moroen wrote: ↑Friday 12 October 2018 14:10
mdenouden wrote: ↑Friday 12 October 2018 14:04
mdenouden wrote: ↑Friday 12 October 2018 13:54
So far it's only on initialization, when (re)starting Domoticz.
At the moment it's three LED lights with one motion sensor. Haven't bought the new outlets yet.
Sorry, answered to soon, did some testing shortly after the above reply. The error also logged when I change the state of one of the lamps via the Tradfri app:
2018-10-12 13:57:56.513 Error: (Tradfri) 'onMessage' failed 'KeyError'.
2018-10-12 13:57:56.513 Error: (Tradfri) ----> Line 290 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py', function onMessage
2018-10-12 13:57:56.513 Error: (Tradfri) ----> Line 214 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py', function onMessage
2018-10-12 13:57:56.513 Error: (Tradfri) ----> Line 131 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py', function updateDeviceState
The state of the lamp DOES update correctly in Domoticz. So the polling works.
Further research showed that the error occurred because I set 'Add groups as devices' to 'Yes' in the plugin configuration. After switching that off there's no error anymore. Does that make sense?
Could you please set debug to true, and post the log including lines before and after this error message?
2018-10-12 14:30:53.103 Status: (Tradfri) Started.
2018-10-12 14:30:53.289 Status: (Tradfri) Entering work loop.
2018-10-12 14:30:53.289 Status: (Tradfri) Initialized version 1.0.6, author 'moroen'
2018-10-12 14:30:55.048 (Tradfri) 7b 22 61 63 74 69 6f 6e 22 3a 20 22 67 65 74 4c 69 67 68 74 {"action":."getLight
2018-10-12 14:30:55.048 (Tradfri) 73 22 7d .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. s"}
2018-10-12 14:30:55.054 (Tradfri) Pushing 'ReadEvent' on to queue
2018-10-12 14:30:55.099 (Tradfri) Processing 'ReadEvent' message
2018-10-12 14:30:55.099 (Tradfri) Received 1258 bytes of data
2018-10-12 14:30:55.099 (Tradfri) 7b 22 72 65 73 75 6c 74 22 3a 20 5b 7b 22 4e 61 6d 65 22 3a {"result":.[{"Name":
2018-10-12 14:30:55.099 (Tradfri) 20 22 4c 61 6d 70 20 68 61 6c 22 2c 20 22 54 79 70 65 22 3a ."Lamp.hal",."Type":
2018-10-12 14:30:55.099 (Tradfri) 20 22 4c 69 67 68 74 22 2c 20 22 44 69 6d 6d 61 62 6c 65 22 ."Light",."Dimmable"
2018-10-12 14:30:55.099 (Tradfri) 3a 20 74 72 75 65 2c 20 22 48 61 73 57 42 22 3a 20 66 61 6c :.true,."HasWB":.fal
2018-10-12 14:30:55.099 (Tradfri) 73 65 2c 20 22 44 65 76 69 63 65 49 44 22 3a 20 36 35 35 33 se,."DeviceID":.6553
2018-10-12 14:30:55.099 (Tradfri) 37 2c 20 22 48 61 73 52 47 42 22 3a 20 66 61 6c 73 65 7d 2c 7,."HasRGB":.false},
2018-10-12 14:30:55.099 (Tradfri) 20 7b 22 4e 61 6d 65 22 3a 20 22 46 69 6c 6d 6c 61 6d 70 22 .{"Name":."Filmlamp"
2018-10-12 14:30:55.099 (Tradfri) 2c 20 22 54 79 70 65 22 3a 20 22 4c 69 67 68 74 22 2c 20 22 ,."Type":."Light",."
