Is it a bug or something misconfigured?
The Eurotronik Spirit thermostat is unknown to Domoticz 4.9980, what means at first
EUROtronic Unknown: type=0003, id=0001+
Second in the config folder
hamster@delphi:/volume1/@appstore/domoticz/Config/eurotronic$ ls
eur_cometz.xml eur_stellaz.xml
Will this thermostat ever be included? No configuration possible at the moment, beta Domoticz did not fix that up. Just downloaded a 4.9999 beta archive, the Spiritz is missing there too.
Edit: Got the required eur_spiritz.xml from github and changed the manufactor file, now even older Domoticz version recognize the valve with correct name and device channels. But it seems to be unstable, setpoints won't work as ecpected and the valve get lost after some hours, unable to heal it back into the network.
Greetz
Solderbro
Eurotronic Spirit unknown in 4.9980
- Solderbro
- Domoticz version: 2020.1
Raspi 3B+RTC, SSD 128GB, Aeotec Gen5, Eurotronic SpiritZ, Fibaro FRGBW, Zipato PIR, Everspring AN180, Neo Coolcam Plug, Fibaro FGMS, Neo Coolcam Doorsensor, Popp Z-Weather
- raymond1972
- Domoticz version: 2021.1
Re: Eurotronic Spirit unknown in 4.9980
Hello Solderbro.
Did you try this? http://www.domoticz.com/forum/viewtopic ... it#p193935
After that you need to delete and re-include your Spirit.
The next thing is to control it, but i'm busy in some other forums to get that answer
HW:Raspberry Pi 3 B, Raspian stretch, Nano, Aeon Labs Aeotec Gen 5 Z-Wave USB
Raspberry Pi 4, Raspian buster, Nano, Aeon Labs Aeotec Gen 5 Z-Wave USB
- Solderbro
Yes this workaround looks okay, now the Spirit is known by name and can be controlled through the heating temp.
Solderbro
Solderbro
