Hi !
From a webbrowser I can control domoticz by:
domoticzIP:8080/json.htm?type=command¶m=udevice&idx=1078&nvalue=0&svalue=10;20;0
This 'command' gives a virtual tempsensor with IDX=1078 a value.
Now I want to do same using an Arduino using :
(just one line of code displayed. there is already a connection with domoticz)
client.print("GET /json.htm?type=command¶m=udevice&idx=1078&nvalue=0&svalue=10;20;0");
But this does not give any result.
Does Domoticz require a setting to accept this "controldata"?
Maybe anyone has a working example? I tried several from the web but all without the desired result.....
Any help is welcome.
BTW I am an absolute beginner in trying to transmit data in this way.
KR
-Bart
how to control domoticz from internet with arduino
BartSr
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
freijn
- Domoticz version: Stable
Re: how to control domoticz from internet with arduino
Do you have set requests coming from the same network does not require to use login password?
BartSr
wow.... such a simple thing.
works like a charm now
thanks a lot !!
-Bart
thanks a lot !!
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
GiorgioIT
I would like to start doing something with arduino, could you give me some clues or sketch arduino to start trying ?????
BartSr
@ GiorgioIT
What you wanna achieve?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
freijn
https://www.letscontrolit.com/wiki/index.php/ESPEasyGiorgioIT wrote: Sunday 18 November 2018 22:14 I would like to start doing something with arduino, could you give me some clues or sketch arduino to start trying ?????
all you need
Ranchor
Thanks for the link you posted, it's been helpful to me. Here is a link to my work.
