Domoticz stops executing scipts sometimes
Furiousz23
Domoticz version: 4.10199
Post by Furiousz23 »
I`m experiencing some problems with my Domoticz the last few months. I have several Xiaomi devices in my setup, temperature sensors, round switches and door sensors. I have a bunch of scripts to control my (Yeelight) lights, doorbell, Sonoff switches and the alarm.
The last few months i had to restart domoticz several times because the scripts (triggerd by a Xiaomi device) stopped working.....sometimes it takes a week or month, but it also happend that i had to restart twice a day :cry: to get the scripts working again. The strange thing is that there a no problems in the logs of Domoticz. Even when i push the (physical) light switch and the script doesn`t get activated the log says:
2018-11-19 08:31:34.807 Status: LUA: Lamp woonkamer ingeschakeld door wandschakelaar
2018-11-19 08:31:34.808 Status: EventSystem: Script event triggered: Lichtschakelaar woonkamer
First i was using the Xiaomi Gateway to connect all the switches and sensors to Domoticz, but i recently switched to the Zigbee2mqtt plugin. With both options the problems are the same, so i think it`s something in Domoticz....
I really can`t find where to look for the solution. The are more people (in the Netherlands) with the exact same problem https://gathering.tweakers.net/forum/vi ... e/57097109.
At this moment i`m using version: 4.10199 of Domoticz. Is there anyone willing to help me with this issue? It`s driving my crazy, and my wife gets angry every time she can`t switch on the lights :mrgreen: :mrgreen:
This is one of the scripts i`m using. "Schakelaar lamp garage" is a round wireless Xiaomi switch and "Garagelamp" is a Sonoff S20 switch:
if (devicechanged['Schakelaar lamp garage'] == 'Click') and (otherdevices['Garage lamp'] == 'Off') then
    commandArray['Garage lamp'] = 'On'
    print('Lamp garage ingeschakeld door wandschakelaar')
elseif (devicechanged['Schakelaar lamp garage'] == 'Click') and (otherdevices['Garage lamp'] == 'On') then
    commandArray['Garage lamp'] = 'Off'
    print('Lamp garage uitgeschakeld door wandschakelaar')
stewdyne
Re: Domoticz stops executing scipts sometimes
Post by stewdyne »
I experience the exact same problem! When I active my Xiaomi devices the event system stops at random intervals. DZ is still up and showing no errors.
Really hope someone can dig into this. I can't find anything in the log.
Furiousz23
Is no one experiencing the same problems???
ben53252642
Post by ben53252642 »
Can't see any problems with your script.
As you mention the issue is specific to your Xiaomi devices, the crash is likely coming from a plugin you have enabled in Domoticz Hardware. Try disabling them one at a time until you find which one is causing it then report in the relevant thread.
