Python plugin: ELV/EQ-3 MAX!
mvzut
Post by mvzut »
Ok, good to hear it at least doesn't give error messages anymore (the "thread seems to have ended unexpectedly" message occurs for me too, although rarely, I suspect this happens when the communication with the Cube occasionally takes too long).
Are the valve positions updated correctly? Can you perhaps post the relevant log parts when debugging is on? It should say something like "x valves require heat".
AurelioF
Re: Python plugin: ELV/EQ-3 MAX!
Post by AurelioF »
mvzut wrote: Sunday 28 October 2018 9:11 Ok, good to hear it at least doesn't give error messages anymore (the "thread seems to have ended unexpectedly" message occurs for me too, although rarely, I suspect this happens when the communication with the Cube occasionally takes too long).
OK that's ...
in the log it appears ...
2018-10-28 11: 43: 52.773 (eQ3) 246 valves require heat
But the Heat demand switch remains closed.
2018-10-28 11:43:37.700 Status: (eQ3) Initialized version 0.6.0, author 'mvzut'
2018-10-28 11:43:40.444 (eQ3) Number of rooms found: 9 (highest number: 9)
2018-10-28 11:43:49.965 (eQ3) Reading e-Q3 MAX! devices from Cube...
2018-10-28 11:43:52.744 (eQ3) Checking device 'WC-Bajo' in room 1
2018-10-28 11:43:52.747 (eQ3) Checking device 'Despacho' in room 2
2018-10-28 11:43:52.750 (eQ3) Checking device 'Pasillo-Superior' in room 3
2018-10-28 11:43:52.753 (eQ3) Checking device 'WC-Superior' in room 4
2018-10-28 11:43:52.756 (eQ3) Checking device 'Dormitorio' in room 5
2018-10-28 11:43:52.759 (eQ3) Checking device 'Invitados' in room 6
2018-10-28 11:43:52.761 (eQ3) Checking device 'Rad-Libreria' in room 7
2018-10-28 11:43:52.764 (eQ3) Checking device 'Rad-mesacomedor' in room 7
2018-10-28 11:43:52.767 (eQ3) Checking device 'Hall' in room 8
2018-10-28 11:43:52.770 (eQ3) Checking device 'Cocina' in room 9
2018-10-28 11:43:52.773 (eQ3) 246 valves require heat
2018-10-28 11:44:22.323 (eQ3) Skipping heartbeat: 1
2018-10-28 11:44:52.324 (eQ3) Skipping heartbeat: 2
2018-10-28 11:45:22.325 (eQ3) Skipping heartbeat: 3
2018-10-28 11:45:52.326 (eQ3) Reading e-Q3 MAX! devices from Cube...
2018-10-28 11:45:55.147 (eQ3) Checking device 'WC-Bajo' in room 1
2018-10-28 11:45:55.150 (eQ3) Checking device 'Despacho' in room 2
2018-10-28 11:45:55.153 (eQ3) Checking device 'Pasillo-Superior' in room 3
2018-10-28 11:45:55.155 (eQ3) Checking device 'WC-Superior' in room 4
2018-10-28 11:45:55.158 (eQ3) Checking device 'Dormitorio' in room 5
2018-10-28 11:45:55.161 (eQ3) Checking device 'Invitados' in room 6
2018-10-28 11:45:55.164 (eQ3) Checking device 'Rad-Libreria' in room 7
2018-10-28 11:45:55.167 (eQ3) Checking device 'Rad-mesacomedor' in room 7
2018-10-28 11:45:55.170 (eQ3) Checking device 'Hall' in room 8
2018-10-28 11:45:55.173 (eQ3) Checking device 'Cocina' in room 9
2018-10-28 11:45:55.176 (eQ3) 246 valves require heat
2018-10-28 11:46:24.726 (eQ3) Skipping heartbeat: 1
2018-10-28 11:46:54.728 (eQ3) Skipping heartbeat: 2
2018-10-28 11:47:24.730 (eQ3) Skipping heartbeat: 3
2018-10-28 11:47:54.731 (eQ3) Reading e-Q3 MAX! devices from Cube...
