HTTPS bad request problem
heggink
Domoticz version: 12451
Post by heggink »
I am trying to convert a requests based HTTPS call into the python framework but struggling to get it to work. The original call is as follows:
base_url = "https://api.life360.com/v3/"
token_url = "oauth2/token.json"
    circles_url = "circles.json"
    circle_url = "circles/"
    authorization_token = "cFJFcXVnYWJSZXRyZTRFc3RldGhlcnVmcmVQdW1hbUV4dWNyRUh1YzptM2ZydXBSZXRSZXN3ZXJFQ2hBUHJFOTZxYWtFZHI0Vg=="
    headers = {'Accept': 'application/json'}
    authheader="Basic " + authorization_token
    headers.update({'Authorization': authheader, 'cache-control': "no-cache",})
    url = self.base_url + self.token_url
    params = {
        "grant_type":"password",
        "username":self.username,
        "password":self.password,
     r = requests.post(url, data=params, headers=headers)
The plugin call si as follows:
    self.authorization_token = "cFJFcXVnYWJSZXRyZTRFc3RldGhlcnVmcmVQdW1hbUV4dWNyRUh1YzptM2ZydXBSZXRSZXN3ZXJFQ2hBUHJFOTZxYWtFZHI0Vg=="
    params = {
        "grant_type": "password",
        'username': self.username,
        'password': self.password,
    headers = { 'Content-Type': 'application/json; charset=utf-8', \
                'Accept': 'application/json', \
                'cache-control': "no-cache", \
                'Authorization': "Basic " + self.authorization_token, \
                'User-Agent':'Domoticz/1.0' }
    Connection.Send({'Verb':'POST', 'URL':self.token_url, 'Headers': headers, 'Data': params})
but results in a HTTP BAD REQUEST error (the connect itself is fine and onConnect gets called). Aything 'obvious I am missing? I never used the plugin this way so struggling to make it work :-(.
Thanks for the help!
H
ps: original code at https://github.com/harperreed/life360-python
DASHTICZ 🙃
P1 meter & solar panel
brunonar
Re: HTTPS bad request problem
Post by brunonar »
Try to use curl on both versions to get the RAW data. You'll find out the difference between the two codes.
To get the raw data you can do it, for example:
https://stackoverflow.com/questions/430 ... -with-curl
heggink
Post by heggink »
Found the culprit with help from dnpwwo: Don't use Username and Password keywords in the plugin unless you intend to use this mechanism in authentication. I needed my own authentication causing the plugin to misbehave. Switching to a Mode parameter fixed it.
DASHTICZ 🙃
