What does nvalue and svalue represent?
In the JSON-API sometimes the nvalue is used (Air quality) and most times the svalue is used (Temperature, etc.).
API - When to use nvalue and when svalue? Topic is solved
tvurce
Re: API - When to use nvalue and when svalue?
I am interested too...
- waaren
nValue = numeric ( one value -- INTEGER DEFAULT 0)
sValue = string ( multiple values -- VARCHAR(200) DEFAULT null )
tvurce
Yes. But in a lot of examples, there are numbers throwing to Domoticz with sValue. This is little bit confusing. But anyway, if one send number to Domoticz in sValue, it seems working (graphs, averages etc are calculated OK...)
febalci
You can find out when to use svalue or nvalue according to the device type in this page:
https://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s
- emme
- Domoticz version: latest
nValue (Numeric Value) is only integer and is used command option for existing devices:
ON(1)
OFF(0)
STOP(17)
DIM LEVEL(2)
(I think there are more, but up to know I know these)
any other value should be set to sValue (String Value)
ON(1)
OFF(0)
STOP(17)
DIM LEVEL(2)
"We always done this way"
Users browsing this forum: willemd and 1 guest
