Howto set color of Color switch, RGBWW, Dimmer from Python?
Charger
Post by Charger »
I can control Yeelight color bulb from Domoticz web UI using "Color switch, RGBWW, Dimmer."
But I want to control this from the Python.
I can turn on/off the bulb and change its brighness:
import DomoticzEvents as DE
device = DE.changed_device
if device.name == "Xiaomi Wireless Switch":
    DE.Log(DE.Devices["Bulb 1"].Describe())
    DE.Command('Bulb 1', 'On')
    DE.Command('Bulb 1', 'Set Level 100 AFTER 0')
The code works and print in log:
ID: 1 Name: Bulb 1, Type: 241, subType: 4, switchType: 7, s_value: 24, n_value: 1, n_value_string: On, last_update_string: 2
But how to change the bulb's color? Desirable without sending HTTP requests.
I can change color via the web interface, so I believe there must be the way do this via DE.Command('Bulb 1', '...') but which command should be there?
StasDemydiuk
Re: Howto set color of Color switch, RGBWW, Dimmer from Python?
Post by StasDemydiuk »
Wow, @Charger where have you found this DomoticzEvents lib, I haven't imagine that it even exist.
I wonder if could share some docs how to use it.
tixi7
Post by tixi7 »
Not sure to understand your question. Do you want to update the graphical representation of the dimmer switch? or do you want to update the bulb itself?
For the former, I m looking at this also.
For the latter, you can get the rgb info from the Hue onCommand like that:
color_info=json.loads(Hue)
r=color_info["r"]
g=color_info["g"]
b=color_info["b"]
m=color_info["m"]
the color mode should be equal to 3 for color request.
elgringo
Domoticz version: Left
Post by elgringo »
I have the same problem; I want a python plugin to update a RGBWW device. I tried it via a JSON URL but the web interface remains the same...
StasDemydiuk
You can update switch color by passing Color property to Device.Update
n_value = 1
s_value = '1'
color = json.dumps({
  'ColorMode': 3, #mode 3: RGB
  'r': 255,
  'g': 255,
  'b': 255
Devices[0].Update(nValue=n_value, sValue=s_value, Color=color)
