TP-Link smart plug HS100/HS110
ollebull
Re: TP-Link smart plug HS100/HS110
Hi, i'm running Domoticz on a Windows machine can i still run this script so that i can control and read from HS110.
I saw for instance this line in your py-script " domain="http://rpi3:8080/" ", since i'm not a programmer i'm not sure how to replace this
for a windows machine, and if there more places that could be affected.
regards Ollebull
regards Ollebull
ajay100
- Domoticz version: 4.10717
Hi ollebull,
If you are running Domoticz on your Windows machine, have a look at your browser address bar to see how you are accessing Domoticz. It might be something like http://127.0.0.1:8080 or http://192.168.0.1:8080. Whatever is there, that's what you use for the domain= variable (with the trailing slash (/)) in the python script.
You need to have Python installed on your Windows PC, as Domoticz doesn't do that for you. This HS1xx script uses Python version 2, not version 3 (they are a little incompatible).
The way to check if you have python installed is to go to a command prompt (windows key-R, or Start -> run then type cmd) and then type python at the prompt. If you get a response rather than an error (such as ''python is not recognized as an internal or external command, operable program or batch file.") then you have python installed. The response will tell you which version is installed (2.x or 3.x).
If you need to install python, you can start with 'Windows x86 MSI installer' from https://www.python.org/downloads/windows/ (click the link 'Latest Python 2 Release - Python 2.7.xx'). Apparently Domoticz works best with the x86 version (not 64 bit).
Once you get to that point, your Windows PC should work as well as a linux box for python scripting. In the following post, you can see how the commands work: viewtopic.php?t=17391#p132472 but use .bat instead of .cmd.
This may be a bridge too far if you don't have a little experience with command prompts, etc. on Windows. I hope it helps.
Cheers - Andrew
Cheers - Andrew
Marco31
I've installed Domoticz on a raspberry to record the power consumption history with a HS-110.
I've successfully added the device to the dashboard and I'm able to control it
I have 2 questions about the data recovery :
1 - I don't understand how the "Virtual sensors" are linked to the hardware IP adress. I've simply added the idx of the sensors to the editable variables section of the script, but all the sensors are in red. Perhaps that's due to the script error return code?
2 - I get an error when I run the script with the energy option :
The info option works fine :
The generated debug shows that the values are correctly gathered :
Also, here it is the config section of the script :
Does someone have an idea please?
Thanks in advance.
pi@raspberrypi:/home/marc/domoticz/scripts/python$ ./tplink_hs110_1.py -c energy
File "./tplink_hs110_1.py", line 238, in <module>
hs.read_hs110()
File "./tplink_hs110_1.py", line 224, in read_hs110
self.send_json(received_data)
File "./tplink_hs110_1.py", line 155, in send_json
voltage = round(float(json_data['emeter']['get_realtime']['voltage_mv']) / 1000,2)
KeyError: 'voltage_mv'Code: Select all
pi@raspberrypi:/home/marc/domoticz/scripts/python$ ./tplink_hs110_1.py -c info
Sent: {"system":{"get_sysinfo":{}}}
Received: {"system":{"get_sysinfo":{"err_code":0,"sw_ver":"1.2.5 Build 180410 Rel.182657","hw_ver":"1.0","type":"IOT.SMARTPLUGSWITCH","model":"HS110(FR)","mac":"50:C7:BF:08:68:15","deviceId":"800643B60A0A5AA51473F47BFFD9E3FA1781ED98","hwId":"797CB3D09D9A83B1C43A623C6DD103C2","fwId":"00000000000000000000000000000000","oemId":"0D13F703F04C040DC3D27DB248C01A1A","alias":"My 1st Smart Plug","dev_name":"Wi-Fi Smart Plug With Energy Monitoring","icon_hash":"","relay_state":1,"on_time":17765,"active_mode":"schedule","feature":"TIM:ENE","updating":0,"rssi":-64,"led_off":0,"latitude":43.779649,"longitude":1.399550}}}Code: Select all
pi@raspberrypi:/home/marc/domoticz/scripts/python$ tail -4 hs110-1.log
2018-09-07 17:01:25,730:__main__:INFO:hs110-1 version 0.5 has started...