2018-10-28 11:47:57.549 (eQ3) Checking device 'WC-Bajo' in room 1
2018-10-28 11:47:57.552 (eQ3) Checking device 'Despacho' in room 2
2018-10-28 11:47:57.555 (eQ3) Checking device 'Pasillo-Superior' in room 3
2018-10-28 11:47:57.558 (eQ3) Checking device 'WC-Superior' in room 4
2018-10-28 11:47:57.561 (eQ3) Checking device 'Dormitorio' in room 5
2018-10-28 11:47:57.564 (eQ3) Checking device 'Invitados' in room 6
2018-10-28 11:47:57.567 (eQ3) Checking device 'Rad-Libreria' in room 7
2018-10-28 11:47:57.570 (eQ3) Checking device 'Rad-mesacomedor' in room 7
2018-10-28 11:47:57.573 (eQ3) Checking device 'Hall' in room 8
2018-10-28 11:47:57.576 (eQ3) Checking device 'Cocina' in room 9
2018-10-28 11:47:57.579 (eQ3) 246 valves require heat
AurelioF
Post by AurelioF »
It is correct "246 valves require heat"
246 seems a high value :?:
I only have 25 devices in this machine
DarkG
Domoticz version: 4.10076
Post by DarkG »
How did you update the plugin?
RPi4 Shelly1 Shelly2.5 ESPEasy Tuya Domoticz Beta Dashticz 3.6
DarkG
Post by DarkG »
So got it installed. Valves are over 50%, but the Heat demand wont switch.
AurelioF
Post by AurelioF »
DarkG wrote: Sunday 28 October 2018 15:41 How did you update the plugin?
The update is done with
git reset --hard
git pull
But problems may appear, keep in mind that it is still in development, visit.
viewtopic.php?f=34&t=25081&start=40#p195558
AurelioF
Post by AurelioF »
DarkG wrote: Sunday 28 October 2018 17:40 So got it installed. Valves are over 50%, but the Heat demand wont switch.
It seems that there is some problem, mvzut is reviewing the code.
mvzut
Post by mvzut »
AurelioF wrote: Sunday 28 October 2018 18:24
I reviewed the code, and found a "bug"! For some reason, the state of the Heat demand switch is undefined directly after it is created. Since I do a check if it is off before I turn it on, it never turned on... The logging of the number of valves that need heat is also correct now.
Please update again using the standard method. Please also REMOVE the heat demand switch, it will be recreated again automatically (but now with a defined initial state). Alternatively, you can also uninstall the plugin completely (removing all devices) and install it back again. For new users, everything should work out-of-the-box now.
AurelioF
Post by AurelioF »
mvzut wrote: Sunday 28 October 2018 18:56
I reviewed the code, and found a bug! For some reason, the state of the Heat demand switch is undefined directly after it is created. Since I do a check if it is off before I turn it on, it never turned on... The logging of the number of valves that need heat is also correct now.
Ok, turn on the heat demand switch!
The log looks good
I will try it for a while and if you want I inform you ..
Thank you very much for this add-on ... :D
mvzut
Post by mvzut »
Great! Feedback is always welcome. Also from others who use the plugin. Let me know if the features work, if/how you use them, if you have ideas for other features, etc.
janvangent2
Post by janvangent2 »
Today I installed the new version, linked it to my ESP8266 module + relay to control the heater and all is working great!
Many thanks mvzut! ;)
I took a small power supply and integrated both in a white General Electric box
I made this relay control for the heater in parallel to the conventional control. Which is now set at 10°C. In case the raspberry Pi crashes or my wifi network is down, I can still control the heater with the conventional thermostat.
Installed the wall thermostat (which fits great with my other household switches)
Al temperatures are updated and the heat demand switch does it job.
mvzut
Post by mvzut »
Cool (or should I say: hot?)! Curious if the heat demand switch works satisfactory on the long run. You have quite a number of valves, I can imagine that switching the boiler on every time just a single valve requires heat could lead to "nervous" switching. If this turns out to be the case, we could experiment with an additional setting which specifies the amount of valves that need to be open before the heat demand switch is turned on.
janvangent2
I have 11 radiator vavles and 3 wall thermostats.
