Dashticz beta: set colors.
I have upgraded to the latest dashticz beta. This works great, except on the colors of the icons...
in my old configuration I used the fa-male and fa-female icons.
In the CUSTOM.CSS I had the text:
.fa.fa-male.on {color: green}
.fa.fa-male.off {color: red}
.fa.fa-female.on {color: green}
.fa.fa-female.off {color: red}
The beta uses a different icon set, so I had to change the icon to fas fa-male and fas fa-female.
However, text below in CUSTOM.CSS does not color my icons;
.fa.fas fa-male.on {color: green}
.fa.fas fa-male.off {color: red}
.fa.fas fa-female.on {color: green}
.fa.fas fa-female.off {color: red}
ALready tried many other configuration options, as shown in https://www.domoticz.com/wiki/Dashticz_ ... Lightbulbs
However, also these do not work.
So what happens: The correct icon is shown. The color is white when "on" and grey when "off".
What am I missing?????
- Domoticz version: 4.10717
Re: Dashticz beta: set colors.
For e.g. this works for me:
.fas.fa-fire {color: red}
.fas.fa-fire {color: green}
So I think you should change the names to:
.fas-fa-male.on {color: green}
.fas-fa-male.off {color: red}
.fas-fa-female.on {color: green}
.fas-fa-female.off {color: red}
Dashticz V2.4.0 Beta
Try the following:
Thanks all for your help... unfortunately both do not work.
To be sure: The file should be CUSTOM.CSS (all in capitals), correct?
any other ideas?
any other ideas?
It looks like that it does not look at the CUSTOM.CSS file. When I change something, nothing happens.
Also it should in the CUSTOM map, the same as CONFIG.js, correct?
Nevermind.... filename should be custom.css.
For support of others, the contents of custom.css should be look a like:
.fas.fa-male.on {color: green}
- HansieNL
The off lightbulb is .far and the on is .fas. You don't have to use .on or .off anymore for the lightbulb. far = regular and fas = solid.
For an overview of all fonts: https://fontawesome.com/icons?d=gallery&m=free
Blah blah blah
- Minglarn
- Domoticz version: v3.8153
Did anyone solved this icon issue?
Having the same strange not loading the right icon problem..
How should I name the icons so it loads into Dash?
Edit: To early in the morning i guess.
The icons now show up... but i cant change the color..
Any idea?
CUSTOM CSS FILE
.fa-power-off.on.icon {font-size: 50px !; color: #00FF00;}
.fa-power-off.off.icon {font-size: 30px !important;color: #FF0000;}
.fa-bell.on.icon {font-size: 50px !; color: #FF0000;}
.fa-bell.icon {font-size: 30px !important;color: #00FF00;}
.fa-user-secret.icon {font-size: 50px !; color: red;}
.fas fa-power-off {font-size: 50px !; color: #00FF00;}
.far power-off.off {font-size: 30px !important;color: #FF0000;}
.fas fa-bell {font-size: 50px !; color: #FF0000;}
.far fa-bell {font-size: 30px !important;color: #00FF00;}
“When you eliminate the impossible, whatever remains, however improbable, must be the truth.” -Spock in Star Trek VI
These are switches for which you selected a custom icon via the blocks[IDX]['icon']='fas fa-power-off' and blocks[IDX]['icon']='fas fa-bell' in CONFIG.js?Minglarn wrote: ↑Friday 02 November 2018 9:31 Did anyone solved this icon issue?
How should I name the icons so it loads into Dash?Code: Select all
/* CUSTOM CSS FILE */ .fa-power-off.on.icon {font-size: 50px !; color: #00FF00;} .fa-power-off.off.icon {font-size: 30px !important;color: #FF0000;} .fa-bell.on.icon {font-size: 50px !; color: #FF0000;} .fa-bell.icon {font-size: 30px !important;color: #00FF00;} .fa-user-secret.icon {font-size: 50px !; color: red;}
Edit: To early in the morning i guess.![]()
The icons now show up... but i cant change the color..Any idea?Code: Select all
.fas fa-power-off {font-size: 50px !; color: #00FF00;} .far power-off.off {font-size: 30px !important;color: #FF0000;} .fas fa-bell {font-size: 50px !; color: #FF0000;} .far fa-bell {font-size: 30px !important;color: #00FF00;}
And you want to set different colors depending on the on/off state? Let's do the size in a second step.
'fas', 'fa-bell' and 'fa-power-off' are classes which can be used in your custom.css to select the right element. Dashticz add to switches the 'on' or 'off' class depending on the state. If you have an element that you want to select has two classes, you connect them in your custom.css with a '.'
That means a CSS selector for a power-off icon in the off state is: .fa-power-off.off
In the on state: .fa-power-off.on
So I guess the following should be working
.fa-power-off.on { color: #00FF00;}
.fa-power-off.off {color: #FF0000;}
.fa-bell.on { color: #FF0000;}
.fa-bell.off {color: #00FF00;}
- Minglarn
Thanks for the help.. Now it works...