2018-09-07 17:01:25,777:__main__:DEBUG:Command: {"emeter":{"get_realtime":{}}}
2018-09-07 17:01:25,803:__main__:DEBUG:Sent: {"emeter":{"get_realtime":{}}}
2018-09-07 17:01:25,805:__main__:DEBUG:Received: {"emeter":{"get_realtime":{"current":0.644156,"voltage":230.228466,"power":80.957878,"total":0.262000,"err_code":0}}}
pi@raspberrypi:/home/marc/domoticz/scripts/python$ more tplink_hs110_1.py
#!/usr/bin/env python2
# Begin user editable variables
version = 0.5
logger_name = "hs110-1" #used for log file names, messages, etc
debug_level="DEBUG" # debug options DEBUG, INFO, WARNING, ERROR, CRITICAL
delay_time = 15 #update time in seconds
base_url = domain + "json.htm?type=command¶m=udevice&nvalue=0"
monitor_list = ["voltage","current","power","usage"]
domoticz_idx = [1,2,3,5]
hs110_ip = "192.168.1.64"
text_logging = True
track_state = True
hs110_switch_idx = 4
datafile_columns = "Time,Voltage,Current,Power (W),Usage (kWHr)"
dailyfile_columns = "Date-Time,Usage (kWHr)"
# End user editable variables
Thanks in advance.
ajay100
Hi Marco31,
It looks like you are really close to getting it working!
The other issue I came up against was having TABS in the file instead of spaces, particularly in the section.
If you copied the script directly from GitHub, it will depend on how you pasted/saved the script to the RPi as to whether these formatting errors may be an issue. BTW, I do my editing using FileZilla between the RPi and Notepad++ on a Windows 10 laptop.
Cheers - Andrew
The hardware IP address (hs110_ip variable) is used when reading or 'commanding' the HS110. There is no connection between the hardware IP and the Domoticz device indexes. What you have done in the config section looks fine, assuming your Domoticz URL is on http://rpi3:8080/. You are correct in assuming that the red devices in Domoticz are a result of the error you are seeing when running the script directly.1 - I don't understand how the "Virtual sensors" are linked to the hardware IP adress. I've simply added the idx of the sensors to the editable variables section of the script, but all the sensors are in red. Perhaps that's due to the script error return code?
Can you check that the tplink_hs110_1.py file has UNIX style line endings, which should be LF (Line Feed) only, not CRLF (Carriage Return Line Feed)? I am using Notepad++ and when I click the 'Show all characters' button, I can see the line endings. To convert in Notepad++, choose Edit -> EOL Conversion -> UNIX/OSX format.2 - I get an error when I run the script with the energy option :
commands = {
'info' : '{"system":{"get_sysinfo":{}}}',
'on' : '{"system":{"set_relay_state":{"state":1}}}',
'off' : '{"system":{"set_relay_state":{"state":0}}}',
'led_on' : '{"system":{"set_led_off":{"off":0}}}',
'led_off' : '{"system":{"set_led_off":{"off":1}}}',
'state' : '{"system":{"get_sysinfo":{}}}',
'cloudinfo': '{"cnCloud":{"get_info":{}}}',
'wlanscan' : '{"netif":{"get_scaninfo":{"refresh":0}}}',
'time' : '{"time":{"get_time":{}}}',
'schedule' : '{"schedule":{"get_rules":{}}}',
'countdown': '{"count_down":{"get_rules":{}}}',
'antitheft': '{"anti_theft":{"get_rules":{}}}',
'reboot' : '{"system":{"reboot":{"delay":1}}}',
'reset' : '{"system":{"reset":{"delay":1}}}',
'energy' : '{"emeter":{"get_realtime":{}}}'
}If you copied the script directly from GitHub, it will depend on how you pasted/saved the script to the RPi as to whether these formatting errors may be an issue. BTW, I do my editing using FileZilla between the RPi and Notepad++ on a Windows 10 laptop.
