I have added my evohome system via API and am able to set the temperature when viewing the devices in the temperature tab, however, I am unable to set the temperature from the dashboard.
Is there any way to enable this? or a workaround
Ideally would also like to be able to set an 'override' timer so that I can for example set 'living room to 20 degrees for 2 hours' before returning to the normal schedule
I have tried googling and searching these forums and have not been able to find an answer.
Many thanks in advance
Evohome Control From Dashboard
- philchillbill
Re: Evohome Control From Dashboard
You cannot change temp from the dashboard, unfortunately. If you want to create a switch that sets a temperature with an until-time specified, a JSON call to the api will do the trick (this is mentioned in the wiki). Something along the lines of:
http://192.168.1.12:8080/json.htm?type=setused&idx=106&setpoint=22&mode=TemporaryOverride&until=2018-11-10T16:00&used=true
Alexa skills author: EvoControl, Statereport, MediaServer, LMS-lite
