LUA script for calculating Solar Boiler yield in kWh
marcoschaap
Post by marcoschaap »
Hi Guys!
I'm trying to create a script which calculates the yield of my solar boiler system in kWh. I'm measuring and registering boiler temperatures on 2 seperate Domoticz devices (Temp_Upper_IDX & Temp_Bottom_IDX). I've created a virtual device to store the yield. I've used pieces of code of a script for measuring degree days, specifically the JSON decode part.
To calculate the yield in kWh I'm measuring the delta temperatures between the day minus and maximum temperature for the two temp sensors. These two values are plussed and after that divided by 2. I have a 300 liter boiler in which heating up all 300 liters takes 0.34 kWh, so the value is multiplied by 0.34.
The values tm and te represent the minimum and maximum temperatures for the sensor. If I browse directly to the JSON url I get the following values:
         "d" : "2018-09-20",
         "hu" : "51",
         "ta" : 64.879999999999995,
         "te" : 73.299999999999997,
         "tm" : 58.700000000000003
         "d" : "2018-09-21",
         "hu" : "51",
         "ta" : 56.189999999999998,
         "te" : 59.899999999999999,
         "tm" : 49.600000000000001
         "d" : "2018-09-22",
         "hu" : "51.0",
         "ta" : 51.1013333333334,
         "te" : 56.899999999999999,
         "tm" : 40.299999999999997
   "status" : "OK",
   "title" : "Graph temp month"
The original JSON decode part of the script was borrowed from this script:
local t, jresponse, status, decoded_response
server_url = "http://"..Domo_IP..":"..Domo_Port
t = server_url.."/json.htm?type=graph&sensor=counter&range=week&idx="..tostring(Gasmeter_IDX)
jresponse, status = http.request(t)
decoded_response = JSON:decode(jresponse)
result = decoded_response["result"]
gas_usage_today = tonumber(result[8]["v"])
This is the complete script which is obviously not working, could anyone point me in the right direction?
--script_device_calculate_solaryield.lua
-- Variables that can be changed
Debug = 1											--Enable/Disable logging
Domo_IP = ('x.x.x.x')								-- IP Address of Domoticz instance
Domo_Port = ('8080')								-- Port used by Domoticz instance
local SolarBoiler_IDX = 193							--Device ID to write calculated Solar Yield (virtual Electric (actual & counter)
Temp_Upper_IDX = 174								--Name of boiler upper temp sensor.
Temp_Bottom_IDX = 176								--Name of boiler bottom temp sensor.
-- End Vars
time = os.date("*t")
if((time.min % 1)==0)then --Run every 5 minutes
-- Load necessary Lua libraries
http = require "socket.http";
socket = require "socket";
-- https = require "ssl.https";
-- JSON = require "json";
JSON = (loadfile "/home/marco/domoticz/scripts/lua/JSON.lua")()
local u, jresponseu, statusu, decoded_responseu
local b, jresponseb, statusb, decoded_responseb
u = server_url.."/json.htm?type=graph&sensor=temp&range=month&idx="..tostring(Temp_Upper_IDX)
b = server_url.."/json.htm?type=graph&sensor=temp&range=month&idx="..tostring(Temp_Bottom_IDX)
jresponseu, statusu = http.request(u)
jresponseb, statusb = http.request(b)
decoded_responseu = JSON:decode(jresponseu)
decoded_responseb = JSON:decode(jresponseb)
resultu = decoded_responseu["resultu"]
resultb = decoded_responseb["resultb"]
temp_upper_day_min = tonumber(resultu[8]["tm"])
temp_upper_day_max = tonumber(resultu[8]["te"])
temp_bottom_day_min = tonumber(resultb[8]["tm"])
temp_bottom_day_max = tonumber(resultb[8]["te"])
temp_upper_delta = temp_upper_day_max - temp_upper_day_min
temp_bottom_delta = temp_bottom_day_max - temp_bottom_day_min
temp_delta = temp_upper_delta + temp_bottom_delta / 2
solar_yield = temp_delta * 0.34
if solar_yield == nil or solar_yield == '' then
solar_yield = 0
-- Debug Data
if Debug == 1 then
        print("Upper Temp Max: " ..temp_upper_day_max)
        print("Upper Temp Min: " ..temp_upper_day_min)
        print("Upper Temp Delta: " ..temp_upper_delta)
        print("Bottom Temp Max: " ..temp_bottom_day_max)
        print("Bottom Temp Min: " ..temp_bottom_day_min)
		print("Bottom Temp Delta: " ..temp_bottom_delta)
        print("Solar Yield: " ..solar_yield)
-- End Debug Data
-- Update Devices
commandArray[SolarBoiler_IDX] = { ['UpdateDevice'] = SolarBoiler_IDX..'|0|'..solar_yield }
-- End Update Devices
The script shows the following error in the Domoticz Log:
2018-09-22 13:38:30.019 Error: EventSystem: in /home/marco/domoticz/scripts/lua/script_device_calculate_solaryield.lua: ...oticz/scripts/lua/script_device_calculate_solaryield.lua:42: attempt to index global 'resultu' (a nil value)
McMelloW
Domoticz version: V2024.1
Re: LUA script for calculating Solar Boiler yield in kWh
Post by McMelloW »
Hi Marco,
Have look at this post, it might be of some help.
https://www.domoticz.com/forum/viewtopi ... 36#p174136
Greetings McMelloW