Cheers - Andrew
Marco31
Hi Andrew,
Many thanks for your reply. Unfortunately, I've checked all the points you've highlighted but still no success
For the Url section, I didn't modified it as I wasn't sure that it was useful. Now its set to "http://192.168.1.253:8080" which is the working Domoticz URL (tested with my laptop).
Also, I've followed the notepad++ instructions you've provided (make sense as I was in the situation where CRLF and now it's only LF.
I get exactly the same behavior than before.
Do you have anymore ideas please?
Thanks.
Cheers.
Marc
Thanks.
Cheers.
Marc
ajay100
Hi Marc,
I'm not a Python expert by any means but I will have a go. There's a good tutorial on KeyError here: https://airbrake.io/blog/python-excepti ... n-keyerror
TABS show as (->) and spaces as dots (.) when Show all Characters is turned on in Notepad++. I also have the Tab Settings set as 'Replace by space' in Notepad++ Preferences, so that TABs are not automatically added. If you checked and there are no TABS in this section instead of spaces, we need to debug a bit further.
Firstly I would try pasting the above dict code block directly over yours, just in case you are missing a minor formatting issue.
If that doesn't help, we can add an extra debugging line after json_data = (my line 146) to see what is coming through:
I see you have debug_level="DEBUG", which is the best option for catching problems. In addition to any error that may appear in the console, we can also look at the log file, as you have done. It is saved in the same folder as the program. (in my case HS110-1.log). For one power logging circuit, mine shows the following:
Also note my software and hardware versions are different from yours, which could suggest different firmware, although I'm a bit unsure about the dates (mine looks earlier):
Cheers - Andrew
The dict setup for us is the code below, so we can be fairly sure the problem is in that area.the KeyError is raised when accessing an invalid key within a dict.
commands = {
}Firstly I would try pasting the above dict code block directly over yours, just in case you are missing a minor formatting issue.
json_data = json.loads(received_data)
logger.debug("json_data: {}".format(json_data))There's nothing plugged in, so the current and power readings are very low.2018-09-15 11:53:23,780:__main__:DEBUG:Command: {"emeter":{"get_realtime":{}}}
2018-09-15 11:53:23,885:__main__:DEBUG:Sent: {"emeter":{"get_realtime":{}}}
2018-09-15 11:53:23,886:__main__:DEBUG:Received: {"emeter":{"get_realtime":{"voltage_mv":242153,"current_ma":14,"power_mw":0,"total_wh":2,"err_code":0}}}
2018-09-15 11:53:23,887:__main__:DEBUG:json_data: {u'emeter': {u'get_realtime': {u'total_wh': 2, u'current_ma': 14, u'power_mw': 0, u'voltage_mv': 242153, u'err_code': 0}}}
2018-09-15 11:53:23,887:__main__:DEBUG:IDX: 90, Item: voltage, Value: 242.15
2018-09-15 11:53:23,888:__main__:DEBUG:URL: http://rpi3:8080/json.htm?type=command& ... lue=242.15
2018-09-15 11:53:23,895:__main__:DEBUG:IDX: 91, Item: current, Value: 0.01
2018-09-15 11:53:23,896:__main__:DEBUG:URL: http://rpi3:8080/json.htm?type=command& ... value=0.01
2018-09-15 11:53:23,903:__main__:DEBUG:IDX: 108, Item: power, Value: 0.0
2018-09-15 11:53:23,904:__main__:DEBUG:URL: http://rpi3:8080/json.htm?type=command& ... svalue=0.0
2018-09-15 11:53:23,910:__main__:DEBUG:IDX: 93, Items: Power (W), Usage (kWhr), Values: 0.0;0.002
2018-09-15 11:53:23,911:__main__:DEBUG:URL: http://rpi3:8080/json.htm?type=command& ... ue=0.0;2.0
Good luck, I'm sure you're almost there! Please let us know either way.2018-09-15 11:53:08,757:__main__:DEBUG:Received: {"system":{"get_sysinfo":{"sw_ver":"1.2.10 Build 170828 Rel.104625","hw_ver":"2.0","type":"IOT.SMARTPLUGSWITCH","model":"HS110(AU)","mac":"xx:84:C6:3D:C0:xx","dev_name":"Smart Wi-Fi Plug With Energy Monitoring","alias":"TP-Link HS110 #1","relay_state":1,"on_time":5894,"active_mode":"none","feature":"TIM:ENE","updating":0,"icon_hash":"","rssi":-70,"led_off":0,"longitude_i":xx,"latitude_i":xx,"hwId":"A28C8BB92AFCB6CAFB83A8C00145F7E2","fwId":"00000000000000000000000000000000","deviceId":"8006B1553E3288EB95B589531A1EF88519FD5012","oemId":"6480C2101948463DC65D7009CAECDECC","err_code":0}}}
Cheers - Andrew
ajay100
Python3 version of the logger
I've just finished the Python3 version of the HS110 logger here https://github.com/ajay10000/TP-Link-HS110, with thanks to https://github.com/GadgetReactor/pyHS10 ... rotocol.py for the howto on the encryption and decryption routines.
