I see a lot of ipadresses in my domoticz log,
Should i worry about it ?
What can i do to prevent this?
See log:
connection from: 95.8.197.10
2018-09-20 01:22:53.154 Incoming connection from: 46.243.189.60
2018-09-20 01:41:28.031 Incoming connection from: 103.90.205.23
2018-09-20 01:41:55.228 Incoming connection from: 185.197.141.214
2018-09-20 02:24:55.558 Incoming connection from: 46.174.191.30
2018-09-20 02:40:01.941 Incoming connection from: 95.9.180.25
2018-09-20 02:59:13.897 Incoming connection from: 184.105.139.67
2018-09-20 04:58:53.325 Incoming connection from: 46.174.191.32
2018-09-20 05:22:49.728 Incoming connection from: 185.208.148.74
2018-09-20 05:24:56.831 Incoming connection from: 189.18.211.4
2018-09-20 05:37:48.690 Incoming connection from: 116.49.73.32
2018-09-20 06:27:07.573 Incoming connection from: 78.108.177.51
2018-09-20 06:57:14.570 Incoming connection from: 122.228.10.51
2018-09-20 07:12:25.380 Incoming connection from: 45.127.220.46
2018-09-20 07:45:01.287 Incoming connection from: 123.211.14.244
2018-09-20 07:56:15.530 Incoming connection from: 103.36.127.142
2018-09-20 08:03:25.483 Incoming connection from: 194.44.180.48
2018-09-20 09:15:07.357 Incoming connection from: 89.205.134.153
2018-09-20 09:15:53.935 Incoming connection from: 178.212.168.252
© 2012-2018 Dom
Ip adresses
SweetPants
Re: Ip adresses
Yes you should worry about that. These are internet IP addresses and they try to connect to your domoticz system. Add a firewall in between or use a VPN connection from outside.
- Egregius
- Domoticz version: v2024.7
Re: Ip adresses
Or install fail2ban to block them.
edwin1234
- Domoticz version: 2021.1
Re: Ip adresses
Thanks for the help,
I think i go for a vpn