2018-10-12 14:30:55.099 (Tradfri) 44 69 6d 6d 61 62 6c 65 22 3a 20 74 72 75 65 2c 20 22 48 61 Dimmable":.true,."Ha
2018-10-12 14:30:55.099 (Tradfri) 73 57 42 22 3a 20 66 61 6c 73 65 2c 20 22 44 65 76 69 63 65 sWB":.false,."Device
2018-10-12 14:30:55.100 (Tradfri) 49 44 22 3a 20 36 35 35 33 38 2c 20 22 48 61 73 52 47 42 22 ID":.65538,."HasRGB"
2018-10-12 14:30:55.100 (Tradfri) 3a 20 66 61 6c 73 65 7d 2c 20 7b 22 4e 61 6d 65 22 3a 20 22 :.false},.{"Name":."
2018-10-12 14:30:55.100 (Tradfri) 4c 61 6d 70 20 62 6f 76 65 6e 20 64 65 20 74 61 66 65 6c 22 Lamp.boven.de.tafel"
2018-10-12 14:30:55.100 (Tradfri) 2c 20 22 54 79 70 65 22 3a 20 22 4c 69 67 68 74 22 2c 20 22 ,."Type":."Light",."
2018-10-12 14:30:55.100 (Tradfri) 44 69 6d 6d 61 62 6c 65 22 3a 20 74 72 75 65 2c 20 22 48 61 Dimmable":.true,."Ha
2018-10-12 14:30:55.100 (Tradfri) 73 57 42 22 3a 20 74 72 75 65 2c 20 22 44 65 76 69 63 65 49 sWB":.true,."DeviceI
2018-10-12 14:30:55.100 (Tradfri) 44 22 3a 20 36 35 35 33 39 2c 20 22 48 61 73 52 47 42 22 3a D":.65539,."HasRGB":
2018-10-12 14:30:55.100 (Tradfri) 20 66 61 6c 73 65 7d 2c 20 7b 22 4e 61 6d 65 22 3a 20 22 47 .false},.{"Name":."G
2018-10-12 14:30:55.100 (Tradfri) 72 6f 75 70 20 2d 20 57 6f 6f 6e 6b 61 6d 65 72 22 2c 20 22 roup.-.Woonkamer",."
2018-10-12 14:30:55.100 (Tradfri) 54 79 70 65 22 3a 20 22 47 72 6f 75 70 22 2c 20 22 44 69 6d Type":."Group",."Dim
2018-10-12 14:30:55.100 (Tradfri) 6d 61 62 6c 65 22 3a 20 74 72 75 65 2c 20 22 48 61 73 57 42 mable":.true,."HasWB
2018-10-12 14:30:55.100 (Tradfri) 22 3a 20 66 61 6c 73 65 2c 20 22 44 65 76 69 63 65 49 44 22 ":.false,."DeviceID"
2018-10-12 14:30:55.100 (Tradfri) 3a 20 31 33 31 30 37 34 7d 2c 20 7b 22 4e 61 6d 65 22 3a 20 :.131074},.{"Name":.
2018-10-12 14:30:55.101 (Tradfri) 22 47 72 6f 75 70 20 2d 20 48 61 6c 22 2c 20 22 54 79 70 65 "Group.-.Hal",."Type
2018-10-12 14:30:55.101 (Tradfri) 22 3a 20 22 47 72 6f 75 70 22 2c 20 22 44 69 6d 6d 61 62 6c ":."Group",."Dimmabl
2018-10-12 14:30:55.101 (Tradfri) 65 22 3a 20 74 72 75 65 2c 20 22 48 61 73 57 42 22 3a 20 66 e":.true,."HasWB":.f
2018-10-12 14:30:55.101 (Tradfri) 61 6c 73 65 2c 20 22 44 65 76 69 63 65 49 44 22 3a 20 31 33 alse,."DeviceID":.13
2018-10-12 14:30:55.101 (Tradfri) 31 30 37 37 7d 5d 2c 20 22 73 74 61 74 75 73 22 3a 20 22 4f 1077}],."status":."O
2018-10-12 14:30:55.101 (Tradfri) 6b 22 2c 20 22 61 63 74 69 6f 6e 22 3a 20 22 67 65 74 4c 69 k",."action":."getLi
2018-10-12 14:30:55.101 (Tradfri) 67 68 74 73 22 7d 7b 22 72 65 73 75 6c 74 22 3a 20 5b 7b 22 ghts"}{"result":.[{"
2018-10-12 14:30:55.101 (Tradfri) 4e 61 6d 65 22 3a 20 22 4c 61 6d 70 20 68 61 6c 22 2c 20 22 Name":."Lamp.hal",."