Cheers - Andrew
Cheers - Andrew
Marco31
Hello Andrew,
Sorry for my late feedback but I was on holydays
So, I've checked again all the script and text format but looks fine.
I've also created anew version of it but using your new Python v3 script and I have exactly same behaviors.
After a long long time spent to analyse the logs and tries, I think I've spotted the issue :
for any reason (perhas the hw/sw which are not exactly the same), the returned values are in decimal format whereas yours are Integrers :
Mine :
Yours :
For example, if we look the voltage values, yours is 242153 millivolt whereas mine is 230.421503 volt.
I don't have found any related setting on the device itself.
I've tried to understand the code, but I'm not familiar with Python
Could you please confirm if you feel that I'm on the right direction and so, if you can instruct me what lines of the code I need to modifiy?
Thanks a lot.
Cheers.
Marc
Mine :
2018-10-02 17:49:29,430:__main__:DEBUG:Received: {"emeter":{"get_realtime":{"current":0.414566,"voltage":230.421503,"power":49.656850,"total":2.304000,"err_code":0}}}
2018-10-02 17:49:29,433:__main__:DEBUG:json_data: {'emeter': {'get_realtime': {'voltage': [b]230.421503[/b], 'power': 49.65685, 'current': 0.414566, 'total': 2.304, 'err_code': 0}}}
018-09-15 11:53:23,887:__main__:DEBUG:json_data: {u'emeter': {u'get_realtime': {u'total_wh': 2, u'current_ma': 14, u'power_mw': 0, u'voltage_mv': [b]242153[/b], u'err_code': 0}}}
Thanks a lot.
Cheers.
Marc
ajay100
Hi Marc,
That is a good pickup! It looks like your HS110 is returning the full values, which will simplify the code. We can try taking the division/rounding out and changing the key names as per what your unit is returning. Try changing these lines:
to this:
Hopefully that will do the trick.
current = round(float(json_data['emeter']['get_realtime']['current_ma']) / 1000,2)
power = round(float(json_data['emeter']['get_realtime']['power_mw']) / 1000,2)
usage = round(float(json_data['emeter']['get_realtime']['total_wh']) / 1000,3)Code: Select all
voltage = float(json_data['emeter']['get_realtime']['voltage'])
current = float(json_data['emeter']['get_realtime']['current'])
power = float(json_data['emeter']['get_realtime']['power'])
usage = float(json_data['emeter']['get_realtime']['total'])-
Marco31
Hi Andrew,
It worked like a charm
Thanks again for all your help.
Cheers.
Marc
Cheers.
Marc
ajay100
That's great news Marc, thanks for letting us know.
