i had find on internet a tutorial to link a Jura Cofee machine to homeassistant
and now i want connect it to domoticz
can sambody help me? my programming skils are not so good.
i have flash the sketch to the nodemcu and control it via the webpage of de esp8266
but now i want it connect to domoticz
i have try in putty "curl -d AN:01 192.168.1.20/api"
nothing hapend on the jura and i got a response "Bad Request"
this is the tutorial i used: https://community.home-assistant.io/t/c ... hine/26604
am i doing somthing wrong?
Controlling Jura Cofee machine
Re: Controlling Jura Cofee machine
Nobody have a solution for this?
I have done it with a Senseo...
Cheers, Hans
Cheers, Hans
- Domoticz version: 4.10717
Hello everybody,
I have a similar question. I also have a Jura Coffee machine. I noticed you can add a special Bluetooth dongle to this machines. They call this Jura J.O.E.. With an Android or IOS app, you can make a cop of coffee. Or you can see some statistics. So, this dongle adds connectivity.
If Bluetooth and an app can be used for connection, maybe other options may work as well. Anybody realized a connection with Domoticz?
I consider buying this J.O.E. dongle. I have a RPi with domoticz within BT-range.
Regards,
Zatarra
Regards,
Zatarra
- MadMedic
- Domoticz version: 2020.2
*bump*
Any progress on this front ?
"Life is too short for bad coffee"
- FireWizard
