group.state not on / mixed
terrorsource
I'm trying to make a dzvents script based on a group of lights.
I want to switch "Slapen" on when all lights are off between nighttime.
Is it possible to get the status "Mixed" of a group?
I now have a script based on "group.state == 'Off'" but "On" should not work because not all lights are on at once.
Can i set "group.state == 'Mixed" ? It is not stated in the wiki.
- waaren
Re: group.state not on / mixed
Yes,terrorsource wrote: Thursday 13 September 2018 10:51 Hi,
on = { devices = { "triggerDevice" }}, -- Change for your triggerDevice
logging = { level = domoticz.LOG_DEBUG,
marker = "Check Group state" },
execute = function(dz)
myGroup = dz.groups("All active devices") -- Change for your group
if myGroup.state == "Mixed" then
dz.log("state of group " .. myGroup.name .. " ===>> " .. myGroup.state,dz.LOG_DEBUG)
}Debian buster, bullseye on RPI-4, Intel NUC.
terrorsource
I've now created this, but it is not sending a message via Prowl when the status of the Group changes.
groups = { 'AlleLampenHuis' }
myGroup = dz.groups("AlleLampenHuis") -- Change for your group
if myGroup.state == "Mixed" and domoticz.devices("Thuis").state == "Off" then
-- domoticz.devices("Slapen").switchOff().checkFirst()
domoticz.notify("State=MIXED","State=MIXED.", domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_PROWL)
elseif myGroup.state == "Off" and domoticz.devices("Thuis").state == "Off" then
-- domoticz.devices("Slapen").switchOn().checkFirst()
domoticz.notify("State=OFF","State=OFF.", domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_PROWL)
elseif myGroup.state == "On" and domoticz.devices("Thuis").state == "Off" then
domoticz.notify("State=ON","State=ON.", domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_PROWL)
- waaren
Try change all "dz" to "domoticz" or vice versa.terrorsource wrote:I've now created this, but it is not sending a message via Prowl when the status of the Group changes.
Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk
terrorsource
Still not working. I've even cleaned up the script but it is not sending messages. Looks like it's never triggered.waaren wrote: Thursday 13 September 2018 17:31Try change all "dz" to "domoticz" or vice versa.terrorsource wrote:I've now created this, but it is not sending a message via Prowl when the status of the Group changes.
Now have only 1 switch in the group, a dummy switch. when i toggle it nothing happens.
execute = function(domoticz, group)
myGroup = domoticz.groups("AlleLampenHuis")
elseif myGroup.state == "Off" then
elseif myGroup.state == "On" then
- waaren
The script in its current form will only execute when the group is switched On or Off. State changes of any device in the group will not trigger it.terrorsource wrote: Thursday 13 September 2018 20:25Still not working. I've even cleaned up the script but it is not sending messages. Looks like it's never triggered.waaren wrote: Thursday 13 September 2018 17:31Try change all "dz" to "domoticz" or vice versa.terrorsource wrote: I've now created this, but it is not sending a message via Prowl when the status of the Group changes.
domoticz simply does not create a group level event for it and dzVents is therefore not aware anything changed on the grouplevel.
If you want to have the script triggered on any groupdevice change you will have to add these devices in the "on = devices" section
on = { devices = { "groupdevice1, groupdevice2 , ... groupdevice99" }}, what might help is that these devicenames can be entered in a wildcard form e.g. group*
terrorsource
The last script is just for test purposes only.waaren wrote: Thursday 13 September 2018 21:21The script in its current form will only execute when the group is switched On or Off. State changes of any device in the group will not trigger it.terrorsource wrote: Thursday 13 September 2018 20:25Still not working. I've even cleaned up the script but it is not sending messages. Looks like it's never triggered.
If you want to have the script triggered on any groupdevice change you will have to add these devices in the "on = devices" sectionCode: Select all
Want to have it send a message when the group has changed (ON/OFF/Mixed).
From there on i can switch "Sleeping" on and create an alarm for motion and doors.
- waaren
Maybe this other approach can help you achieving what you want. It will notify you within a minute after a group state change happens by a device in that group or imediate when the group itself was changed manual of via a command.terrorsource wrote: Friday 14 September 2018 9:28 The last script is just for test purposes only.
When executed the first time it will also send 1 notification
local groupName = "AlleLampenHuis"
groups = { groupName },
timer = { "every minute" },
httpResponses = { "getSceneState" }},
logging = {
level = domoticz.LOG_INFO,
marker = "getSceneState"
data = { state = { initial = "" }},
execute = function(dz, item)
local myGroup = dz.groups(groupName)
local function triggerJSON()
local urlString = dz.settings['Domoticz url'] .. "/json.htm?type=scenes"
dz.openURL({ url = urlString,
method = "GET",
callback = "getSceneState" })
local function getState(groupName)
local state = "No state found for " .. groupName
if item.json.result ~= nil then
rt = item.json.result
dz.log("No values found",dz.LOG_DEBUG )
return
for i=1,#rt do -- Loop through the result
dz.log( "Checking group " .. rt[i].idx .. " ===>> " .. rt[i].Name ,dz.LOG_DEBUG)
if rt[i].Name == groupName then
return rt[i].Status
return state
if item.isHTTPResponse then
myGroup.state = getState(groupName)
if myGroup.state ~= dz.data.state then
dz.data.state = myGroup.state
dz.log("State changed to " .. myGroup.state, dz.LOG_FORCE)
dz.notify("State=" .. myGroup.state ,"State=" .. myGroup.state, dz.PRIORITY_NORMAL,nil,nil,dz.NSS_PROWL)
dz.log("State of : " .. myGroup.name .. " is still " .. myGroup.state, dz.LOG_DEBUG)
triggerJSON()
terrorsource
Thanks for the script. i've extended it a bit further.waaren wrote: Saturday 15 September 2018 21:48Maybe this other approach can help you achieving what you want. It will notify you within a minute after a group state change happens by a device in that group or imediate when the group itself was changed manual of via a command.terrorsource wrote: Friday 14 September 2018 9:28 The last script is just for test purposes only.
This is the result:
timer = { "every minute between nighttime and 05:00", "at 05:01" },
logging = {
method = "GET",
return
return rt[i].Status
return state
if domoticz.time.matchesRule("at 05:01") then
dz.devices("Slapen").switchOff().checkFirst()
dz.notify("Slaapstand=OFF","Slaapstand is uitgezet.", dz.PRIORITY_NORMAL,nil,nil,dz.NSS_PROWL)
elseif myGroup.state ~= dz.data.state then
if dz.data.state == "Off" and dz.devices("Thuis").state == "On" then
dz.devices("Slapen").switchOn().checkFirst()
dz.notify("Slaapstand=ON","Slaapstand is aangezet.", dz.PRIORITY_NORMAL,nil,nil,dz.NSS_PROWL)
elseif dz.data.state == "On" and dz.devices("Thuis").state == "On" then
elseif dz.data.state == "Mixed" and dz.devices("Thuis").state == "On" then
elseif
dz.log("Status van : " .. myGroup.name .. " is nog steeds: " .. myGroup.state, dz.LOG_DEBUG)
triggerJSON()