Cheers - Andrew
Cheers - Andrew
cerocca
- Domoticz version: V 4.9700
@ajay100 : I am trying to include my HS110 in my domoticz setup, so once find this thread I immediately tried it
unfortunately I am having similar (not the same) issues experienced by Marc
I created 4 devices (+ the switch, which I don't want to use) as in the attached screenshot, when I run the script I was getting same errors of Marc:
also info option was giving me same results, the difference is in the log file where I cannot see values correctly gathered :
anyhow I tried to remove the division/rounding out and changing the key names as per your post of October the 3rd.
What I get is the following, my terminal is stuck:
No output! And of course only by CTRL+C I can stop the script.
But as you can also see from the screenshot, my domoticz seems to receive the data, but why I don't get an output from the terminal?
How can I have the script running "forever" without issues?
Maybe I misconfigured the devices in Domoticz?
Any help would be appreciated, thanks since now!
pi@raspberrypi:~/domoticz/scripts/python $ python hs110.py -c energy
File "hs110.py", line 238, in <module>
hs.read_hs110()
File "hs110.py", line 224, in read_hs110
File "hs110.py", line 155, in send_json
pi@raspberrypi:~/domoticz/scripts/python $ tail -4 hs110-1a.log
2018-10-16 20:04:06,081:__main__:DEBUG:Command: {"system":{"get_sysinfo":{}}}
2018-10-16 20:04:06,099:__main__:DEBUG:Sent: {"system":{"get_sysinfo":{}}}
2018-10-16 20:04:06,101:__main__:DEBUG:Received: {"system":{"get_sysinfo":{"err_code":0,"sw_ver":"1.2.5 Build 171213 Rel.101523","hw_ver":"1.0","type":"IOT.SMARTPLUGSWITCH","model":"HS110(EU)","mac":"70:4F:57:1B:DB:37","deviceId":"800657AADA2A0C8635066D6ED760C98B18ECE692","hwId":"45E29DA8382494D2E82688B52A0B2EB5","fwId":"00000000000000000000000000000000","oemId":"3D341ECE302C0642C99E31CE2430544B","alias":"CiruPluggr","dev_name":"Wi-Fi Smart Plug With Energy Monitoring","icon_hash":"","relay_state":1,"on_time":786592,"active_mode":"schedule","feature":"TIM:ENE","updating":0,"rssi":-55,"led_off":0,"latitude":43.100680,"longitude":12.384625}}}
2018-10-16 20:04:06,103:__main__:DEBUG:URL: http://localhost:8080/json.htm?type=command¶m=udevice&idx=107&nvalue=1What I get is the following, my terminal is stuck:
^CTraceback (most recent call last):
File "ahs.py", line 242, in <module>
time.sleep(delay_time)
KeyboardInterruptBut as you can also see from the screenshot, my domoticz seems to receive the data, but why I don't get an output from the terminal?
- Schermata 2018-10-16 alle 19.50.41.png (41.68 KiB) Viewed 3193 times
ajay100
Hi cerocca,
Well done, you've got it working! Running in the looping mode, you will not see anything in the console and it will look like it's frozen. But you are getting the results in Domoticz, so that is good.
Now you can look at this post (if you haven't already done so) viewtopic.php?f=56&t=13290&p=188061&hilit=start#p188061 to see how I set mine up to start the script automatically at RPi startup. Then you don't need to type anything into the console unless you want to send a direct command (like switching the HS110 off and on, etc.)
Cheers - Andrew
Cheers - Andrew
cerocca
Hi ajay100 ,
thanks for the reply, glad to see that I have it working even without realizing it
I'll try ASAP the method you linked me to have the script running in loop, but may I ask you 3 further questions for my final/proper understanding?
1) why it is OK to don't see anything from the terminal? Did I "activate" the looping mode somehow in the script?
I ask this because if I check on your github page I understand that with the command should give me an output on terminal. Am I wrong?
2) are my devices associated properly? The code from my python script is as follows:
Then I associated this list to my devices as per the screenshot I sent in my previous message. Is this correct?
