Problems with Kaipule IM20 Door Sensor
dzdm
Post by dzdm »
Hi!
I'm having some difficulties getting the Kaipule IM20 Door/Window Sensors to work reliably. The problem is the following:
The sensors usually work without problems (report open/close states), but sometimes, the sensors report
a state change (for example on->off) even though nobody opened or closed the window during this time.
I've already changed the "Auto report status time" (Parameter 3) to 0 to disable auto reports, but the
problem still persists. Example:
2018-09-24 20:54:03 Off (Incorrect, the window is still open)
2018-09-24 09:07:44 On (Correct, I've opened the window)
Here is a OZW log of the incorrect state change at 20:54:03:
2018-09-24 20:54:00.047 Detail, Node009, Received: 0x01, 0x05, 0x00, 0x46, 0x4a, 0x00, 0xf6
2018-09-24 20:54:00.047 Info, Node009, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE for node 9 - SUCCESS
2018-09-24 20:54:00.047 Detail, Expected callbackId was received
2018-09-24 20:54:00.047 Detail, Expected reply was received
2018-09-24 20:54:00.047 Detail, Message transaction complete
2018-09-24 20:54:00.047 Detail, Node009, Removing current message
2018-09-24 20:54:00.047 Detail, Notification: ControllerCommand - Completed
2018-09-24 20:54:00.047 Info, Node009, Sending (WakeUp) message (Callback ID=0x0d, Expected Reply=0x13) - NoOperation_Set (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x00, 0x00, 0x25, 0x0d, 0xc6
2018-09-24 20:54:00.055 Detail, Node009, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-09-24 20:54:00.055 Detail, Node009, ZW_SEND_DATA delivered to Z-Wave stack
2018-09-24 20:54:00.071 Detail, Node009, Received: 0x01, 0x07, 0x00, 0x13, 0x0d, 0x00, 0x00, 0x02, 0xe4
2018-09-24 20:54:00.071 Detail, Node009, ZW_SEND_DATA Request with callback ID 0x0d received (expected 0x0d)
2018-09-24 20:54:00.071 Info, Node009, Request RTT 23 Average Request RTT 23
2018-09-24 20:54:00.071 Detail, Expected callbackId was received
2018-09-24 20:54:00.071 Detail, Expected reply was received
2018-09-24 20:54:00.071 Detail, Message transaction complete
2018-09-24 20:54:00.071 Detail, Node009, Removing current message
2018-09-24 20:54:00.071 Detail, Node009, Notification: Notification - NoOperation
2018-09-24 20:54:00.071 Detail, Node009, Query Stage Complete (CacheLoad)
2018-09-24 20:54:00.071 Detail, Node009, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Associations live=1
2018-09-24 20:54:00.071 Detail, Node009, QueryStage_Associations
2018-09-24 20:54:00.071 Info, Node009, Number of association groups reported for node 9 is 2.
2018-09-24 20:54:00.071 Info, Node009, Get Associations for group 1 of node 9
2018-09-24 20:54:00.071 Detail, Node009, Queuing (Send) AssociationCmd_Get (Node=9): 0x01, 0x0a, 0x00, 0x13, 0x09, 0x03, 0x85, 0x02, 0x01, 0x25, 0x4b, 0x04
2018-09-24 20:54:00.071 Detail, Node009, Queuing (Query) Query Stage Complete (Associations)
2018-09-24 20:54:00.071 Info, Node009, Sending (Send) message (Callback ID=0x4b, Expected Reply=0x04) - AssociationCmd_Get (Node=9): 0x01, 0x0a, 0x00, 0x13, 0x09, 0x03, 0x85, 0x02, 0x01, 0x25, 0x4b, 0x04
2018-09-24 20:54:00.079 Detail, Node009, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-09-24 20:54:00.079 Detail, Node009, ZW_SEND_DATA delivered to Z-Wave stack
2018-09-24 20:54:00.095 Detail, Node009, Received: 0x01, 0x07, 0x00, 0x13, 0x4b, 0x00, 0x00, 0x02, 0xa2
2018-09-24 20:54:00.095 Detail, Node009, ZW_SEND_DATA Request with callback ID 0x4b received (expected 0x4b)
2018-09-24 20:54:00.095 Info, Node009, Request RTT 23 Average Request RTT 23
2018-09-24 20:54:00.095 Detail, Expected callbackId was received
2018-09-24 20:54:00.121 Detail, Node009, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x09, 0x06, 0x85, 0x03, 0x01, 0x01, 0x00, 0x01, 0x7f