I will monitor the on/off behavior in the next few days.
In case there is an issue, we could possible re-use some of the coding of the other EQ-3 max plugin?
In case you run out of user configurable parameters, could I edit the values in the python script directly?
BoilerOnPercent = 30               -- percentage valve open at which the boiler will be turned on
HysterysisOffPercent = 20             -- percentage below BoilerOnPercent to switch off the boiler
MinValves = 2                      -- Number of Valves that need to be open before boiler is turned on
ValvePercentOveride = 75            -- Percentage value of valve open required to override MinValves value (one room is very cold)
AurelioF
Post by AurelioF »
Some appreciations after a few days of use.
First I want to say that in my installation I still do not have wall thermostats, I hope to solve this situation in a few days.
I'm working with 11 valves and their corresponding integrated thermostats, I know this is not the best.
in my case the percentage of the opening of the valves of 25% caused a demand of continuous or almost heat, modify this value in your script and use 50%, with this value the behavior improved, even so I find differences of 1º or more between the setpoint temperature and the temperature actually reached, I explain, to have a stay at 19 º I have to adjust the valve to 18 º.
My heating uses valves from a single pipe, the most abundant systems use a hot water pipe and a return pipe for the already cooled water. In my heating, the water after passing through the radiator goes back to the same pipe.
I would also like to point out, that I do not find improvement in the frequency of taking temperature when using the script
valves = {"Mode valve 1","Mode valve 2","Mode valve 3"}
if tonumber(os.date('%M')) == 0 then
  for n, device in pairs(valves) do
    setting = otherdevices_svalues[device]
    if setting == 0 then tempsetting = 10 else tempsetting = 0 end
    table.insert(commandArray, {[device] = "Set Level " .. tempsetting})
    table.insert(commandArray, {[device] = "Set Level " .. setting .. " AFTER 30"})
I tried to put the script also in the directory for lua, as indicated.
maybe I misunderstood how to use the names of the valves, I think these are the names of the valves in domoticz, is that correct?
After testing the script for 48 hours I do not find more frequent temperature taking.
Next week I will include wall thermostats
janvangent2
So far it is working great.
Below a graph of the heat demand switch.
Last heat demand yesterday evening was at 20.34
At 22.00 we went to sleep and all temperature setpoints are lowered except the sleeping room of our son, which is set to 19°C.
As you can see only once during the night (00.39) heat was requested to keep the sleeping room on it's setpoint. Next time was in the morning around 5:30 when the setpoint of the living room goes up to 21°C.
Since I'm at home this week, the heating in the living room is set to 20°C during the day, so about every 2 hours there is heat demand to maintain this temperature.
So I couldn't be happier for the moment.
mvzut
Post by mvzut »
AurelioF wrote: Tuesday 30 October 2018 15:46 in my case the percentage of the opening of the valves of 25% caused a demand of continuous or almost heat, modify this value in your script and use 50%, with this value the behavior improved, even so I find differences of 1º or more between the setpoint temperature and the temperature actually reached, I explain, to have a stay at 19 º I have to adjust the valve to 18 º.
For me 25% works ok, but I only have 3 valves, and the heater switches on a lot due to the normal thermostat in my living room as well.
I am experimenting with a version that approaches it from a slightly different perspective: I calculate the average opening percentage of all valves, which should be above e.g. 10%. In my case, with only 3 valves, this means that one valve needs to be open 30% or two @ 15% or three @ 10%. If you have 11 valves, it means one valve @ 100% will not even cause the heat demand switch to go on because it gives an average of 9%. But usually, when one valve requires heat, more will, so eventually the average opening percentage will rise above 10%. I think this could reduce the amount of "nervous" switching. Anyone interested to try this out? For such testing pruposes, I suggest that I send or attach the python file directly, instead of using Github.
