Failed to open file options.xml
przemhb
Post by przemhb »
In /var/log/messages log Domoticz placed messages saying there is a problem with opening options.xml file and OZW log file.
Surprisingly it fails to open options.xml file. I've installed Domoticz package using Fedora's 28 x64 DNF.
What is causing the problem and how to fix it?
Error, Cannot find a path to the configuration files at /usr/bin/Config/, Using /etc/openzwave/ instead...
Info, Reading /etc/openzwave/options.xml for Options
Warning, Failed to Parse /usr/share/domoticz/options.xml: Failed to open file
and addidiotnally:
Could Not Open OZW Log File.
Log:
audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=domoticz comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2018-10-15 23:41:38.294 Sunrise: 07:14:00 SunSet: 17:49:00
2018-10-15 23:41:38.294 Day length: 10:35:00 Sun at south: 12:05:00
2018-10-15 23:41:38.294 Civil twilight start: 06:38:00 Civil twilight end: 18:25:00
2018-10-15 23:41:38.294 Nautical twilight start: 05:57:00 Nautical twilight end: 19:06:00
2018-10-15 23:41:38.294 Astronomical twilight start: 05:15:00 Astronomical twilight end: 19:47:00
2018-10-15 23:41:38.711 Active notification Subsystems: pushover (1/13)
2018-10-15 23:41:38.780 Starting shared server on: :::6144
2018-10-15 23:41:41.301 Error, Cannot find a path to the configuration files at /usr/bin/Config/, Using /etc/openzwave/ instead...
2018-10-15 23:41:41.328 Info, Reading /etc/openzwave/options.xml for Options
2018-10-15 23:41:41.329 Warning, Failed to Parse /usr/share/domoticz/options.xml: Failed to open file
2018-10-15 23:41:41.329 Info, Options:
2018-10-15 23:41:41.329 Info, appendlogfile: false
2018-10-15 23:41:41.329 Info, associate: true
2018-10-15 23:41:41.329 Info, assumeawake: true
2018-10-15 23:41:41.329 Info, autoupdateconfigfile: false
2018-10-15 23:41:41.329 Info, configpath: /etc/openzwave/
2018-10-15 23:41:41.329 Info, consoleoutput: true
2018-10-15 23:41:41.329 Info, customsecuredcc: 0x62,0x4c,0x63
2018-10-15 23:41:41.330 Info, drivermaxattempts: 5
2018-10-15 23:41:41.330 Info, dumptriggerlevel: 4
2018-10-15 23:41:41.330 Info, enablesis: true
2018-10-15 23:41:41.330 Info, enforcesecurereception: true
2018-10-15 23:41:41.330 Info, exclude:
2018-10-15 23:41:41.330 Info, include:
2018-10-15 23:41:41.330 Info, interface:
2018-10-15 23:41:41.330 Info, intervalbetweenpolls: true
2018-10-15 23:41:41.330 Info, logfilename: OZW_Log.txt
2018-10-15 23:41:41.331 Info, logging: true
2018-10-15 23:41:41.331 Info, networkkey: [cut-out]
2018-10-15 23:41:41.331 Info, notifyondriverunload: false
2018-10-15 23:41:41.331 Info, notifytransactions: false
2018-10-15 23:41:41.331 Info, performreturnroutes: true
2018-10-15 23:41:41.331 Info, pollinterval: 60000
2018-10-15 23:41:41.331 Info, queueloglevel: 4
2018-10-15 23:41:41.331 Info, refreshallusercodes: false
2018-10-15 23:41:41.331 Info, reloadafterupdate: AWAKE
2018-10-15 23:41:41.331 Info, retrytimeout: 10000
2018-10-15 23:41:41.332 Info, saveconfiguration: true
2018-10-15 23:41:41.332 Info, saveloglevel: 4
2018-10-15 23:41:41.332 Info, securitystrategy: SUPPORTED
2018-10-15 23:41:41.332 Info, suppressvaluerefresh: false
2018-10-15 23:41:41.332 Info, userpath: /usr/share/domoticz/
2018-10-15 23:41:41.332 Info, validatevaluechanges: true
2018-10-15 23:41:41.333 Always, OpenZwave Version 1.5.0 Starting Up
2018-10-15 23:41:58.133 OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2018-10-15 23:41:58.136 OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2018-10-15 23:41:58.136 OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2018-10-15 23:42:02.552 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2018-10-15 23:42:02.552 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2018-10-15 23:42:02.552 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2018-10-15 23:42:02.581 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2018-10-15 23:42:02.681 OpenZWave: Value_Added: Node: 16 (0x10), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2018-10-15 23:42:02.764 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2018-10-15 23:42:03.050 OpenZWave: Value_Added: Node: 20 (0x14), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2018-10-15 23:42:03.306 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2018-10-15 23:42:03.427 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2018-10-15 23:42:03.582 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2018-10-15 23:42:03.697 OpenZWave: Value_Added: Node: 24 (0x18), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2018-10-15 23:42:03.983 OpenZWave: Value_Added: Node: 25 (0x19), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2018-10-15 23:42:04.254 OpenZWave: Value_Added: Node: 26 (0x1a), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2018-10-15 23:42:04.483 OpenZWave: Value_Added: Node: 29 (0x1d), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2018-10-15 23:42:04.545 OpenZWave: Value_Added: Node: 30 (0x1e), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
