hi
First time here, searched a lot on my issue, but can'f find anything close to it. So here it comes:
I have domoticz running on a synology
I added hardware Evohome with WEB api. So that went well
It added devices in the Setup/Devices list, so that was promising.
In the log I see
2018-10-21 20:27:35.867 (Evo Thermostat) fetch data from server
2018-10-21 20:28:37.028 (Evo Thermostat) fetch data from server
So it is fetching data, again very promising.
BUT I cannot see any device on temperature tab, it still says: No Temperature sensors found or added in the system...
So i'm lost, no logs with any errors or whatsoever, no hint of something went wrong. HOW can i get devices to show up on the usefull locations outside the SETUP menu. I really love some hints/help to get nice blocks on any other page to start working with the data.
anyone to chip in?
evohome web api not showing my devices
checkingnl
- Target OS: -
- waaren
Re: evohome web api not showing my devices
Did you press the small green Arrows on the right side of the device lines on the devices tab to enable them (and name the zones) ?checkingnl wrote: Sunday 21 October 2018 20:32 I added hardware Evohome with WEB api. So that went well
In the log I see
checkingnl
- Target OS: -
I did, as far as i can recall. But after removing and adding two times more and indeed the zones are visible now on the right tabs.. dunno what went wrong.. now next step is HUE bridge not loading bulbswaaren wrote: Sunday 21 October 2018 23:44Did you press the small green Arrows on the right side of the device lines on the devices tab to enable them (and name the zones) ?checkingnl wrote: Sunday 21 October 2018 20:32 I added hardware Evohome with WEB api. So that went well
In the log I see
- waaren
That might become a challenge if you are on the latest stable.
checkingnl
- Target OS: -
do you know what was the issue? i did see somthing on versions in june (beta's).. not seen any fix so farwaaren wrote: Monday 22 October 2018 9:34That might become a challenge if you are on the latest stable.In 4.9700 adding Hue bulbs or groups does not work. It is solved but the solution is only available in later beta's
- waaren
Pleas have a look here and herecheckingnl wrote: Monday 22 October 2018 9:41do you know what was the issue? i did see somthing on versions in june (beta's).. not seen any fix so farwaaren wrote: Monday 22 October 2018 9:34That might become a challenge if you are on the latest stable.In 4.9700 adding Hue bulbs or groups does not work. It is solved but the solution is only available in later beta's
checkingnl
- Target OS: -
ah.. great, thx a lot.waaren wrote: Monday 22 October 2018 10:11Pleas have a look here and herecheckingnl wrote: Monday 22 October 2018 9:41do you know what was the issue? i did see somthing on versions in june (beta's).. not seen any fix so farwaaren wrote: Monday 22 October 2018 9:34
will need to find if the version used in these http://www.jadahl.com/domoticz_beta_6.2_python/ is consumable
- waaren
You can just use the latest Beta from Jadahlcheckingnl wrote: Monday 22 October 2018 11:21ah.. great, thx a lot.waaren wrote: Monday 22 October 2018 10:11Pleas have a look here and herecheckingnl wrote: Monday 22 October 2018 9:41
will need to find if the version used in these http://www.jadahl.com/domoticz_beta_6.2_python/ is consumable![]()
checkingnl
- Target OS: -
beta works fine indeed. Nice to see beta be usable so far too
next is understanding virtual devices setup