AurelioF wrote: Tuesday 30 October 2018 15:46 I would also like to point out, that I do not find improvement in the frequency of taking temperature when using the script
You should indeed use the (axact!) names of the mode switches in Domoticz. To make sure it's actually running: If you look at the history of the mode switches, do they indeed change position briefly every hour? In my case it seems to help a bit. I'll disable the script tonight to see the difference.
AurelioF
Post by AurelioF »
ok thank you very much mvzut, I am willing to experience what is necessary.
for me the current method works well, and has the advantage of being able to completely close valves (guest room) without influencing the rest, just comment as general information in case someone could find the same problem.
Something that I see very interesting, is to be able to use different types of thermostats, for example the intelligent virtual thermostat, it seems an interesting development.
For me, it would be a great solution, to be able to use a thermostat per floor or per room, without being forced to buy wall thermostats EQ-3 MAX!
although it seems that it is not easy to implement given the operation of the EQ-3 MAX!
Next week I will have the EQ-3 MAX thermostats! and I will prove how they work.
thanks for everything.
haajee
Domoticz version: V4.10149
Post by haajee »
Hi.
Thank you for your great work! i tried directly on my Orange Pi PC with Armbian Ubuntu Bionic. But sadly it does nothing... Also if i reboot the Domoticz or even the complete Orange PI... There comes no new hardware under the devices...
I have the following Python versions installed:
root@orangepipc:/# python --version
Python 2.7.15rc1
root@orangepipc:/# python3 --version
Python 3.6.6
What do i wrong? Or should i just activate plugins in the settings or something? A clean install does also not fix this problem.
Edit: i look in the log and i read:
2018-10-30 18:56:34.878 Status: EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
Edit2: this error did i fixed with:
apt-get install libpython3
I didn't see a error in Domoticz error log now but it's still not working :(
AurelioF
Post by AurelioF »
Hello haajee, I use raspbian in my pi, and it works without problems, I use the version of Python: 3.5.3, in the Domoticz wiki you can find all the information to install.
If you have difficulties trying to help you.
haajee
Post by haajee »
Thaml you very much. :) This is what the log now shows. I see nothing what could be wrong?
 2018-10-30 19:30:02.886 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2018-10-30 19:30:02.898 Status: Build Hash: a3a45906, Date: 2018-06-23 14:24:51
2018-10-30 19:30:02.899 Status: Startup Path: /home/hj/domoticz/
2018-10-30 19:30:03.174 Sunrise: 06:27:00 SunSet: 16:08:00
2018-10-30 19:30:03.174 Day length: 09:41:00 Sun at south: 11:05:00
2018-10-30 19:30:03.174 Civil twilight start: 05:51:00 Civil twilight end: 16:44:00
2018-10-30 19:30:03.174 Nautical twilight start: 05:11:00 Nautical twilight end: 17:25:00
2018-10-30 19:30:03.174 Astronomical twilight start: 04:31:00 Astronomical twilight end: 18:04:00
2018-10-30 19:30:03.515 Active notification Subsystems: (0/13)
2018-10-30 19:30:03.642 Starting shared server on: :::6144
2018-10-30 19:30:03.174 Status: EventSystem: reset all events...
2018-10-30 19:30:03.504 Status: PluginSystem: Started, Python version '3.6.6'.
2018-10-30 19:30:03.529 Status: WebServer(HTTP) started on address: :: with port 8080
2018-10-30 19:30:03.637 Status: WebServer(SSL) started on address: :: with port 443
2018-10-30 19:30:03.640 Status: Proxymanager started.
2018-10-30 19:30:03.642 Status: TCPServer: shared server started...
2018-10-30 19:30:03.642 Status: RxQueue: queue worker started...
2018-10-30 19:30:05.643 Status: EventSystem: reset all events...
2018-10-30 19:30:05.644 Status: EventSystem: reset all device statuses...
2018-10-30 19:30:05.725 Status: PluginSystem: Entering work loop.
2018-10-30 19:30:05.736 Status: Python EventSystem: Initalizing event module.
2018-10-30 19:30:05.736 Status: EventSystem: Started
2018-10-30 19:30:05.736 Status: EventSystem: Queue thread started...
