Danalock V3 On / Off / On Command
l00pz
Post by l00pz »
After using Stable Build 4.9700 for a few weeks, I jumped the gun yesterday and updated my Domoticz installation to the latest Beta with build commit 5936d70. After installing this commit (and also commit 4b274d47 from today) I noticed that my Z-wave Danalock V3 gets an On / Off / On command when I try to unlock or lock the lock (this issue wasn't present in the latest Stable build). These On / Off / On commands happen within 10 seconds after pushing the button, and therefore I get a Z-wave Time-out from my lock in the Log and I'm unable to use Notifications on the lock as I get three messages. First I thought this had something to do with my lock so I excluded the lock from my Z-wave Network and rejoined it, but the same "problem" stays after rejoining the Z-wave and doing a full reset of the lock. I disable the event system as a test to be sure that not an Event was doing this, but also then the problem stays. The log of the Lock states the following:
Am I the only one who has this issue, or are there more people who have this issue? I did make a Back-up of my Stable installation, but restoring this would mean I would lose 1,5 days of Logging of my Solar Panels and P1 as I discovered this issue 1,5 after doing the update.
murat
Re: Danalock V3 On / Off / On Command
Post by murat »
Related to your experience, did you had the danalock working on domoticz v4.97? I strugle with controling the danalock v3 with latest firmware.
can you share your experience with this?
thanks
Murat
