Influx-Grafana and Domoticz Stable 3.8153
febalci
Post by febalci »
I am trying to use Infux and Grafana with Domoticz Stable 3.8153. As seen at the image attached, i can send many values to Influx and can see the plots on Garafana. However, the ones marked with red arrow refuses to go to Influx Database, no errors, simply no values at all. The screenshot is from Settings-Data Push-InfluxDB, i tried Settings-Data Push-HTTPLink but that didn't worked with any values at all. These devices are simply dummy devices, which are fed by either mqtt, plugin or something else. What am i doing wrong?
Screen Shot 2018-04-22 at 17.27.09.jpg (160.52 KiB) Viewed 4190 times
dziadzi
Re: Influx-Grafana and Domoticz Stable 3.8153
Post by dziadzi »
I have the same issue, I can easily export type Status or Temperature or Humidity, but I cannot export Alert or Concentration to InfluxDB.
Does anyone have a solution??
foxingdemon
Post by foxingdemon »
My temperatures on direct Target Type don't update to InfluxDB. Everything else seems to work fine.
febalci
Post by febalci »
As i see, only the native Domoticz plugins feed the influx db; if you feed the Domoticz db directly with curl, mqtt or python plugin it is not sent to influx.
foxingdemon
My devices are Xiaomi sensors. Problem is only with Temperature, not Pressure or Humidity.
wywywywy
Post by wywywywy »
Hi folks,
If you can use Prometheus instead of InfluxDB, I just published an exporter to connect Prometheus with Domoticz, so you can get the data into Grafana.
https://github.com/wywywywy/domoticz_exporter
