Seems to work fine, no errors so far in the (now very exhaustive) log.
Looking good. No more errors in the log. Keep up the good work!EscApe wrote: ↑Sunday 09 September 2018 16:36 Now new features or fixes, but i have tweaked the logging a bit
**version 0.6.6**
- Improved: Debug logging for the ssh session now hides the ssh password.
- Improved: Presence changes are now logged (without needing debug mode), so you can see something is going on.
- Improved: Some more log tweaking (removed some redundancies and changed log levels for some messages)
2018-09-12 08:26:40.238 Error: iDetect iPhones hardware (5) thread seems to have ended unexpectedly
2018-09-12 08:26:40.238 Error: iDetect RPi Fnatenrahmen hardware (6) thread seems to have ended unexpectedly
Error: (iDetect) Failed 30 times to get capabilities for 192.168.31.1. Retry interval automatically reduced for this router.
(iDetect) Started.
(iDetect) Entering work loop.
(iDetect) Initialized version 0.7.0, author 'ESCape'
(iDetect) Using generic brctl command on router 192.168.31.1. Will respond slower and on some routers a little less reliable to absence
(iDetect) Awaiting confirmation on absence of 2 devices
(iDetect) Connection restored for 192.168.31.1
(iDetect) SSH command on 192.168.31.1 took 776 milliseconds.
(iDetect) Found these devices connected:[]
(iDetect) Considered absent: Phone2
(iDetect) Considered absent: Phone1
(iDetect) Polling presense data from 192.168.31.1
(iDetect) Using password instead of ssh public key authentication for 192.168.31.1 (less secure!)
(iDetect) Fetching data from 192.168.31.1 using: sshpass -p **secret** ssh -o StrictHostKeyChecking=no -o ConnectTimeout=2 [email protected] export PATH=/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:$PATH;brctl showmacs br0 | grep '..:..:..:..:..:..' | awk '{print $ 2}';exit
(iDetect) ssh command on 192.168.31.1 returned:b''
(iDetect) SSH command on 192.168.31.1 took 780 milliseconds.
brctl showmacs br0
arp -a
root@XiaoQiang:~# brctl showmacs br0
brctl: invalid argument 'showmacs' to 'brctl'
root@XiaoQiang:~# brcl show
-ash: brcl: not found
? (192.168.31.11) at mac adress [ether] on br-lan
2018-09-25 16:34:40.726 Status: (iDetect) Started.
2018-09-25 16:34:40.939 Status: (iDetect) Entering work loop.
2018-09-25 16:34:40.940 Status: (iDetect) Initialized version 0.7.0, author 'ESCape'
2018-09-25 16:34:41.018 (iDetect) SSH subprocess for 192.168.0.1 failed with error (255):b''
2018-09-25 16:34:41.018 (iDetect) SSH command on 192.168.0.1 took 30 milliseconds.
2018-09-25 16:34:41.018 (iDetect) Could not retreive available commands on 192.168.0.1
2018-09-25 16:34:41.018 (iDetect) Router initialized as:{'192.168.0.1': {'user': '<user account for SSH>', 'errorcount': 1, 'cmd': '', 'prospone': datetime.datetime(2018, 9, 25, 16, 34, 53, 18616), 'initialized': False}}
2018-09-25 16:34:41.018 (iDetect) iDetect - Phone1 is stil in use
2018-09-25 16:34:41.018 (iDetect) iDetect - Phone2 is stil in use
2018-09-25 16:34:41.018 (iDetect) iDetect - Phone3 is stil in use
2018-09-25 16:34:41.019 (iDetect) Devicenames and their Domoticz (subdevice) index: {'Hans': 2, 'Nellie': 3, 'Michel': 4}
2018-09-25 16:34:41.019 (iDetect) MAC addresses to monitor: {'Phone1': {'ignore': False, 'mac': 'D0:B1:28:37:4E:23', 'lastseen': None}, 'Phone2': {'ignore': False, 'mac': '44:C3:46:48:E8:2B', 'lastseen': None}, 'Phone3': {'ignore': False, 'mac': '64:A2:F9:28:5A:A1', 'lastseen': None}}
2018-09-25 16:34:41.019 (iDetect) Plugin initialization done.