2018-09-24 20:54:00.121 Info, Node009, Response RTT 50 Average Response RTT 50
2018-09-24 20:54:00.121 Info, Node009, Received Association report from node 9, group 1, containing 1 associations
2018-09-24 20:54:00.121 Info, Node009, The group contains:
2018-09-24 20:54:00.121 Info, Node009, Node 1
2018-09-24 20:54:00.122 Info, Node009, Get Associations for group 2 of node 9
2018-09-24 20:54:00.122 Detail, Node009, Queuing (Send) AssociationCmd_Get (Node=9): 0x01, 0x0a, 0x00, 0x13, 0x09, 0x03, 0x85, 0x02, 0x02, 0x25, 0x4c, 0x00
2018-09-24 20:54:00.122 Detail, Node009, Expected reply and command class was received
2018-09-24 20:54:00.122 Detail, Node009, Message transaction complete
2018-09-24 20:54:00.122 Detail, Node009, Removing current message
2018-09-24 20:54:00.122 Info, Node009, Sending (Send) message (Callback ID=0x4c, Expected Reply=0x04) - AssociationCmd_Get (Node=9): 0x01, 0x0a, 0x00, 0x13, 0x09, 0x03, 0x85, 0x02, 0x02, 0x25, 0x4c, 0x00
2018-09-24 20:54:00.130 Detail, Node009, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-09-24 20:54:00.130 Detail, Node009, ZW_SEND_DATA delivered to Z-Wave stack
2018-09-24 20:54:00.146 Detail, Node009, Received: 0x01, 0x07, 0x00, 0x13, 0x4c, 0x00, 0x00, 0x02, 0xa5
2018-09-24 20:54:00.146 Detail, Node009, ZW_SEND_DATA Request with callback ID 0x4c received (expected 0x4c)
2018-09-24 20:54:00.146 Info, Node009, Request RTT 24 Average Request RTT 23
2018-09-24 20:54:00.146 Detail, Expected callbackId was received
2018-09-24 20:54:00.170 Detail, Node009, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x09, 0x05, 0x85, 0x03, 0x02, 0x02, 0x00, 0x7a
2018-09-24 20:54:00.170 Info, Node009, Response RTT 48 Average Response RTT 49
2018-09-24 20:54:00.170 Info, Node009, Received Association report from node 9, group 2, containing 0 associations
2018-09-24 20:54:00.170 Info, Node009, Querying associations for node 9 is complete.
2018-09-24 20:54:00.170 Detail, Node009, Expected reply and command class was received
2018-09-24 20:54:00.170 Detail, Node009, Message transaction complete
2018-09-24 20:54:00.171 Detail, Node009, Removing current message
2018-09-24 20:54:00.171 Detail, Node009, Notification: Group
2018-09-24 20:54:00.171 Detail, Node009, Query Stage Complete (Associations)
2018-09-24 20:54:00.171 Detail, Node009, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Neighbors live=1
2018-09-24 20:54:00.171 Detail, Node009, QueryStage_Neighbors
2018-09-24 20:54:00.171 Detail, Requesting routing info (neighbor list) for Node 9
2018-09-24 20:54:00.171 Detail, Node009, Queuing (Command) Get Routing Info (Node=9): 0x01, 0x07, 0x00, 0x80, 0x09, 0x00, 0x00, 0x03, 0x72
2018-09-24 20:54:00.171 Detail, Node009, Queuing (Query) Query Stage Complete (Neighbors)
2018-09-24 20:54:00.171 Info, Node009, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=9): 0x01, 0x07, 0x00, 0x80, 0x09, 0x00, 0x00, 0x03, 0x72
2018-09-24 20:54:00.176 Detail, Node009, Received: 0x01, 0x20, 0x01, 0x80, 0x91, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xcf
2018-09-24 20:54:00.176 Info, Node009, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2018-09-24 20:54:00.176 Info, Node009, Neighbors of this node are:
2018-09-24 20:54:00.176 Info, Node009, Node 1
2018-09-24 20:54:00.176 Info, Node009, Node 5
2018-09-24 20:54:00.176 Info, Node009, Node 8
2018-09-24 20:54:00.176 Detail, Expected reply was received
2018-09-24 20:54:00.176 Detail, Message transaction complete
2018-09-24 20:54:00.176 Detail, Node009, Removing current message
2018-09-24 20:54:00.176 Detail, Node009, Query Stage Complete (Neighbors)
