plugin Zigate - Beta 3.1.x
pipiche
Re: plugin Zigate - Beta 3.1.x
Post by pipiche »
hkhk wrote: Wednesday 21 November 2018 22:06
The Aquara wall switch (the flat battery driven one) is detected wrongly I think since Domoticz thinks it is a XCube and it creates 2 devices.
I sent you a Private message, and in paralell I found that your Aqara wall switch was known under an other model. I did update, so if you can update the plugin, restart remove the olde device and re-pair it .
ThomasTelos
Post by ThomasTelos »
ATTENTION, there is no way to fall back, so make sure that you have the proper backup in place (domoticz.db and DeviceList.txt at least).
It is not possible to back-up this file. I get the mssge: ....=> see picture. ??
DeviceList.txt is Locked?
I use latest Zigate version and foor SSH Filezilla
pipiche
Post by pipiche »
Could you clarify what is the problem you want to report?
The plugin 3.1 is not supported since a while.