2018-09-25 16:34:50.988 (iDetect) Prosponed connection to 192.168.0.1 for 0:00:02.030716
2018-09-25 16:34:50.988 (iDetect) Did not retreive WLAN information from any router
2018-09-25 16:35:00.954 (iDetect) 192.168.0.1 was not properly initialized. Retrying to get router capabilities (and skipping this poll round).
2018-09-25 16:35:00.955 (iDetect) Using password instead of ssh public key authentication for 192.168.0.1 (less secure!)
2018-09-25 16:35:00.955 (iDetect) Fetching data from 192.168.0.1 using: sshpass -p **secret** ssh -o StrictHostKeyChecking=no -o ConnectTimeout=2 [email protected]
2018-09-25 16:35:00.955 #!/bin/sh
2018-09-25 16:35:00.955 export PATH=/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:$PATH
2018-09-25 16:35:00.955 type wl > /dev/null 2>&1 && printf "~wl"
2018-09-25 16:35:00.955 type iwinfo > /dev/null 2>&1 && printf "~iwinfo"
2018-09-25 16:35:00.955 type wlanconfig > /dev/null 2>&1 && printf "~wlanconfig"
2018-09-25 16:35:00.955 type qcsapi_sockrpc > /dev/null 2>&1 && printf "~qcsapi_sockrpc"
2018-09-25 16:35:00.955 type brctl > /dev/null 2>&1 && printf "~brctl"
2018-09-25 16:35:00.955 type arp > /dev/null 2>&1 && printf "~arp"
2018-09-25 16:35:00.955 [ -f /proc/net/arp ] && printf "~procarp"
2018-09-25 16:35:00.955 exit
2018-09-25 16:35:01.045 (iDetect) SSH subprocess for 192.168.0.1 failed with error (255):b''
2018-09-25 16:35:01.045 (iDetect) SSH command on 192.168.0.1 took 90 milliseconds.
2018-09-25 16:35:01.045 (iDetect) Could not retreive available commands on 192.168.0.1
2018-09-25 16:35:01.046 (iDetect) Routerinfo:{'user': '<user account for SSH>', 'errorcount': 2, 'cmd': '', 'prospone': datetime.datetime(2018, 9, 25, 16, 36, 1, 46001), 'initialized': False}
2018-09-25 16:35:01.046 (iDetect) Did not retreive WLAN information from any router
2018-09-25 16:35:10.964 (iDetect) Prosponed connection to 192.168.0.1 for 0:00:50.081134
2018-09-25 16:35:10.965 (iDetect) Did not retreive WLAN information from any router
2018-09-25 16:35:20.984 (iDetect) Prosponed connection to 192.168.0.1 for 0:00:40.061711
2018-09-25 16:35:20.984 (iDetect) Did not retreive WLAN information from any router
2018-09-25 16:35:30.957 (iDetect) Prosponed connection to 192.168.0.1 for 0:00:30.088598
2018-09-25 16:35:30.957 (iDetect) Did not retreive WLAN information from any router
Thanks for the quick update, now it is working
2018-09-26 08:30:11.164 (iDetect) Considered absent: Miche-GSMl
2018-09-26 08:30:15.671 (iDetect) Polling presense data from 192.168.0.1
2018-09-26 08:30:16.219 (iDetect) Using password instead of ssh public key authentication for 192.168.0.1 (less secure!)
2018-09-26 08:30:16.220 (iDetect) Fetching data from 192.168.0.1 using: sshpass -p **secret** ssh -o StrictHostKeyChecking=no -o ConnectTimeout=2 -p9325 <username router>@192.168.0.1 export PATH=/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:$PATH;arp -a | grep '..:..:..:..:..:..' | awk '{print $ 4}';exit
2018-09-26 08:30:18.240 (iDetect) SSH subprocess for 192.168.0.1 timeout
2018-09-26 08:30:18.240 (iDetect) SSH command on 192.168.0.1 took 20 milliseconds.
