SweetPants
Re: machinon theme - (work in progress)
Ok, that is why you can't update via git. Do the following
1) remove the machinon directory
2) cd ~/domoticz/www/styles
3) git clone https://github.com/EdddieN/machinon-domoticz_theme.git
4) cp ~/domoticz/www/styles/machinon-domoticz_theme/templates/Settings.html ~/domoticz/www/templates/
5) restart domoticz
6) Select the new theme
5) restart domoticz
Hobbybob
Ah, that works!SweetPants wrote: Tuesday 11 September 2018 20:32 Ok, that is why you can't update via git. Do the following
5) restart domoticz
If I understand correctly, I can update in the future with "git pull" now?
I also see that the blocks are now stretched if there is not a full row, nice touch Eddie, I like it!
SweetPants
YesHobbybob wrote: Tuesday 11 September 2018 20:48 If I understand correctly, I can update in the future with "git pull" now?
- EdddieN
- Domoticz version: 4.9700
I didn't know that myself, good to know! I was getting tied of the FTPSweetPants wrote: Tuesday 11 September 2018 20:50YesHobbybob wrote: Tuesday 11 September 2018 20:48 If I understand correctly, I can update in the future with "git pull" now?
About to upload this to show your projects, recognise the theme?
11101101 - www.machinon.com
- EdddieN
Is the UV icon to look like this?
snuiter
nice video EdddieN
- heggink
- Domoticz version: 12451
Re: machinon theme
methinks great theme!
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
poudenes
- Domoticz version: 3.8993
Re: machinon theme
love the dark version !!! so cool to see a group of geeks and build a perfect Theme... Maybe Domoticz want this theme as their default !
snuiter
Re: machinon theme
I must say I love this theme as well but the bug remains that on both iphone and ipad I can not select in the settings menu the Theme part. So this means no dark theme possible on ipad and iphone. Any suggestions? Tried a lott but not able to tap it in both landscape and portrait mode. It simple does not respond.
But great work !!
But great work !!
- DewGew
- Domoticz version: V4.10618
Re: machinon theme
We are working on this issue https://github.com/EdddieN/machinon-dom ... /issues/52.snuiter wrote: Friday 14 September 2018 9:26 I must say I love this theme as well but the bug remains that on both iphone and ipad I can not select in the settings menu the Theme part. So this means no dark theme possible on ipad and iphone. Any suggestions? Tried a lott but not able to tap it in both landscape and portrait mode. It simple does not respond.
But great work !!
snuiter
Re: machinon theme
Don't waste any time....
hahaha sorry
hahaha sorry
- EdwinK
- Domoticz version: BETA
Re: machinon theme
Since using this theme, I can't make backup's anymore. It want's to save as backupdatebase.php instead of a .db file, ending in a network error.
- DewGew
Re: machinon theme
I dont have that issue.EdwinK wrote: Friday 14 September 2018 9:57 Since using this theme, I can't make backup's anymore. It want's to save as backupdatebase.php instead of a .db file, ending in a network error.
- EdwinK
Re: machinon theme
The problem is, that I do have that problem
- EdddieN
Re: machinon theme
Can you give details of browser, OS and any specific detail? I'll see if I can replicate it.EdwinK wrote: Friday 14 September 2018 9:57 Since using this theme, I can't make backup's anymore. It want's to save as backupdatebase.php instead of a .db file, ending in a network error.
However the theme has had quite a few changes lately so very likely it is a cache and App cache issue. If in doubt, try both + incognio
- EdwinK
Re: machinon theme
Running on Mac El Capitan and used both chrome and safari browsers, both give the same problems. For now switched back to one of the standard themes, and no problems.
Already did clean appcache and the normal cache. I'll try the incognito method next.
- heggink
Re: machinon theme
How are the settings saved? On Android, I can select dark and it sticks. On linux/chrome, I can select dark but next time I start chrome, I am back to the light settings. I do clear all my cache and cookies on exit though (click & clean). Tried to get click&clean to retain all info but it still won;t stick
DASHTICZ 🙃
DASHTICZ 🙃
Hobbybob
Re: machinon theme
Perhaps not the most usefull to you, but for information: I can download the databse correctly with the backup-button. I'm on Win10, using Firefox.EdwinK wrote: Saturday 15 September 2018 9:38 Running on Mac El Capitan and used both chrome and safari browsers, both give the same problems. For now switched back to one of the standard themes, and no problems.
- EdddieN
Re: machinon theme
Can you try this?EdwinK wrote: Saturday 15 September 2018 9:38 Running on Mac El Capitan and used both chrome and safari browsers, both give the same problems. For now switched back to one of the standard themes, and no problems.
1.- Try the backup button
2.- on terminal, run top
3.- is your domoticz eating a lot of CPU?
I just tried on High Sierra and Chrome and it worked, that said, it took a while as my DB is quite big. For a moment I thought it was not working, until I run top and I could see it was working hard
Users browsing this forum: madpatrick and 1 guest
