is it possible to trigger scripts by device's state?
rkarolek
Post by rkarolek »
Is it possible to run script in specified time range, but only if some devices are off?
For example id like to check if lights are off after lets say 8pm,
if not id like to try switch them off and check in 5min,
if yes id like not to start script any more.
I hope you can understand my problem :)
emme
Domoticz version: latest
Re: is it possible to trigger scripts by device's state?
Post by emme »
you can trigger by state change in a specific time window using:
    devices = { 'mylight' = { 'between 20:00 and 20:05' }
but to answer you question I assume it could be like:
    timer= { 'every 5 minutes between 20.00 and 23:59' }
   execute = function(domoticz, security)
      domoticz.devices('mylight').switchOff().checkFirst()
this will check at 20:00, 20:05, 20:10 etc etc and switch off your light only if needed
ciao
M
"We always done this way"
rkarolek
Post by rkarolek »
yes, i know that, but script is triger and in case many scripts can make some mesh in network.
would be nice if script will triger for example between 8 and 10pm but only if specify device value is on.
rkarolek wrote: Wednesday 03 October 2018 13:24 Is it possible to run script in specified time range, but only if some devices are off?
My preference would be to use the approach @emme used but if you don't want to execute your script, a dzVents solution could be
-- active when function returns true (  )
local myTimerange = "at 15:33-15:55"       -- your Timeslot
local myLightIDX  = 535            	-- Your light's idx
    active = function(domoticz)                                -- This function will be evaluated every minute by the dzVents system
                myLight = domoticz.devices(myLightIDX)
                return myLight.state == "On"
            end,
    on     = {  timer   = { myTimerange .. " every 5 minutes" }},
    execute = function(dz)
       myLight.switchOff()
emme
Post by emme »
rkarolek wrote: Wednesday 03 October 2018 15:28 yes, i know that, but script is triger and in case many scripts can make some mesh in network.
script like the above does not mesh....
the .checkFirst() function switch the lights off ONLY if needed, but... I assume you want a timer within that window... so
if lights is switched on between 8pm and 10pm then switch it off after 5 minutes... right?
ok.. if so:
    devices = {
        'mylight' = { 'between 20:00 and 22:00' }
   execute = function(domoticz, myLight)
        domoticz.devices('mylight').cancelQueuedCommands()
        if myLight.state == 'On' then
            domoticz.devices('mylight').switchOff().afterMin(5)
the script is triggered ONLY between 8 and 10 pm and WHEN the myLight device changes its state (On/Off)
if on.. empty the queued messages and apply an Off Command delayed 5 mins
so... it'n 9pm...
Manual Switch On ==> queued 5 min before Off
Manual Switch Off ==> Delayed Off Command Canceled
after 5 mins ==> Auto Off
rkarolek
Post by rkarolek »
ty emme for your help, but its not exactly what i need.
i use domoticz to control lights in my aquarium, during last holidays i had problem with conection between my nodes.
I set lights switch and lights off in specific time (two lamps, so two on and two off times), coz my problem with mysensor networks lights not on or what worse not off. Now i try secure for next time. at the moment i triger script every minute and check lights by .checkFirst(), but i though that it can be made in other (maybe simple) way.
I hope no more problem with network but..... its just for secure (end for knowing somethin new :))
i try analyze waaren's code, but im new in dzvents, so its a bit strange for me, have to read more about it :)
emme
Post by emme »
I think (from a domoticz point of view) there are no many other ways to handle it with less script/traffic.
You said you're working on MySensors, I had it too and I discontinued it due to communication issue (nrf24 are not so brilliant as I supposed) and even using the new model did not fix my comm problems.
It could be that your problem is not on domoticz, but on mysensors....
do you have the possibility to use a different framework (like Esp8266 and WiFi)?
rkarolek wrote: Wednesday 03 October 2018 17:06 i try analyze waaren's code, but im new in dzvents, so its a bit strange for me, have to read more about it :)
Let me try to help. Probably the confusing part is
           end,
dzVents first looks at "active" to determine if the script should be executed or not. Whatever you assign to "active" ; as long it is not nil or false, will be considered as true. You can do this explicit by entering
active = true
but here we do it implicit and based on the evaluation of the state of your light. The function will return true if the light is on and false otherwise. In order to be able to do the evaluation of the light's state, we have to pass the domoticz object to the function. I we don't do that, the function will not have access to information of all the domoticz devices.
This is not as bad as it sounds because Lua tables (and here the domoticz object is a Lua table) and functions, userdata and threads are reference types (sort of pointer). So we don't cause a lot of overhead because we only pass that reference to the function.
Hope this clarifies.
rkarolek
Post by rkarolek »
@emme, you right, i have some esp-01 with easyesp working as wirelesss sensor and no problem with them.
already bought ESP2866 wemos and if will have another problem with mysensor network ill switch to ESP, but now seem all works fine (after upgrades all nodes to 2.3 and added 100u capacitor on NRF24)
@waaren, tyvm it looks great, i didnt know about active section, (missed it in manual?), so have to train it a bit :)