2018-10-12 14:30:55.101 (Tradfri) 4c 65 76 65 6c 22 3a 20 32 35 34 2c 20 22 53 74 61 74 65 22 Level":.254,."State"
2018-10-12 14:30:55.101 (Tradfri) 3a 20 66 61 6c 73 65 2c 20 22 44 65 76 69 63 65 49 44 22 3a :.false,."DeviceID":
2018-10-12 14:30:55.101 (Tradfri) 20 36 35 35 33 37 2c 20 22 48 65 78 22 3a 20 6e 75 6c 6c 7d .65537,."Hex":.null}
2018-10-12 14:30:55.101 (Tradfri) 5d 2c 20 22 73 74 61 74 75 73 22 3a 20 22 4f 6b 22 2c 20 22 ],."status":."Ok",."
2018-10-12 14:30:55.101 (Tradfri) 61 63 74 69 6f 6e 22 3a 20 22 64 65 76 69 63 65 55 70 64 61 action":."deviceUpda
2018-10-12 14:30:55.101 (Tradfri) 74 65 22 7d 7b 22 72 65 73 75 6c 74 22 3a 20 5b 7b 22 4e 61 te"}{"result":.[{"Na
2018-10-12 14:30:55.102 (Tradfri) 6d 65 22 3a 20 22 46 69 6c 6d 6c 61 6d 70 22 2c 20 22 4c 65 me":."Filmlamp",."Le
2018-10-12 14:30:55.102 (Tradfri) 76 65 6c 22 3a 20 31 32 37 2c 20 22 53 74 61 74 65 22 3a 20 vel":.127,."State":.
2018-10-12 14:30:55.102 (Tradfri) 66 61 6c 73 65 2c 20 22 44 65 76 69 63 65 49 44 22 3a 20 36 false,."DeviceID":.6
2018-10-12 14:30:55.102 (Tradfri) 35 35 33 38 2c 20 22 48 65 78 22 3a 20 6e 75 6c 6c 7d 5d 2c 5538,."Hex":.null}],
2018-10-12 14:30:55.102 (Tradfri) 20 22 73 74 61 74 75 73 22 3a 20 22 4f 6b 22 2c 20 22 61 63 ."status":."Ok",."ac
2018-10-12 14:30:55.102 (Tradfri) 74 69 6f 6e 22 3a 20 22 64 65 76 69 63 65 55 70 64 61 74 65 tion":."deviceUpdate
2018-10-12 14:30:55.102 (Tradfri) 22 7d 7b 22 72 65 73 75 6c 74 22 3a 20 5b 7b 22 4e 61 6d 65 "}{"result":.[{"Name
2018-10-12 14:30:55.102 (Tradfri) 22 3a 20 22 4c 61 6d 70 20 62 6f 76 65 6e 20 64 65 20 74 61 ":."Lamp.boven.de.ta
2018-10-12 14:30:55.102 (Tradfri) 66 65 6c 22 2c 20 22 4c 65 76 65 6c 22 3a 20 32 35 34 2c 20 fel",."Level":.254,.
2018-10-12 14:30:55.102 (Tradfri) 22 53 74 61 74 65 22 3a 20 66 61 6c 73 65 2c 20 22 44 65 76 "State":.false,."Dev
2018-10-12 14:30:55.102 (Tradfri) 69 63 65 49 44 22 3a 20 36 35 35 33 39 2c 20 22 48 65 78 22 iceID":.65539,."Hex"
2018-10-12 14:30:55.102 (Tradfri) 3a 20 22 66 31 65 30 62 35 22 7d 5d 2c 20 22 73 74 61 74 75 :."f1e0b5"}],."statu
2018-10-12 14:30:55.102 (Tradfri) 73 22 3a 20 22 4f 6b 22 2c 20 22 61 63 74 69 6f 6e 22 3a 20 s":."Ok",."action":.