2018-09-24 20:54:00.176 Detail, Node009, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2018-09-24 20:54:00.176 Detail, Node009, QueryStage_Session
2018-09-24 20:54:00.176 Detail, Node009, Queuing (Query) PowerlevelCmd_Get (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x73, 0x02, 0x25, 0x4d, 0xf7
2018-09-24 20:54:00.176 Detail, Node009, Queuing (Query) WakeUpCmd_IntervalGet (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x84, 0x05, 0x25, 0x4e, 0x04
2018-09-24 20:54:00.176 Detail, Node009, Queuing (Query) Query Stage Complete (Session)
2018-09-24 20:54:00.177 Info, Node009, Sending (Query) message (Callback ID=0x4d, Expected Reply=0x04) - PowerlevelCmd_Get (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x73, 0x02, 0x25, 0x4d, 0xf7
2018-09-24 20:54:00.184 Detail, Node009, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-09-24 20:54:00.184 Detail, Node009, ZW_SEND_DATA delivered to Z-Wave stack
2018-09-24 20:54:00.200 Detail, Node009, Received: 0x01, 0x07, 0x00, 0x13, 0x4d, 0x00, 0x00, 0x02, 0xa4
2018-09-24 20:54:00.200 Detail, Node009, ZW_SEND_DATA Request with callback ID 0x4d received (expected 0x4d)
2018-09-24 20:54:00.200 Info, Node009, Request RTT 23 Average Request RTT 23
2018-09-24 20:54:00.200 Detail, Expected callbackId was received
2018-09-24 20:54:00.212 Detail, Node009, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x09, 0x04, 0x73, 0x03, 0x00, 0x00, 0x8c
2018-09-24 20:54:00.212 Info, Node009, Response RTT 35 Average Response RTT 42
2018-09-24 20:54:00.212 Info, Node009, Received a PowerLevel report: PowerLevel=Normal, Timeout=0
2018-09-24 20:54:00.212 Detail, Node009, Initial read of value
2018-09-24 20:54:00.212 Detail, Node009, Expected reply and command class was received
2018-09-24 20:54:00.212 Detail, Node009, Message transaction complete
2018-09-24 20:54:00.212 Detail, Node009, Removing current message
2018-09-24 20:54:00.212 Detail, Node009, Notification: ValueChanged
2018-09-24 20:54:00.212 Info, Node009, Sending (Query) message (Callback ID=0x4e, Expected Reply=0x04) - WakeUpCmd_IntervalGet (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x84, 0x05, 0x25, 0x4e, 0x04
2018-09-24 20:54:00.221 Detail, Node009, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-09-24 20:54:00.221 Detail, Node009, ZW_SEND_DATA delivered to Z-Wave stack
2018-09-24 20:54:00.237 Detail, Node009, Received: 0x01, 0x07, 0x00, 0x13, 0x4e, 0x00, 0x00, 0x02, 0xa7
2018-09-24 20:54:00.237 Detail, Node009, ZW_SEND_DATA Request with callback ID 0x4e received (expected 0x4e)
2018-09-24 20:54:00.237 Info, Node009, Request RTT 24 Average Request RTT 23
2018-09-24 20:54:00.237 Detail, Expected callbackId was received
2018-09-24 20:54:00.249 Detail, Node009, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x09, 0x06, 0x84, 0x06, 0x01, 0x51, 0x80, 0x01, 0xab
2018-09-24 20:54:00.249 Info, Node009, Response RTT 36 Average Response RTT 39
2018-09-24 20:54:00.249 Info, Node009, Received Wakeup Interval report from node 9: Interval=86400, Target Node=1
2018-09-24 20:54:00.249 Detail, Node009, Initial read of value
2018-09-24 20:54:00.249 Detail, Node009, Expected reply and command class was received
2018-09-24 20:54:00.249 Detail, Node009, Message transaction complete
2018-09-24 20:54:00.249 Detail, Node009, Removing current message
2018-09-24 20:54:00.249 Detail, Node009, Notification: ValueChanged
2018-09-24 20:54:00.249 Detail, Node009, Query Stage Complete (Session)
2018-09-24 20:54:00.249 Detail, Node009, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2018-09-24 20:54:00.249 Detail, Node009, QueryStage_Dynamic
2018-09-24 20:54:00.249 Detail, Node009, Queuing (Send) BasicCmd_Get (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x20, 0x02, 0x25, 0x4f, 0xa6