3) is it needed to create the switch, or it can be omitted?
thanks for your support and above all for your nice work!
python tplink_hs110.py -c energy2) are my devices associated properly? The code from my python script is as follows:
domoticz_idx = [18,19,20,21]3) is it needed to create the switch, or it can be omitted?
ajay100
Hi again cerocca,
1. Reading my original post, it wasn't as clear as it should have been, so I will fix that description in GitHub! The important sentence is
So, the command does activate the 'looping' mode as you say. It can be called from the console, but won't provide an output in the terminal, the results shown are actually from the logs. Except for testing, it is better run from a startup script.
Most of the other commands (other than 'energy') will provide a direct output in the terminal. i.e. (to turn the switch on) or (to get complete device information from the HS110).
2. From your Domoticz output, it looks like your hs_volt and hs_amp devices are correct, but you may have hs_elec and hs_usag around the wrong way. My kWh device is for usage and I am using a Custom Sensor for power (Watts). Swap 20 and 21 around where you are setting your index values and see if the results logged in Domoticz make sense. i.e.
3. You can leave your code as it is and the switch will not be activated unless you send a command directly, such as .
It's great to get your feedback, thanks!
Andrew
.If 'energy' is used in the command line as above, the data is sent to Domoticz using JSON. If any other command is used, the switch will respond directly and show the result following the command.
So, the command
python tplink_hs110.py -c energyMost of the other commands (other than 'energy') will provide a direct output in the terminal. i.e.
python tplink_hs110.py -c offCode: Select all
python tplink_hs110.py -c info2. From your Domoticz output, it looks like your hs_volt and hs_amp devices are correct, but you may have hs_elec and hs_usag around the wrong way. My kWh device is for usage and I am using a Custom Sensor for power (Watts). Swap 20 and 21 around where you are setting your index values and see if the results logged in Domoticz make sense. i.e.
domoticz_idx = [18,19,21,20]Code: Select all
python tplink_hs110.py -c onIt's great to get your feedback, thanks!
Andrew
cerocca
ajay100,
Thanks for your support, but I cannot get proper readings for usage and power, which is my main scope us using the HS110 in my domoticz setup.
Would you be so kind to tell me exactly how you create these devices?
I mean, from "hardware" tab, which kind of virtual sensors you create (and which idx do they correspond in your code) ?
ajay100
Hi @cerocca,
My HS110 hardware type in Domoticz is: Dummy (Does nothing, use for virtual switches only)
For these settings in code:
My Device settings in Domoticz are:
voltage, index 90 is Sensor type: Voltage. This shows as Type General, SubType Voltage
current, index 91 is Sensor type: Ampere (1 phase). This shows as Type General, SubType Current
power, index 108 is Custom Sensor, Sensor Type: Custom Sensor, Axis Label: Watts. This shows as Type General, SubType Custom Sensor
usage, index 93 is Sensor Type: Electric (Instant + Counter). This shows in the devices list as SubType kWh. It shows both power (watts) and usage (kWh).
usage, index 93 could also be Sensor Type: Counter Incremental (see EDIT below), as shown below. I've only just tried that one!
Cheers - Andrew
[EDIT] Counter Incremental doesn't look right for this purpose. I'm trying Counter now.
domoticz_idx = [90,91,108,93]voltage, index 90 is Sensor type: Voltage. This shows as Type General, SubType Voltage
Cheers - Andrew
- HS110 power.jpg (14.09 KiB) Viewed 3148 times
- HS110 usage.jpg (11.77 KiB) Viewed 3148 times
Hi there,
This plugin work with HS100?
https://github.com/dahallgren/domoticz-tplink-smartplug
It is a on/off plugin, or show the energy usage?
somebody able to test it?
ajay100
Hi @vamp, it looks like it does both from the code. I don't have an HS100 to test, but I will try it with the HS110 when I can get some time.
Cheers - Andrew
Cheers - Andrew
I will be glad if you able to test it! I will plan to buy some and it will be good if they work with domoticz without any modification (firmware update, scripting, etc...)ajay100 wrote: Thursday 18 October 2018 15:23 Hi @vamp, it looks like it does both from the code. I don't have an HS100 to test, but I will try it with the HS110 when I can get some time.
Cheers - Andrew
