OTGW plugin stops functioning every hour or so
For OpenTherm-gateway related questions in Domoticz
mvzut
Post by mvzut »
My OTGW (connected to my Raspberry Pi 3 via a USB-to-serial cable) has worked for a few years with hardly any problems. But since the last half year or so it seems to lose connection VERY often. I have set a data timeout so it reconnects automatically every time, but it is very annoying to see this appear in the error log approximately once every 1-2 hours.
Are more people experiencing this problem? Looking at Github, I don't think the plugin code has really changed for already quite some time. Maybe I should just remove the plugin and add it again to see if that helps, but I'm reluctant to do this since I will lose all my historic data that way.
sincze
Domoticz version: 2024.4
Re: OTGW plugin stops functioning every hour or so
Post by sincze »
It just disconnects or are you experiencing wdt resets?
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
mvzut
Post by mvzut »
sincze wrote:It just disconnects or are you experiencing wdt resets?
It says "Nothing received for more than x minutes" (depending on how you set the timeout). If I don't set a timeout, the devices stop being updated after a while.
sincze
Post by sincze »
mvzut wrote: Wednesday 17 October 2018 20:29
It say "Nothing received for more than x minutes" (depending on how you set the timeout). If I don't set a timeout, the devices stop being updated after a while.
Mmm that I have that as well but in addition I have a WDT reset :*opentherm 4.2.5* message in the log. In the end I have to trigger a hardware reset on the otgw itself to have it back on its feed again.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