2018-09-24 20:54:00.249 Detail, Node009, Queuing (Send) SensorBinaryCmd_Get (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x30, 0x02, 0x25, 0x50, 0xa9
2018-09-24 20:54:00.249 Detail, Node009, Queuing (Send) AlarmCmd_Get (Node=9): 0x01, 0x0c, 0x00, 0x13, 0x09, 0x05, 0x71, 0x04, 0x00, 0x06, 0x01, 0x25, 0x51, 0xea
2018-09-24 20:54:00.249 Detail, Node009, Queuing (Send) AlarmCmd_Get (Node=9): 0x01, 0x0c, 0x00, 0x13, 0x09, 0x05, 0x71, 0x04, 0x00, 0x07, 0x01, 0x25, 0x52, 0xe8
2018-09-24 20:54:00.249 Detail, Node009, Queuing (Send) BatteryCmd_Get (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x80, 0x02, 0x25, 0x53, 0x1a
2018-09-24 20:54:00.249 Detail, Node009, Queuing (Query) Query Stage Complete (Dynamic)
2018-09-24 20:54:00.249 Info, Node009, Sending (Send) message (Callback ID=0x4f, Expected Reply=0x04) - BasicCmd_Get (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x20, 0x02, 0x25, 0x4f, 0xa6
2018-09-24 20:54:00.258 Detail, Node009, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-09-24 20:54:00.258 Detail, Node009, ZW_SEND_DATA delivered to Z-Wave stack
2018-09-24 20:54:00.274 Detail, Node009, Received: 0x01, 0x07, 0x00, 0x13, 0x4f, 0x00, 0x00, 0x02, 0xa6
2018-09-24 20:54:00.274 Detail, Node009, ZW_SEND_DATA Request with callback ID 0x4f received (expected 0x4f)
2018-09-24 20:54:00.274 Info, Node009, Request RTT 24 Average Request RTT 23
2018-09-24 20:54:00.274 Detail, Expected callbackId was received
2018-09-24 20:54:00.285 Detail, Node009, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x09, 0x03, 0x20, 0x03, 0xff, 0x24
2018-09-24 20:54:00.285 Info, Node009, Response RTT 35 Average Response RTT 37
2018-09-24 20:54:00.285 Info, Node009, Received Basic report from node 9: level=255
2018-09-24 20:54:00.285 Detail, Node009, Initial read of value
2018-09-24 20:54:00.285 Detail, Node009, Expected reply and command class was received
2018-09-24 20:54:00.285 Detail, Node009, Message transaction complete
2018-09-24 20:54:00.285 Detail, Node009, Removing current message
2018-09-24 20:54:00.286 Detail, Node009, Notification: ValueChanged
2018-09-24 20:54:00.286 Info, Node009, Sending (Send) message (Callback ID=0x50, Expected Reply=0x04) - SensorBinaryCmd_Get (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x30, 0x02, 0x25, 0x50, 0xa9
2018-09-24 20:54:00.294 Detail, Node009, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-09-24 20:54:00.294 Detail, Node009, ZW_SEND_DATA delivered to Z-Wave stack
2018-09-24 20:54:00.310 Detail, Node009, Received: 0x01, 0x07, 0x00, 0x13, 0x50, 0x00, 0x00, 0x02, 0xb9
2018-09-24 20:54:00.310 Detail, Node009, ZW_SEND_DATA Request with callback ID 0x50 received (expected 0x50)
2018-09-24 20:54:00.310 Info, Node009, Request RTT 24 Average Request RTT 23
2018-09-24 20:54:00.310 Detail, Expected callbackId was received
2018-09-24 20:54:03.286 Error, Node009, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-09-24 20:54:03.286 Always,
2018-09-24 20:54:03.286 Always, Dumping queued log messages
2018-09-24 20:54:03.287 Always,
2018-09-24 20:54:03.287 Always, End of queued log message dump
2018-09-24 20:54:03.287 Detail, Node009, Removing current message
2018-09-24 20:54:03.287 Detail, Node009, Notification: Notification - TimeOut
2018-09-24 20:54:03.287 Info, Node009, Sending (Send) message (Callback ID=0x51, Expected Reply=0x04) - AlarmCmd_Get (Node=9): 0x01, 0x0c, 0x00, 0x13, 0x09, 0x05, 0x71, 0x04, 0x00, 0x06, 0x01, 0x25, 0x51, 0xea
2018-09-24 20:54:03.295 Detail, Node009, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-09-24 20:54:03.295 Detail, Node009, ZW_SEND_DATA delivered to Z-Wave stack
2018-09-24 20:54:03.311 Detail, Node009, Received: 0x01, 0x07, 0x00, 0x13, 0x51, 0x00, 0x00, 0x02, 0xb8