2018-10-12 14:30:55.102 (Tradfri) 22 64 65 76 69 63 65 55 70 64 61 74 65 22 7d 7b 22 72 65 73 "deviceUpdate"}{"res
2018-10-12 14:30:55.103 (Tradfri) 75 6c 74 22 3a 20 5b 7b 22 4e 61 6d 65 22 3a 20 22 57 6f 6f ult":.[{"Name":."Woo
2018-10-12 14:30:55.103 (Tradfri) 6e 6b 61 6d 65 72 22 2c 20 22 4c 65 76 65 6c 22 3a 20 30 2c nkamer",."Level":.0,
2018-10-12 14:30:55.103 (Tradfri) 20 22 53 74 61 74 65 22 3a 20 66 61 6c 73 65 2c 20 22 44 65 ."State":.false,."De
2018-10-12 14:30:55.103 (Tradfri) 76 69 63 65 49 44 22 3a 20 31 33 31 30 37 34 7d 5d 2c 20 22 viceID":.131074}],."
2018-10-12 14:30:55.103 (Tradfri) 73 74 61 74 75 73 22 3a 20 22 4f 6b 22 2c 20 22 61 63 74 69 status":."Ok",."acti
2018-10-12 14:30:55.103 (Tradfri) 6f 6e 22 3a 20 22 64 65 76 69 63 65 55 70 64 61 74 65 22 7d on":."deviceUpdate"}
2018-10-12 14:30:55.103 (Tradfri) 7b 22 72 65 73 75 6c 74 22 3a 20 5b 7b 22 4e 61 6d 65 22 3a {"result":.[{"Name":
2018-10-12 14:30:55.103 (Tradfri) 20 22 48 61 6c 22 2c 20 22 4c 65 76 65 6c 22 3a 20 30 2c 20 ."Hal",."Level":.0,.
2018-10-12 14:30:55.103 (Tradfri) 22 53 74 61 74 65 22 3a 20 74 72 75 65 2c 20 22 44 65 76 69 "State":.true,."Devi
2018-10-12 14:30:55.103 (Tradfri) 63 65 49 44 22 3a 20 31 33 31 30 37 37 7d 5d 2c 20 22 73 74 ceID":.131077}],."st
2018-10-12 14:30:55.103 (Tradfri) 61 74 75 73 22 3a 20 22 4f 6b 22 2c 20 22 61 63 74 69 6f 6e atus":."Ok",."action
2018-10-12 14:30:55.103 (Tradfri) 22 3a 20 22 64 65 76 69 63 65 55 70 64 61 74 65 22 7d .. .. ":."deviceUpdate"}
2018-10-12 14:30:55.104 (Tradfri) Pushing 'onMessageCallback' on to queue
2018-10-12 14:30:55.105 (Tradfri) Pushing 'onMessageCallback' on to queue
2018-10-12 14:30:55.105 (Tradfri) Processing 'onMessageCallback' message
2018-10-12 14:30:55.105 (Tradfri) Calling message handler 'onMessage'.
