Fibaro FGS221 only showing one switch
doh
Post by doh »
I am running Domoticz V3.8373 on an RPi3 with an Aeon Lab Z-Stick S2.
Most of my devices run fine, but I am having trouble with my FGS221, which is installed within a light switch housing (other devices in the same room work fine).
The FGS221 is correctly identified in Domoticz and OZW, but only a single switch is shown instead of the two there should be.
This used to work fine, but for some reason the 2nd switch has disappeared.
I have removed and re-added the device, deleted the OZWCfg file, rebooted domoticz, etc. and nothing seems to bring back the missing switch.
Any ideas?
Are these devices known to be problematic, and would I be better moving to something like a TKB Double Relay Wall Switch instead? Or even a cheap lightwave double wall switch? (I use it to control inside and outside lights in my garden cabin/office).
Thanks in advance!
doh
Re: Fibaro FGS221 only showing one switch
Post by doh »
No-one??
Ascari
Domoticz version: 4.9
Post by Ascari »
I have the same issue.
A solution ?
rrozema
Post by rrozema »
Same issue here. It is not specific for the Fibaro switches though: I have similar issues with all other devices that have multiple nodes, for example: aeotec multi sensor 6, Neo coolcam 2 gang wall switch, Neo coolcam PIR[url], [url=https://products.z-wavealliance. ... ring ST814 and indeed the Fibaro FG-223. I am on the latest beta (Version: 4.10022), currently built from sources, but same thing happens with the latest beta downloaded, and it also happened when I had the latest stable release installed. Z-wave support is really broken (in many ways) at least since the latest stable release. beta has been a little better, in that betas at the time of latest stable did still recognise multi node devices, but beta is now broken too. Devices behave differently: some go dead, others only give a timeout, for some one partial device works, the other doesn't do anything, for yet another one device in domoticz now suddenly controls another lamp (lamp is on the same z-wave device, but the wrong node gets triggered, the other node is dead), some other devices simply do nothing at all anymore and so on. Unable to remove some devices that are no longer in my network: if I delete them from my z-wave devices, after a reboot they are back in the list. Oh, and battery level has been broken for years already and it is still broken. And for info: I always include my devices using "secure include".
Some assorted error messages I found scrolling through domoticz.log:
Error: ZWave: Node not found! (NodeID: 35, 0x23)
Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 35, 0x23)
Status: OpenZWave: Received timeout notification from HomeID: 3401436029, NodeID: 30 (0x1e)
Status: OpenZWave: Received timeout notification from HomeID: 3401436029, NodeID: 11 (0x0b)
Error: Error sending switch command, DevID: 301, Time: 2018-10-01 18:51:01
from scrolling through OZW_log.txt, also some notable messages:
Error, Node035, ERROR: Dropping command, expected response not received after 1 attempt(s)
Error, Node038, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
Error, Node038, ERROR: Dropping command, expected response not received after 2 attempt(s)
Error, Node039, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
Detail, Node039, Notification: Notification - TimeOut
Error, Node041, ERROR: Dropping command, expected response not received after 1 attempt(s)
Detail, Unsolicited message received while waiting for ACK.
Detail, Node012, Notification: Notification - TimeOut
Error, Node015, ERROR: Dropping command because node is presumed dead
Error, Node018, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
Warning, Node028, WARNING: Unexpected Callback ID received
Error, Node028, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
Detail, Node052, Notification: Notification - TimeOut
These 3 go together:
Warning, Node010, Received a Clear Text Message for the CommandClass COMMAND_CLASS_ASSOCIATION which is Secured
Warning, Node010, Dropping Message
Detail, Node010, Received: 0x01, 0x0b, 0x00, 0x04, 0x10, 0x0a, 0x05, 0x85, 0x03, 0x02, 0x05, 0x00, 0x6e
And another sequence that struck my attention (for a 2 gang neo wall switch):
Info, Node057, Sending (Send) message (Callback ID=0x61, Expected Reply=0x04) - MultiChannelAssociationCmd_Get (Node=57): 0x01, 0x0a, 0x00, 0x13, 0x39, 0x03, 0x8e, 0x02, 0x02, 0x25, 0x61, 0x16
Detail, Node057, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
Detail, Node057, ZW_SEND_DATA delivered to Z-Wave stack
Detail, Node057, Received: 0x01, 0x07, 0x00, 0x13, 0x61, 0x01, 0x00, 0x05, 0x8e
Detail, Node057, ZW_SEND_DATA Request with callback ID 0x61 received (expected 0x61)
Info, Node057, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
Warning, Node057, WARNING: Device is not a sleeping node.
Detail, Node001, Expected callbackId was received
Detail, Node057, Received: 0x01, 0x07, 0x00, 0x13, 0x61, 0x00, 0x00, 0x49, 0xc3
Detail, Node057, ZW_SEND_DATA Request with callback ID 0x61 received (expected 0x00)
Warning, Node057, WARNING: Unexpected Callback ID received
Error, Node057, ERROR: Dropping command, expected response not received after 1 attempt(s)
Detail, Node030, Received: 0x01, 0x26, 0x00, 0x04, 0x10, 0x1e, 0x20, 0x98, 0x81, 0x0b, 0xcc, 0xae, 0x52, 0x04, 0xe7, 0xb7, 0x7b, 0x99, 0xe6, 0x4e, 0x5c, 0x5c, 0x0b, 0x0b, 0x74, 0x3e, 0x31, 0x7c, 0xbc, 0x5c, 0xa9, 0xe7, 0x76, 0x91, 0x02, 0xd7, 0x3b, 0xe6, 0x5a, 0xd3
Warning, Node030, A Nonce with id a9 does not exist
Warning, Node030, Could Not Retrieve Nonce for Node 30
I am pretty close to giving up on Domoticz. I am going to spend another day or 2 doing a complete reinstall of my entire setup (fresh install, exclude/reset and include all devices and if that doesn't work I'm going to give Home Assistant a try. The only thing that's keeping me with Domoticz for now is dzVentz....
Ascari
Post by Ascari »
My solution :
I have a old RPI Domoticz working with fgs221, I copy the xml file parameter for my node 14 (the fgs221) and past in my new reboot domoticz and magic it's work
rrozema
Post by rrozema »
I've got at least 12 devices I would have to do that for...
emme
Domoticz version: latest
Post by emme »
got the same issue qith a FGS222.... use S2, restart domoticz.... wait up to 1hour....
the second switch will appear in the device list....
"We always done this way"
ferrangl
Post by ferrangl »
You've said that copy the xml file parameter for your node. From where to where did you copy?
Maybe is possible to only touch the file and restart?