2018-09-24 20:54:03.311 Detail, Node009, ZW_SEND_DATA Request with callback ID 0x51 received (expected 0x51)
2018-09-24 20:54:03.311 Info, Node009, Request RTT 24 Average Request RTT 23
2018-09-24 20:54:03.311 Detail, Expected callbackId was received
2018-09-24 20:54:03.345 Detail, Node009, Received: 0x01, 0x0f, 0x00, 0x04, 0x00, 0x09, 0x09, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0xfe, 0x00, 0x87
2018-09-24 20:54:03.345 Info, Node009, Response RTT 57 Average Response RTT 47
2018-09-24 20:54:03.345 Info, Node009, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Access Control event:254, status=255
2018-09-24 20:54:03.345 Detail, Node009, Initial read of value
2018-09-24 20:54:03.345 Detail, Node009, Expected reply and command class was received
2018-09-24 20:54:03.345 Detail, Node009, Message transaction complete
2018-09-24 20:54:03.345 Detail, Node009, Removing current message
2018-09-24 20:54:03.345 Detail, Node009, Notification: ValueChanged
2018-09-24 20:54:03.346 Detail, Node009, Notification: ValueChanged
2018-09-24 20:54:03.346 Info, Node009, Sending (Send) message (Callback ID=0x52, Expected Reply=0x04) - AlarmCmd_Get (Node=9): 0x01, 0x0c, 0x00, 0x13, 0x09, 0x05, 0x71, 0x04, 0x00, 0x07, 0x01, 0x25, 0x52, 0xe8
2018-09-24 20:54:03.354 Detail, Node009, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-09-24 20:54:03.354 Detail, Node009, ZW_SEND_DATA delivered to Z-Wave stack
2018-09-24 20:54:03.370 Detail, Node009, Received: 0x01, 0x07, 0x00, 0x13, 0x52, 0x00, 0x00, 0x02, 0xbb
2018-09-24 20:54:03.370 Detail, Node009, ZW_SEND_DATA Request with callback ID 0x52 received (expected 0x52)
2018-09-24 20:54:03.371 Info, Node009, Request RTT 24 Average Request RTT 23
2018-09-24 20:54:03.371 Detail, Expected callbackId was received
2018-09-24 20:54:03.404 Detail, Node009, Received: 0x01, 0x0f, 0x00, 0x04, 0x00, 0x09, 0x09, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x07, 0xfe, 0x00, 0x86
2018-09-24 20:54:03.404 Info, Node009, Response RTT 58 Average Response RTT 52
2018-09-24 20:54:03.404 Info, Node009, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:254, status=255
2018-09-24 20:54:03.404 Detail, Node009, Refreshed Value: old value=0, new value=0, type=byte
2018-09-24 20:54:03.404 Detail, Node009, Changes to this value are not verified
2018-09-24 20:54:03.404 Detail, Node009, Initial read of value
2018-09-24 20:54:03.404 Detail, Node009, Expected reply and command class was received
2018-09-24 20:54:03.404 Detail, Node009, Message transaction complete
2018-09-24 20:54:03.405 Detail, Node009, Removing current message
2018-09-24 20:54:03.405 Detail, Node009, Notification: ValueChanged
2018-09-24 20:54:03.405 Info, Node009, Sending (Send) message (Callback ID=0x53, Expected Reply=0x04) - BatteryCmd_Get (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x80, 0x02, 0x25, 0x53, 0x1a
2018-09-24 20:54:03.413 Detail, Node009, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-09-24 20:54:03.413 Detail, Node009, ZW_SEND_DATA delivered to Z-Wave stack
2018-09-24 20:54:03.429 Detail, Node009, Received: 0x01, 0x07, 0x00, 0x13, 0x53, 0x00, 0x00, 0x02, 0xba
2018-09-24 20:54:03.429 Detail, Node009, ZW_SEND_DATA Request with callback ID 0x53 received (expected 0x53)
2018-09-24 20:54:03.429 Info, Node009, Request RTT 23 Average Request RTT 23
2018-09-24 20:54:03.429 Detail, Expected callbackId was received
2018-09-24 20:54:03.440 Detail, Node009, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x09, 0x03, 0x80, 0x03, 0x64, 0x1f
2018-09-24 20:54:03.440 Info, Node009, Response RTT 34 Average Response RTT 43
2018-09-24 20:54:03.440 Info, Node009, Received Battery report from node 9: level=100
2018-09-24 20:54:03.440 Detail, Node009, Initial read of value
