Help wanted with ventilation script
basjes
Post by basjes »
I'm new to dzVent scripting and thought to setup a ventilation script.
Unfortunately it is not as easy as I thought ;)
I have a ventilation box with multiple levels which I can control wit a selector switch in domoticz.
The actual state of the box is sent to domoticz using ESPEasy.
What I'm trying to achieve is the following:
between 07:00 and 22:00 (daytime) the ventilation box may run at a higher speed (switch level 10) and if the humidity rises above 60 % it is supposed to run at switch level 30.
Between 22:00 and 07:00 (nighttime) the ventilation box must run at a lower speed (switch level 00) and if the hunidity rises above 60% it is supposed to run at switch level 10.
I've searched the wiki and tried to use examples. So far I created the following script, but is does not work as expected.
It only seems to run the daytime part. I'm probably overthinking this and missing something (for me not so) obvious.
Can you guys give me som pointers ?
Thanks.
		timer = {'every minute'}
   execute = function(domoticz, timer)
if (domoticz.time.hour >=7 and domoticz.time.hour <22) then
	domoticz.log('het is overdag')
	if domoticz.devices('Thermo Badkamer').humidity >= 60 then
	domoticz.log('Het is vochtig op de badkamer!', domoticz.LOG_INFO)
		if domoticz.devices('Ventilatie').switchSelector < 40 then
		domoticz.log('Er is geen timer ingesteld', domoticz.LOG_INFO)
		domoticz.devices('Ventilatie').switchSelector(20)
    if domoticz.devices('Thermo Badkamer').humidity <= 60 then
  	domoticz.log('Het is niet (meer)vochtig op de badkamer!', domoticz.LOG_INFO)
	domoticz.devices('Ventilatie').switchSelector(10)
elseif (domoticz.time.hour >=22 and domoticz.time.hour <7) then
	domoticz.log('het is avond/nacht')
	domoticz.log('Het is niet (meer) vochtig op de badkamer!', domoticz.LOG_INFO)
	domoticz.devices('Ventilatie').switchSelector(00)
Re: Help wanted with ventilation script
basjes wrote: Tuesday 30 October 2018 22:18 I'm new to dzVent scripting and thought to setup a ventilation script.
Do you see anything in the log ? That would be useful for debugging.
I use a script similar to the one below and adjusted some parts to enable it for your situation. Please check if it fits your purpose. Any questions feel free to ask.
    on      =   {   timer   = { "every minute"  }},
   logging  =   {   level   = domoticz.LOG_DEBUG,
                    marker  = "ventilation"      },
   execute = function(dz)
        local humidity          = dz.devices("Thermo Badkamer").humidity
        local ventilator        = dz.devices("Ventilatie")
        local ventLevel         = ventilator.level
        local humidityFence     = 60
        local noTimerLevel      = 40
        local lowVentDaytime    = 10
        local highVentDaytime   = 20
        local lowVentNighttime  = 0
        local highVentNighttime = 10
        local function logWrite(str,level)
            if not level then level = LOG_DEBUG end
            dz.log(str,level)
        local function manageVentilator(low,high)
            if humidity >= humidityFence then
                logWrite("Het is vochtig op de badkamer! (" .. humidity .. "%)")
                if ventLevel < noTimerLevel then
                    logWrite("Er is geen timer ingesteld")
                    if ventLevel ~= high then
                        logWrite("Er wordt geschakeld")
                        ventilator.switchSelector(high)
                        logWrite("Ventilator draait al op juiste nivo; dus geen actie vereist")
                    logWrite("Er is een timer ingesteld")
                logWrite("Het is niet (meer) vochtig op de badkamer! (" .. humidity .. "%)")
                if ventLevel ~= low then
                    ventilator.switchSelector(low)
                    logWrite("Ventilator draait al op juiste nivo; dus actie vereist")
        -- Main
        if dz.time.matchesRule("at 07:00-22:00") then
            logWrite("het is overdag")
            manageVentilator(lowVentDaytime,highVentDaytime)
            logWrite("het is avond/nacht")
            manageVentilator(lowVentNighttime,highVentNighttime)
basjes
Post by basjes »
Thanks for the script. I will look at it tonight
basjes
Post by basjes »
waaren wrote: Tuesday 30 October 2018 23:52
            dz.log(str,level)
        -- Main
Your script works like a charm.
