Add HA bridge to Domoticz
As of now i've been using Domoticz quite a while..
The thing is i want to use HA bridge to control my harmony hub and Hue system
I run Domoticz on windows server 2016 as service everything works well except, connect HA bridge to Domoticz...
I can connect to my HA bridge setup what is running on a Raspberry pi 3, when i push the link button in HA and after that in Domoticz register, i get a key...
But it is not showing any devices from HA.
My ports 80 are open in the network.... i can ping to both machines so the connection is there.
In HA bridge i cannot acces Domoticz devices.. i get an error 500
In domoticz i cannot acces HA bridge
What is the problem here?
- waaren
Re: Add HA bridge to Domoticz
My HA bridge runs on my Synology NAS and I have domoticz instances on RPI's.wou5er wrote: Saturday 29 September 2018 18:52 .... I want to use HA bridge to control my harmony hub and Hue system
They are both in my home network 192.168.nnn
In domoticz I configured "Local Networks (no username/password):" [Setup] [ Settings] [System] as
127.0.0.*;192.168.nnn.*
127.0.0.* // local host
192.168.nnn.* // home network (replace 192.168.nnn by that part of your home network
and press [Apply settings]
Now you can enter in the HA-Bridge [HA Bridge][Bridge Control] the domoticz IP and domoticz port and leave the username password blank
If you have not blocked any ports on your home network, the HA bridge should pick up all devices / scenes and groups from your domoticz system.
If you press the build button on a device it will compose the json for you that will switch the device / scene / group.
Please be aware that these composed json string are not usable for sensors. You have to modify them manual (look at https://www.domoticz.com/wiki/Domoticz_ ... N_URL's for the correct format / syntax.
I do not understand this. HA bridge does send to domoticz and ask domoticz for info but I am not aware of any domoticz initiated actions from domoticz to the bridge ?In domoticz i cannot acces HA bridge
Hope this help
This is the part where domoticz recognize ha bridge added devices.. but in domoticz there arent any devices from my HA bridge...I do not understand this. HA bridge does send to domoticz and ask domoticz for info but I am not aware of any domoticz initiated actions from domoticz to the bridge ?In domoticz i cannot acces HA bridge
Hope this help
on my windows server i got port 80 open as port 8080 so i should see the devices in my device page in domoticz... but that doesn't
- waaren
Still don't understand. As far as I know, no devices added to the ha-bridge, are to be created in domoticz. Do I miss something ?wou5er wrote: Sunday 30 September 2018 22:17 This is the part where domoticz recognize ha bridge added devices.. but in domoticz there arent any devices from my HA bridge...
yes, the point is i need to control my habridge devices with domoticz not the other way around,waaren wrote: Sunday 30 September 2018 23:15Still don't understand. As far as I know, no devices added to the ha-bridge, are to be created in domoticz. Do I miss something ?wou5er wrote: Sunday 30 September 2018 22:17 This is the part where domoticz recognize ha bridge added devices.. but in domoticz there arent any devices from my HA bridge...
- waaren
That is not how the ha-bridge concept work.wou5er wrote: Monday 01 October 2018 6:53yes, the point is i need to control my habridge devices with domoticz not the other way around,waaren wrote: Sunday 30 September 2018 23:15Still don't understand. As far as I know, no devices added to the ha-bridge, are to be created in domoticz. Do I miss something ?wou5er wrote: Sunday 30 September 2018 22:17 This is the part where domoticz recognize ha bridge added devices.. but in domoticz there arent any devices from my HA bridge...
thats true but this way should work also... in the past it did! but now it isn't working...waaren wrote: Monday 01 October 2018 8:21That is not how the ha-bridge concept work.wou5er wrote: Monday 01 October 2018 6:53yes, the point is i need to control my habridge devices with domoticz not the other way around,waaren wrote: Sunday 30 September 2018 23:15
Add the ha bridge as a phillips hue device under hardware
the only thing that is different is that domotic's is running on Window server 2016 and Habridge on a PI... where it in the past both on the pi was
- waaren
Ah.. Now I understand what you try to do. Does it still work when you install the ha-bridge on the PI where domoticz is active ?wou5er wrote: Monday 01 October 2018 9:31 thats true but this way should work also... in the past it did! but now it isn't working...
Domoticz is active on a windows server 2016waaren wrote: Monday 01 October 2018 9:50Ah.. Now I understand what you try to do. Does it still work when you install the ha-bridge on the PI where domoticz is active ?wou5er wrote: Monday 01 October 2018 9:31 thats true but this way should work also... in the past it did! but now it isn't working...
Ha bridge on the pi..
So to answer your question, i really don't know
Well I can now acces Domoticz devices with HA bridge but acces HA devices with domoticz not...waaren wrote: Monday 01 October 2018 9:50Ah.. Now I understand what you try to do. Does it still work when you install the ha-bridge on the PI where domoticz is active ?wou5er wrote: Monday 01 October 2018 9:31 thats true but this way should work also... in the past it did! but now it isn't working...
HA bridge is connect tot domoticz... domoticz log is ok... but it isn't showing the devices of HA bridge anyone any idea what is happening here, and what i'm doing wrong/forget?
