SOLVED Error executing script command returned: 512 and 32256
McJohn
Post by McJohn »
We made a simple Python script (below) to switch on a led at the Raspberry GPIO pin 4.
This script works perfect at the command line but unfortunately not in a Scene in Domoticz.
We got the following error:
Error executing script command (/home/pi/domoticz/scripts/ledon.py). returned: 32256
The specified path is 100% ok (script:///home/pi/domoticz/scripts/ledon.py)
Then we changed the user rights with sudo 755.
Then we got the following error;
Error executing script command (/home/pi/domoticz/scripts/ledon.py). returned: 512
Then we tried the standard delivered sample within the Domoticz python script folder:
Error executing script command (/home/pi/domoticz/scripts/python/script_time_demo.py). returned: 32256
So, even the standard python sample won't work within a Domoticz Scene!
We searched the forum and saw a lot of these kind of errors but nu solution for this simple script.
Thanks for the help!
Python script:
from gpiozero import LED
red_led=LED(4)
red_led.on()
McJohn
Re: Error executing script command returned: 512 and 32256
Post by McJohn »
SOLVED!
For the
32256 error:
Every script must have the right user permissions, even the standard samples delivered with Domoticz has to be changed after installation:
sudo chmod 755 /home/pi/domoticz/scripts/ledon.py
And for the
512 error
Every (Python) script must begin with:
#!/usr/bin/python
gomecin
Re: SOLVED Error executing script command returned: 512 and 32256
Post by gomecin »
Just for the record in case anyone stumbles here as I did.
Besides the needed chmod 777 or 755, I struggled with some python issues and the reason was that one argument was the name of a file to use in the script. From shell no issue, but from Domoticz nothing. That name, so as any other file used in the script, has to contain the full path, RELATIVE ROUTES DO NOT WORK WHEN CALLING SCRIPTS FROM DOMOTICZ.