2018-09-24 20:54:03.440 Detail, Node009, Expected reply and command class was received
2018-09-24 20:54:03.440 Detail, Node009, Message transaction complete
2018-09-24 20:54:03.440 Detail, Node009, Removing current message
2018-09-24 20:54:03.441 Detail, Node009, Notification: ValueChanged
2018-09-24 20:54:03.441 Detail, Node009, Query Stage Complete (Dynamic)
2018-09-24 20:54:03.441 Detail, Node009, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2018-09-24 20:54:03.441 Detail, Node009, QueryStage_Configuration
2018-09-24 20:54:03.441 Detail, Node009, QueryStage_Complete
2018-09-24 20:54:03.441 Detail, Node009, Queuing (WakeUp) WakeUpCmd_NoMoreInformation (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x84, 0x08, 0x25, 0x54, 0x13
2018-09-24 20:54:03.441 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=1
2018-09-24 20:54:03.441 Warning, CheckCompletedNodeQueries all=0, deadFound=0 sleepingOnly=1
2018-09-24 20:54:03.441 Detail, Node009, Notification: NodeQueriesComplete
2018-09-24 20:54:03.461 Info, mgr, Manager::WriteConfig completed for driver with home ID of 0xe1f59ff5
2018-09-24 20:54:03.529 Detail,
2018-09-24 20:54:03.530 Info, Node009, Sending (WakeUp) message (Callback ID=0x54, Expected Reply=0x13) - WakeUpCmd_NoMoreInformation (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x84, 0x08, 0x25, 0x54, 0x13
2018-09-24 20:54:03.543 Detail, Node009, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-09-24 20:54:03.543 Detail, Node009, ZW_SEND_DATA delivered to Z-Wave stack
2018-09-24 20:54:03.556 Detail, Node009, Received: 0x01, 0x07, 0x00, 0x13, 0x54, 0x00, 0x00, 0x02, 0xbd
2018-09-24 20:54:03.556 Detail, Node009, ZW_SEND_DATA Request with callback ID 0x54 received (expected 0x54)
2018-09-24 20:54:03.556 Info, Node009, Request RTT 23 Average Request RTT 23
2018-09-24 20:54:03.556 Info, Node009, Node 9 has been marked as asleep
2018-09-24 20:54:03.557 Detail, Expected callbackId was received
2018-09-24 20:54:03.557 Detail, Expected reply was received
2018-09-24 20:54:03.557 Detail, Message transaction complete
2018-09-24 20:54:03.557 Detail, Node009, Removing current message
2018-09-24 20:54:03.557 Detail, Node009, Notification: Notification - Node Asleep
Maybe the problem is related to: 2018-09-24 20:54:03.286 Error, Node009, ERROR: Dropping command, expected response not received after 1 attempt(s)
I've also contacted the Amazon seller regarding this issue and got back the following information:
"We suspect that the gateway has received a status code that causes a "close" event on the gateway. There are two info in the status code, one is the door sensor state (real open or close between the sensor part and the magnetic part) information, the other one is the anti-demolition (the switch in the door sensor is also a tamper switch) state information. When the door or window is opened, the door sensor state is open, but the tamper state is closed, and the demolition state info is transmitted after the door sensor state, it is possible that the gateway does not differentiate between the tamper-proof state and the door sensor state, which leads to the gateway receives "close" info when the window is "open".
To resolve this issue: please set the status code reporting time to be "0", but ensure that the following setup steps are successful.
1. when using the gateway to configure parameters of the door sensors, pay attention to the following parameters parameter, byte, range value, if you want to close the status report, parameter = 3,byte = 1,range = 0 (reference picture as attached)"
So how can I configure paramter=3, byte=1, range=0 in domoticz for the sensor? Any other ideas of how to fix this problem?
Domoticz version: V4.10007
Thank you!