2018-10-12 14:30:55.106 (Tradfri) Registering: {"Name": "Lamp hal", "Dimmable": "true", "HasRGB": "false", "Type": "Light", "DeviceID": 65537, "HasWB": "false"}
2018-10-12 14:30:55.106 (Tradfri) Registering: {"Name": "Filmlamp", "Dimmable": "true", "HasRGB": "false", "Type": "Light", "DeviceID": 65538, "HasWB": "false"}
2018-10-12 14:30:55.106 (Tradfri) Registering: {"Name": "Lamp boven de tafel", "Dimmable": "true", "HasRGB": "false", "Type": "Light", "DeviceID": 65539, "HasWB": "true"}
2018-10-12 14:30:55.107 (Tradfri) Registering: {"Name": "Group - Woonkamer", "Type": "Group", "DeviceID": 131074, "Dimmable": "true", "HasWB": "false"}
2018-10-12 14:30:55.107 (Tradfri) Registering: {"Name": "Group - Hal", "Type": "Group", "DeviceID": 131077, "Dimmable": "true", "HasWB": "false"}
2018-10-12 14:30:55.107 (Tradfri) Processing 'onMessageCallback' message
2018-10-12 14:30:55.107 (Tradfri) Calling message handler 'onMessage'.
2018-10-12 14:30:55.107 (Tradfri) {'Name': 'Lamp hal', 'DeviceID': 65537, 'Level': 254, 'Hex': '', 'State': 'false'}
2018-10-12 14:30:55.107 (Tradfri - Lamp hal) Updating device from 0:'101' to have values 0:'101'.
2018-10-12 14:30:55.114 (Tradfri) Processing 'onMessageCallback' message
2018-10-12 14:30:55.114 (Tradfri) Calling message handler 'onMessage'.
2018-10-12 14:30:55.114 (Tradfri) {'Name': 'Filmlamp', 'DeviceID': 65538, 'Level': 127, 'Hex': '', 'State': 'false'}
2018-10-12 14:30:55.115 (Tradfri - Filmlamp) Updating device from 0:'50' to have values 0:'50'.
2018-10-12 14:30:55.121 (Tradfri) Processing 'onMessageCallback' message
2018-10-12 14:30:55.121 (Tradfri) Calling message handler 'onMessage'.
2018-10-12 14:30:55.122 (Tradfri) {'Name': 'Lamp boven de tafel', 'DeviceID': 65539, 'Level': 254, 'Hex': 'f1e0b5', 'State': 'false'}
2018-10-12 14:30:55.122 (Tradfri - Lamp boven de tafel) Updating device from 0:'101' to have values 0:'101'.
2018-10-12 14:30:55.128 (Tradfri - Lamp boven de tafel - WB) Updating device from 0:'20' to have values 0:'20'.
2018-10-12 14:30:55.136 (Tradfri) Processing 'onMessageCallback' message
2018-10-12 14:30:55.136 (Tradfri) Calling message handler 'onMessage'.
2018-10-12 14:30:55.136 (Tradfri) {'Name': 'Woonkamer', 'DeviceID': 131074, 'Level': 0, 'State': 'false'}
2018-10-12 14:30:55.136 (Tradfri) {'Name': 'Hal', 'DeviceID': 131077, 'Level': 0, 'State': 'true'}
2018-10-12 14:30:55.136 Error: (Tradfri) 'onMessage' failed 'KeyError'.
2018-10-12 14:30:55.136 Error: (Tradfri) ----> Line 290 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py', function onMessage
2018-10-12 14:30:55.136 Error: (Tradfri) ----> Line 214 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py', function onMessage
2018-10-12 14:30:55.136 Error: (Tradfri) ----> Line 131 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py', function updateDeviceState
2018-10-12 14:30:55.137 Error: (Tradfri) 'onMessage' failed 'KeyError'.
2018-10-12 14:30:55.137 Error: (Tradfri) ----> Line 290 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py', function onMessage
2018-10-12 14:30:55.137 Error: (Tradfri) ----> Line 214 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py', function onMessage
2018-10-12 14:30:55.137 Error: (Tradfri) ----> Line 131 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py', function updateDeviceState
2018-10-12 14:31:03.290 (Tradfri) Pushing 'onHeartbeatCallback' on to queue
2018-10-12 14:31:03.302 (Tradfri) Processing 'onHeartbeatCallback' message
2018-10-12 14:31:03.302 (Tradfri) Calling message handler 'onHeartbeat'.
