Hello. I need get lastUpdate.minutesAgo (or hoursAgo) for security state.
For example i need switch boiler to standby mode if my Dz had "Armed Away" state more than 2 days...
lastUpdate.minutesAgo for security state - how? [Solved]
- waaren
Re: lastUpdate.minutesAgo for security state - how?
The field lastUpdate does not exist for the Domoticz Security Panel in dzVents. The workaround for this could be a script like
-- security.lua
on = { security = { domoticz.SECURITY_ARMEDAWAY,
domoticz.SECURITY_ARMEDHOME,
domoticz.SECURITY_DISARMED },
timer = {"every 10 minutes" },
data = { securityState = { history = true, maxItems = 1 }},
logging = { level = domoticz.LOG_DEBUG,
marker = "Security" },
execute = function(dz, item )
if dz.data.securityState.get(1) == nil then
dz.data.securityState.add("Initialized") -- Initialize persistent historical variable (= data + timestamp)
dz.log(item.trigger,dz.LOG_DEBUG)
if item.isSecurity then
dz.data.securityState.add(item.trigger) -- Store state to persistent historical variable (= data + timestamp)
safedSecurityState = dz.data.securityState.get(1)
dz.log("Security state set to: " .. safedSecurityState.data .. ", " ..
safedSecurityState.time.secondsAgo .." seconds ago.",dz.LOG_DEBUG) -- retrieve state and set time secondsAgo
- Domoticz version: 3.9272
May be easiest way write user variable? (and read it from another scripts) I think it is possible do with dzvents and more universal. What do you think?
- waaren
Yes, good idea ! Write the uservariable with my script and read it with other (your) scripts. Let me know if you cannot get it working.
- waaren
Re: lastUpdate.minutesAgo for security state - how? [Solved]
Like this ?
Set
--[[ setSecurityState.lua
Before first execution of this script, the vars "SecurityStateModifyTime" and "SecurityState" need to be created as type string.
values can be left empty
marker = "setSecurityState" },
execute = function(dz,item)
local securityState = dz.variables("SecurityState")
local securityStateTime = dz.variables("SecurityStateModifyTime")
local function setVars(str)
if securityState.value ~= str then
securityState.set(str)
securityStateTime.set(dz.time.raw)
setVars(item.trigger)
--[[ getSecurityState.lua
this is a script to demonstrate how to get the states from the security panel and lastupdate time of this state.
The update of the variables is done by the setSecurityState script and that script must have run at least once before this one
on = { devices = { "securityTrigger" }}, -- Just for test purposes.
execute = function(dz)
-- Get securityState and time set
local Time = require('Time')
local t = Time(securityStateTime.value)
dz.log("Security state set to: " .. securityState.value .. ", " ..
t.secondsAgo .." seconds ago.") -- retrieve state and set time secondsAgo
