I try to retrieve some values from a CSV file of my Resol solar boiler. I use a script to read from the file each minute. I checked the code within Zero Brain Studio and it is working fine.
When I try to run the code in Domoticz Events I get this error:
Error: EventSystem: in Update RESOL: [string "local m = os.date('%M')
..."]:10: attempt to index global 'bestand' (a nil value)
This is the code:
if (m % 1 == 0) then
--print("The minute script interval reached")
-- Put your script code here that shall run every 5 minutes
local regel = {}
mijnarray = {}
bestand = io.open("L://Output.csv","r")
i = 1
for line in bestand:lines() do
regel=line
i=i+1
-- print(i)
--print(regel[3]) -- dit is de juiste regel
j = 0
for token in string.gmatch(regel[3], "[^%s]+") do
--print(token)
j= j+1
mijnarray[j] = token
mijnarray[15] = mijnarray[15]/1000 -- in kWh ipv Wh
--print("temp buiten",mijnarray[4])
--print("temp binnen",mijnarray[5])
--print("pomp",mijnarray[12])
--print("totaal opwek",mijnarray[15])
commandArray['UpdateDevice']='42|0|mijnarray[4]'
commandArray['UpdateDevice']='43|0|mijnarray[5]'
commandArray['UpdateDevice']='44|0|mijnarray[12]'
commandArray['UpdateDevice']='45|0|mijnarray[15]'
print("waarde",mijnarray[15])
I used the Time tab.
Any thoughts?
Error in LUA script event
- Domoticz version: 4.9700
Re: Error in LUA script event
Please use the code display </> to share your program.
Os.date. Is it not a string value? Try with a tonumber https://www.domoticz.com/wiki/User_variables
Antoine
Antoine
Thx Tonio16,
Sorry, I will do that next time
I will try to use tonumber.
I think I have got it.
The LUA compiler is running on the PC (with a USB stick with the CSV file) So that works fine.
But... Domoticz is on a RPI and therefore Domoticz cannot find that file.
Can you please specify how to use the data in the output.csv file to sensors in Domoticz?
Much appreciated!
Joost
Much appreciated!
Joost
