Listen to your favourite radios V2
- Domoticz version: Latest
Re: Listen to your favourite radios V2
Seems that your Pi cannot find a bluetooth device... Can you check lspci and lsusb.
status of bluetooth give me this output
did a fresh reinstall BTW
Everything looks working normal
lsusb works lspci not=
gianni@xxxxxxx:~ $ systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset
Active: active (running) since Fri 2018-09-21 09:39:36 CEST; 1h 2min ago
Docs: man:bluetoothd(8)
Main PID: 449 (bluetoothd)
Status: "Running"
CGroup: /system.slice/bluetooth.service
└─449 /usr/lib/bluetooth/bluetoothd
sep 21 09:39:36 domotic systemd[1]: Starting Bluetooth service...
sep 21 09:39:36 domotic bluetoothd[449]: Bluetooth daemon 5.43
sep 21 09:39:36 domotic systemd[1]: Started Bluetooth service.
sep 21 09:39:36 domotic bluetoothd[449]: Starting SDP server
sep 21 09:39:36 domotic bluetoothd[449]: Bluetooth management interface 1.14 ini
[color=#FF0000]sep 21 09:39:36 domotic bluetoothd[449]: Failed to obtain handles for "Service C
sep 21 09:39:36 domotic bluetoothd[449]: Sap driver initialization failed.
sep 21 09:39:36 domotic bluetoothd[449]: sap-server: Operation not permitted (1)
sep 21 09:39:37 domotic bluetoothd[449]: Failed to set privacy: Rejected (0x0b)[/color]
lines 1-18/18 (END)
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Status: "Running"
sep 21 09:39:36 domotic bluetoothd[449]: Bluetooth management interface 1.14 initialized
[color=#FF0000]sep 21 09:39:36 domotic bluetoothd[449]: Failed to obtain handles for "Service Changed" characteristic
gianni@xxxxxxxx~ $ lsusb
Bus 001 Device 004: ID 0658:0200 Sigma Designs, Inc.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
gianni@xxxxxxx:~ $ lspci
-bash: lspci: opdracht niet gevonden
gianni@xxxxxx:~ $
gianni@xxxxxx:~ $ rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Hi, this is interesting:
Look here:
https://www.raspberrypi.org/forums/view ... p?t=131999
ok first thing solved.
The distance between te bleutooth speaker and the pi was to far.
Put my pi near my speaker and i got music when i exesute the command om my PI
But i still not get it work in Domoticz.
Looks like the os.excecute is not excecute on the pi
- emme
- Domoticz version: latest
have you setted the country in raspi-config or in the wpasupplicant.conf ?
"We always done this way"
yep my country is set correct
but my bleutooth is working now it's only the os-execute that not work.
When i test to make a dir in my homefolder with os-execute the dir does not come in my home folder.
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
country=BE
still not working
it's drive me mad
Reinstall my domoticz and stretch multiple time's.
so short
if i execute direct on my pi manual it's play on my bleutooth speaker.
if i execute this code on domoticz
it's kill the player i started manual.
But if is start this code from domoticz it's not play
so whats the different between the off and the MNM code?
The only thing i can think off is that is delete the PI user and use my own user account?
it's drive me mad
so short
if i execute
mplayer -noconsolecontrols http://uk2.internet-radio.com:8358/ &> /dev/null
if device.state == 'Off' then
os.execute ("killall mplayer")
if device.state == 'MNM' then
os.execute ("mplayer -noconsolecontrols http://uk2.internet-radio.com:8358/ &> /dev/null")
i found the problem now i need to find a solution
I create a simple bash script that excecute
if i run mplayer -noconsolecontrols http://uk2.internet-radio.com:8358/ in the console it's works
if i run it from the script i get a pulse connection refused
Starting playback...
Audio only file format detected.
Opening audio decoder: [mpg123] MPEG 1.0/2.0/2.5 layers I, II, III
AUDIO: 44100 Hz, 2 ch, s16le, 160.0 kbit/11.34% (ratio: 20000->176400)
Selected audio codec: [mpg123] afm: mpg123 (MPEG 1.0/2.0/2.5 layers I, II, III)
AO: [pulse] 44100Hz 2ch s16le (2 bytes per sample)
Video: no video
AO: [pulse] Init failed: Connection refused
Failed to initialize audio driver 'pulse'
AO: [alsa] 44100Hz 2ch s16le (2 bytes per sample)
Video: no video
Hi, I'm not sure. But can you try this:
sudo adduser <username> audio
gianni@domotic:~ $ sudo adduser gianni audio
De gebruiker `gianni' is reeds lid van `audio'.
toch bedankt om mee te denken
Oh great
Gern geschehen. Viel Spaß
hheehehe it's not working,i was already a member of audio
Ok bad...
- amplituda
- Domoticz version: 2023.2
Hello everyone!) Have you tried to switch channels with a radio button from Xiaomi?
that is, you can make the command "next channel" and so on in a circle?
- ledfreak3d
- Domoticz version: 3.8025
bluetooth audio from domoticz seems to be a bit of an issue and i cant find why
from console all works great
from domotiz it does not but only when using bluetooth when using analog or hdmi out no issue
Unleashe the magic smoke ;)
- Domoticz version: 2020.1
Hi all, after some issue I found this solution...