2018-09-26 08:30:18.241 (iDetect) Routerinfo:{'user': '<username router>', 'initialized': True, 'port': 9325, 'prospone': datetime.datetime(2018, 9, 26, 8, 30, 48, 241000), 'cmd': "export PATH=/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:$PATH;arp -a | grep '..:..:..:..:..:..' | awk '{print $ 4}';exit", 'errorcount': 1}
2018-09-26 08:30:18.241 (iDetect) Did not retreive WLAN information from any router
2018-09-26 08:30:22.751 (iDetect) Prosponed connection to 192.168.0.1 for 0:00:25.489953
2018-09-26 08:30:22.751 (iDetect) Did not retreive WLAN information from any router
2018-09-26 08:30:27.759 (iDetect) Prosponed connection to 192.168.0.1 for 0:00:20.481861
2018-09-26 08:30:27.759 (iDetect) Did not retreive WLAN information from any router
2018-09-26 08:30:32.768 (iDetect) Prosponed connection to 192.168.0.1 for 0:00:15.472683
2018-09-26 08:30:32.768 (iDetect) Did not retreive WLAN information from any router
2018-09-26 08:30:37.787 (iDetect) Prosponed connection to 192.168.0.1 for 0:00:10.453300
2018-09-26 08:30:37.788 (iDetect) Did not retreive WLAN information from any router
2018-09-26 08:30:42.683 MQTT: Topic: domoticz/in, Message: {"idx":3417,"nvalue":0,"svalue":"26.8"}
2018-09-26 08:30:47.754 (iDetect) Prosponed connection to 192.168.0.1 for 0:00:00.486358
2018-09-26 08:30:47.754 (iDetect) Did not retreive WLAN information from any router
2018-09-26 08:30:52.769 (iDetect) Polling presense data from 192.168.0.1
2018-09-26 08:30:52.769 (iDetect) Using password instead of ssh public key authentication for 192.168.0.1 (less secure!)
2018-09-26 08:30:52.769 (iDetect) Fetching data from 192.168.0.1 using: sshpass -p **secret** ssh -o StrictHostKeyChecking=no -o ConnectTimeout=2 -p9325 <username router>@192.168.0.1 export PATH=/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:$PATH;arp -a | grep '..:..:..:..:..:..' | awk '{print $ 4}';exit
2018-09-26 08:30:53.742 (iDetect) ssh command on 192.168.0.1 returned:b'00:23:eb:78:00:d9\n5c:cf:7f:af:bd:a8\nd0:17:c2:ba:15:19\nc0:3f:d5:69:c5:19\n60:01:94:29:df:03\n4c:32:75:35:5e:6f\n5c:cf:7f:4c:52:27\n2c:3a:e8:2e:89:6d\n00:11:32:2c:12:f1\nf0:9f:c2:a6:cc:96\ne0:50:8b:32:5b:34\nd0:e7:82:da:08:fd\n44:c3:46:48:e8:2b\n00:1c:85:0a:41:f3\n8c:89:a5:cc:85:df\nd0:b1:28:37:4e:23\nb8:27:eb:16:63:96\n00:11:32:0f:0a:dc\n28:6c:07:85:e7:60\n5c:cf:7f:58:42:f1\nac:cf:23:6d:3e:58\n64:a2:f9:28:5a:a1\nf0:9f:c2:a6:c7:18\n00:11:32:2c:12:f2\n5c:cf:7f:f9:09:7a\n78:8a:20:83:e1:27\n'
2018-09-26 08:30:53.742 (iDetect) SSH command on 192.168.0.1 took 972 milliseconds.
2018-09-26 08:30:53.743 (iDetect) Found these devices connected:['00:23:EB:78:00:D9', '5C:CF:7F:AF:BD:A8', 'D0:17:C2:BA:15:19', 'C0:3F:D5:69:C5:19', '60:01:94:29:DF:03', '4C:32:75:35:5E:6F', '5C:CF:7F:4C:52:27', '2C:3A:E8:2E:89:6D', '00:11:32:2C:12:F1', 'F0:9F:C2:A6:CC:96', 'E0:50:8B:32:5B:34', 'D0:E7:82:DA:08:FD', '44:C3:46:48:E8:2B', '00:1C:85:0A:41:F3', '8C:89:A5:CC:85:DF', 'D0:B1:28:37:4E:23', 'B8:27:EB:16:63:96', '00:11:32:0F:0A:DC', '28:6C:07:85:E7:60', '5C:CF:7F:58:42:F1', 'AC:CF:23:6D:3E:58', '64:A2:F9:28:5A:A1', 'F0:9F:C2:A6:C7:18', '00:11:32:2C:12:F2', '5C:CF:7F:F9:09:7A', '78:8A:20:83:E1:27']
2018-09-26 08:30:53.743 Status: (iDetect) Connection restored for 192.168.0.1
2018-09-26 08:30:53.758 Status: (iDetect) Changing presence of iDetect - Miche-GSMl to On
