CONFIG.js. (forget a comma, no closing brackets, etc.)
Step 2: Connection to Domoticz
If CONFIG.js is correct, then your devices should appear in dashticz.
Possible errors:
If you always get the red error text in the lower right corner then probably there is something not configured correctly for the Domoticz connection:
* check IP/port
* Check username/password (or disable access control for the subnet in Domoticz, and don't use username/password)
* In case of using "config['use_favorites']=1": Some devices have been labeled as Favorite in Domoticz
* In case of using "config['room_plan']" The devices have been added to a room_plan in Domoticz
Step 3: Switches work (in most cases)
If switches are visible in Dashticz, then you should be able to toggle a switch (without getting the red error text in most cases).
Possible errors:
I'm not sure, but if I remember correctly then in Domoticz you can configure that certain users only have 'read only' access. That could explain you can not operate the switches at all.
Step 4: the red error text, sometimes visible.
If step 0-3 are working, then let's look into this.
I see several reasons for the red error text to appear.
A) Timeout to Domoticz.
Debug:
Open chrome developer mode (F12), go to the network tab, press 'Time' so that all network requests are sorted on executing time top-down.
Check which calls give errors, what the reported error is, and what the execution time is.
It doens't always mean that the connection to Domoticz is the problem. If you switch back to the waterfall view, try to find network requests that take a long time.
B) Error text appears after pressing a switch in Dashticz. (in some cases)
This is a small bug in Dashticz. Might be fixed in the future.
(reason: the domoticz refresh request which is still running in the background gets cancelled. This creates the error. No real error: you can ignore it)
Possible errors:
Possible errors:
* check IP/port
Possible errors:
Debug:
Last edited by Lokonli on Wednesday 28 November 2018 11:19, edited 1 time in total.
You are using the master version of Dashticz. The beta version is more robust, but probably requires you to make some changes in your CONFIG.js and/or custom.js. Especially with the font-awesome fonts.rgroothuis wrote: ↑Wednesday 28 November 2018 10:26 Same problem on my side.
Last edited by Lokonli on Wednesday 28 November 2018 11:15, edited 1 time in total.
