SQLHelper error on deleted script
ArnieO
Domoticz version: 4.9700
Post by ArnieO »
Domoticz version 4.9700 running on Raspberry Pi 3 B
I had a LUA script stored in ...../domoticz/scripts/lua that I have moved to the internal event editor.
The "new" internal script works correctly.
But after having deleted the script in the above folder, I still get this error message each time the event is triggered:
Error: SQLHelper: Error script not found '/home/domoticz/domoticz/scripts/lua/script_device_KontorVeggbryter2.lua'
I have not been able to find anything in the forum explaining this, and its potential fix.
Anyone?
Electronics engineer partly out of practice, having turned the skills into hobby recently. Playing with RPi, Arduinos, ESP8266s etc. Installed Nexa units in the house, which I want to control with Domoticz / RPi3 / RFXtrx433.
Re: SQLHelper error on deleted script
ArnieO wrote: Wednesday 21 November 2018 15:50 Domoticz version 4.9700 running on Raspberry Pi 3 B
Did you try to cycle the event system in [systems] [settings] [other] Eventsystem (disable + apply settings / enable + apply settings) ?
If that does not work, stop/start domoticz might help
ArnieO
Post by ArnieO »
waaren wrote: Wednesday 21 November 2018 18:05 Did you try to cycle the event system in [systems] [settings] [other] Eventsystem (disable + apply settings / enable + apply settings) ?
Thank you for your interest!
I tried both now, unfortunately it did not help. No change.
ArnieO wrote: Wednesday 21 November 2018 23:10
Do you have an idea why the error points to two levels domoticz ? What is your actual domoticz dir ?
ArnieO
Post by ArnieO »
waaren wrote: Wednesday 21 November 2018 23:37
Something did not go as planned during a recent restore after an SD card crash. :roll: This is the correct directory of my domoticz. I am quite sure the error is not related to this.