Use to don' block the script and
Use
io.popen
runuser -l pi -c
if domoticz.devices('WebRadio').state == 'Subasio' then
--domoticz.notify('WebRadio','Radio Subasio on air...', domoticz.PRIORITY_NORMAL)
io.popen ("runuser -l pi -c \'mplayer -noconsolecontrols http://onair18.xdevel.com:8152 -volume 100 &> /dev/null'")
--os.execute ("runuser -l pi -c \'mplayer -noconsolecontrols http://onair18.xdevel.com:8152 -volume 100 &> /dev/null'")
Finish!
I add two dummy selector switches "WebRadio" and "Volume"
When you change the volume is not necessary to kill and restart...
Change your device with your device...
run to know your...
Change your device
"NBY5540 - A2DP"
run
amixer
data = {
switchwebradio = { initial = "Off" }
devices = {
'WebRadio',
'Volume'
execute = function(domoticz, triggeredItem, info)
local volume = domoticz.devices('Volume').level
if (domoticz.devices('Volume').state == "Off") then
volume = 0
cmd = 'amixer set "NBY5540 - A2DP" ' ..volume.. '% &> /dev/null'
os.execute ("runuser -l pi -c \'" ..cmd.. "'")
if (domoticz.devices('WebRadio').state ~= domoticz.data.switchwebradio) then
if (domoticz.devices('WebRadio').state == 'Off') then
domoticz.notify('WebRadio','WebRadio spenta', domoticz.PRIORITY_NORMAL)
io.popen ("runuser -l pi -c \'mplayer -noconsolecontrols http://onaxr18.xxxxxxxxxxxxxx.com:8152 &> /dev/null'")
if domoticz.devices('WebRadio').state == 'RTL' then
io.popen ("runuser -l pi -c \'mplayer -noconsolecontrols https://strex2.xxxxxxxxxx.com/rtl-1025 &> /dev/null'")
domoticz.notify('WebRadio','RTL 102.5 on air...', domoticz.PRIORITY_NORMAL)
if domoticz.devices('WebRadio').state == '105' then
io.popen ("runuser -l pi -c \'mplayer -noconsolecontrols http://icecast.xxxxxxxxxxo.it/Radio105.mp3 &> /dev/null'")
domoticz.notify('WebRadio','Radio 105 on air...', domoticz.PRIORITY_NORMAL)
if domoticz.devices('WebRadio').state == 'RDS' then
io.popen ("runuser -l pi -c \'mplayer -noconsolecontrols http://icstream.rxxxxxxxxxs.radio/rdsmp3 &> /dev/null'")
domoticz.notify('WebRadio','RDS on air...', domoticz.PRIORITY_NORMAL)
if domoticz.devices('WebRadio').state == 'Deejay' then
io.popen ("runuser -l pi -c \'mplayer -noconsolecontrols http://raxxxxxxxxxy-lh.akamaihd.net/i/RadioDeejay_Live_1@189857/master.m3u8 &> /dev/null'")
domoticz.notify('WebRadio','Radio Deejay on air...', domoticz.PRIORITY_NORMAL)
if domoticz.devices('WebRadio').state == 'RadioItalia' then
io.popen ("runuser -l pi -c \'mplayer -noconsolecontrols https://radixxxxxxxxxxxxxi-lh.akamaihxxxxxxnet/i/radioitaliasmi_1@329643/master.m3u8 &> /dev/null'")
domoticz.notify('WebRadio','Radio Italia on air...', domoticz.PRIORITY_NORMAL)
if domoticz.devices('WebRadio').state == 'RadioUno' then
io.popen ("runuser -l pi -c \'mplayer -noconsolecontrols http://icestreamxxxxxxxxx.it/1.mp3 &> /dev/null'")
domoticz.notify('WebRadio','Rai Radio 1 on air...', domoticz.PRIORITY_NORMAL)
if domoticz.devices('WebRadio').state == 'RadioDue' then
io.popen ("runuser -l pi -c \'mplayer -noconsolecontrols http://icestreaxxxxxxxxxx.it/2.mp3 &> /dev/null'")
domoticz.notify('WebRadio','Rai Radio 2 on air...', domoticz.PRIORITY_NORMAL)
if domoticz.devices('WebRadio').state == 'IsoRadio' then
io.popen ("runuser -l pi -c \'mplayer -noconsolecontrols http://icestrexxxxxxxxi.it/6.mp3 &> /dev/null'")
domoticz.notify('WebRadio','IsoRadio on air...', domoticz.PRIORITY_NORMAL)
if domoticz.devices('WebRadio').state == 'UAO_Kids' then
io.popen ("runuser -l pi -c \'mplayer -noconsolecontrols http://nr11.newrxxxxxxxxxxxxxt:9023/stream?1587028574736 &> /dev/null'")
domoticz.notify('WebRadio','UAO Kids radio on air...', domoticz.PRIORITY_NORMAL)
domoticz.data.switchwebradio = domoticz.devices('WebRadio').state
Cool... With notification
